Question about Kenmore Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker
My kenmore elite refrig keeps leaking water from what appears to be condensation. It gets so bad that the ice maker door freezes shut and water actually drips on the floor. The freezer is set to 0 while the refrig is set to 37. Any suggestions.
  • Kenmore Master
  • 17,130 Answers
The high level of condensation is due to constant opening of the fridge when the frost develops. It is required to defrost off the condensation and if this has an auto mode timer for defrost , then it is possible that it is not working.
The water must drain out to the drain tank but since it is formed out of the freezer the water flows out of the collection tray.
Posted on Sep 27, 2010
We have a Kenmore Elite 795 fridge. It is constantly leaking water from the bottom right corner of the unit onto the floor. There always seems to be a build up of ice at the bottom of the unit.
Usually the result of CONDENSATION due to eithr bad door seals allowing air and moister in to condensate. or a plugged or clogged evaporator drain line which causes water to back up and freeze or leak out the lowest point the bottom?
Mar 19, 2015 | Kenmore Refrigerators
Scotsman ice maker, short freeze code no ice
this Scotsman Prodigy had bad Ice thickness probe, error was for long freeze cycle. Hope this video will help someone
Jul 13, 2014 | Kitchen Appliances - Others
My refrigator isn't making ice, and hasn't in about 6 months?
It could be a couple of resons, I have the same problem. With my refrigator its the water tube that fills the tray freeze up. So I have to shut off the unit, leave the freezer door open for about 30 minutes or so. Then restart the unit.
Jan 31, 2012 | Kenmore Elite 78722 78729 Bottom Freezer...
My Whirpool Bottom Freezer Refrigerator keeps collecting ice at the bottom of the freezer and eventually, every couple of weeks, leaks onto the floor. It does have an ice maker which is not hooked up. We...
The defrosting heating element may have burnt out. Also if the gasket around the door/drawer isn't sealing correctly moisture from the air leaking in could be condensing inside and then freezing causing the build up.
Please rate my response.
Jan 14, 2011 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
The water feed line to the ice maker keeps freezing adjusta cube ice maker
you have a bad water valve on the back of the machine,it's not totally shuting the water down,the water that is trickling through is freezing up on you
Feb 22, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
I have a Kenmore side by side elite. I have installed a new ice maker. I can not get water into the ice maker. The extraction teeth rotate and I get water through the water port on the door but not into...
Usually happends that the solenoid (electric valve who opends when the ice maker calls for water) leaks and this water freezes up inside the filling tube for the ice maker , t he solenoid has to be replaced.
Sep 20, 2009 | Refrigerators
Ice maKer is not getting water but the water side works.
Your refrig water valve , has 2 coils on one valve . One is for the water dispensor , and one is for the ice maker . So even if you get water thru the dispensor , the other coil ( for the ice maker ) could be bad . The fill tube from inside the freezer to the ice maker , could be frozen solid , keeping the water from entering the ice maker . This frozen tube , would be caused be the water valve " seeping " , which means , it isn't closing completely , and drips freezing inside the tube . indicating a bad water valve . Pour about 2/3 cup of water into the ice maker . If it dumps , but doesn't refill with water , replace the water valve but also check this tube . If the ice maker does not dump the frozen cubes , replace the ice maker , but also check the coils under the refrig , for dust , lint , etc , needing to be cleaned off . The ice maker needs to be 5 degrees to operate , and dirty coils can keep the freezer at 6 degrees or above .
Sep 15, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice maker stopped making ice. Now water continuously drips.
Replace the water valve behind refrig , where the wall water line connects to on refrig .
Aug 31, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Can't identify "water filter indicator light"
the indicator light could be on the control panel inside the refr section if your controls are there, or it is most likely on the front of the dispenser panel. it only comes on when you draw water from the dispenser and thats when you will see it be green, filter ok, yellow, filter at 80% life, or red, time to replace the water filter.
also you dont need to shut off the water when changing the filter as it is made with a shut off device in the filter housing already and is automatic.
by the way filters are expensive, go online and check prices. google "water filters" and find a good price.
Dec 13, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore Elite 795 75542401
I replaced my "entire" ice cube maker (tube,hoses,water pump, ice maker) and it still pooled water at the bottom. I removed the back panel in the freezer and noticed the ciols go through a defrost cycle and water forms in tray under coils. I removed the lower panel on rear of fridge -and found a drain hose near the water solenoid/pump. I blew compressed air into the hose and hopefully unblocked it so it can drain into the pan not the freezer.
Jul 16, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Kenmore Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker Logo
226 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
jackdo2
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
