Question about HP LaserJet 2420 Printer
Hp laser jet m4345mfp errore 13.05.00 top cover jam intrmintan problem
5 Suggested Answers
  • 105 Answers
SOURCE: Our HP Color Laser Jet 4700 dn frequently gives an
There is either a small piece of paper in your paper input section or you have a paper sensor going bad.
Posted on Nov 20, 2009
SOURCE: HP laser jet 3055 document feeder jam
document feeder jam
Posted on Jul 27, 2009
  • 123 Answers
SOURCE: how to solve error is doc. feeder jam in hp laser
Hello Anil_ kuma61!
First thing you need to do will be check the correct postioning of the pick up roller on the automatic document feeder, open up the top cover, you will see a grey roller on the middle, this roller shouldnt be touching the cork a the bottom.
After checking on this, we need to reset the sensors on the printer, to do this follow this steps:
1) Turn the printer off
2) Take out all supplies, including toner and paper
3) With the printer off, press the down arrow and the cancel at the same time (keep the depressed)
4) Turn the printer on while holding those keys and wait until you a message on the display "permanent storage init"
5) release the keys and wait to the printer to come back to ready
Posted on Jul 17, 2010
  • 6 Answers
SOURCE: HP Color laser jet 4700n 49.3048 service error
The problem is usually caused by printing a PDF file with fonts/page size/ page formating errors which will cause the printer to display the 49.3048 error. The only way to use the printer is to POR or recycle the power and delete the print job from the server or spooling device and cancel it on the printer before the offending command is issued to the printer again. You can try updating the firmware to the latest version 46.140.5 from the HP website. MIke L.
Posted on Jul 20, 2010
Our new-to-us Hewlett Packard Laser Jet 4 Plus is mission an owner's manual. After a paper jam, we removed the paper, but don't know how to reset it. any advice? thanks mthubers@netnitco.net
This error message is displayed by the printer when paper is jammed in one or more locations. In such a case, users are recommended to remove the jammed paper from the specified location. The entire paper path must be checked for any pieces of paper. To stop the message, open and close the top most cover of the printer. Lastly, verify the flags and the sensors. If the problem persists, the cause of the error message could be a broken sensor or sensor lever.
Nov 09, 2010 | HP LaserJet 4 plus Printer
Hp laser jet 5200 paper jam in fuser unit
Hp printer paper jam error message is displayed by the printer when paper is jammed in one or more locations. In such a case, users are recommended to remove the jammed paper from the specified location. The entire paper path must be checked for any pieces of paper. To stop the message, open and close the top most cover of the printer. Lastly, verify the flags and the sensors. If the problem persists, the cause of the error message could be a broken sensor or sensor lever.
Aug 25, 2010 | HP LaserJet 5200 Printer
HP Laser Jet 3055 printer-52 scanner error?
Remove the top cover. The laser / unit is a black box.
Try www.partsurfer.hp.com
to purchase one.
Jan 15, 2010 | Office Equipment & Supplies
Laser Jet 4250N Is The jam code B.20.00 paper jam in tray 2..... a service call or can i try to fix it myself?
You should be able to clear this jam yourself
Open the top cover and remove the toner cartridge.
Look inside for jammed paper, and remove it.
Reinstall the toner cartridge and close the lid.
Try that....
Dec 01, 2009 | HP Office Equipment & Supplies
Error 13.10 paer jam in HP laser jet 5100 DTN
HI ayyasamyr:
This your problem.
13.10 PAPER JAM The event log message for a paper-delay jam in the duplexer is 13.10.
1. Check the duplexer and the rear area of the printer for obstructions or damage.
2. Check PS1701 and PS1703 in the duplexer for correct operation. Replace the
duplexer if a sensor is defective.
Hope this helps
May 21, 2009 | HP Office Equipment & Supplies
52.00 error
Hp says you have a bad scanner unit(laser unit) or DC controller, but first reseat all your connectors on your scanner unit(laser) and DC controller. Your scanner is located under the top cover and the DC controller is located behind the right cover. If the problem still persist replace the scanner first.
Apr 23, 2009 | HP LaserJet 4350n Printer
Error symbol
it is a jam after clearing paper from tray you have to open top cover to reset or paper may be under cartridge. gl
May 27, 2008 | HP LaserJet 5p Printer
HP LaserJet 2420 Printer Logo
423 people viewed this question
Seeker5211
Seeker5211
