Question about HP PSC 2210 All-In-One InkJet Printer
Clean inside of printer glass
Want to clean glass on scanner on inside of glass how do i get to it i have a hp psc 2210 all-in-one
  • 2 more comments
  • Anonymous May 31, 2008
  • ek9999 Jun 06, 2008
    want to clean glass on scanner on inside of glass
  • rowbear64 Oct 18, 2008
    Inside of glass is filmy and fogged which affects the quality of my scans. I would like to clean the inside but I am not sure how to disassemble the printer so that I can get to the inside of the glass.
  • Anonymous Oct 22, 2008
    The underside of the glass is dusty and somehow the cable rubbed against it so now all my scans have this stripe down the side.
    Problem Solver:
  • 14 Answers
NOTE: The underneath side of the scanner glass cannot be cleaned on any product. This is unlikely to be necessary and should only be done by an authorized service provider.
This note is found on that website. For an authorized service provider near you: (in Canada)
(in USA)
Posted on Jun 13, 2008
When the scanner head on my hp 2210 reaches the home position over the motor the motor continues to run and causing the gears to slip. is there a limiter switch that tells the motor when to stop?
Open the printer wipe down and clean everything!
The cause of this is dust! there are no switches to let it know it has reached the end it is only based on detection of the edge of that silver tape that's underneath, the detection is obviously done by... scanning! it is the contrast that triggers it
Clean the scanner glass from both sides,
the scanner module face
the silver strip
the white scanner cover/lid (this might be the main issue as the lid turns colour from white to yellow after a while) if the cover is yellowed try placing paper inside when turning it on if it persists try other colours or materials and experiment with it.
and if you still couldnt resolve it then you have probably changed your main board with a low quality one! Let me know about this last part!
Jan 29, 2014 | HP PSC 2210 All-In-One InkJet Printer
2210 making noises right back side,originally said needs relignment,know it says scanner failure
Hello, Tim.
Often, the problem is that the scanner mirror needs to be cleaned.
If you are comfortable, disassemble and clean the scanner equipment. Sticks, glasses and mirrors, all should be accessible.
Some notes:
- Clean everything with glass cleaner
- Check where the white stripe is on the bottom of the glass plate
- Put a mark on the plastic, where this stripe is located, so you know the location of the stripe on the outside as well.
- Enlarge this mark, so it is on the main body as well
- Remove the glass again
- Align the scan head by hand, so that the bottom mirror is exactly on line with your mark
- Put everything back together
- Be careful, don't move the scan unit
- Turn it on when it's complete
If still a problem, the unit needs to be serviced.
Hope this helps.
Oct 29, 2009 | HP PSC 2210 All-In-One InkJet Printer
I have an HP J6480 printer, Fax copier, when I fax or copy a black line is down the center of the sheet. I replaced the toner. How do I fix it?
There is something stuck on the scanner glass. To test for this problem try making a copy by laying your original on the glass and making your copy, not running it through the feeder. If it copies fine from the glass it is definately something in the feeder/scanner glass. Just clean it with a soft cloth and some glass cleaner. You should be lookig for a thin strip of glass to the left of the large glass. Or you might have to open up the feeder unit and find it there.
Oct 16, 2009 | HP PSC 2210 All-In-One InkJet Printer
I don´t know where is located the scanner glass in my hp psc 2110 all in one
The Scanner glass is located on the top of the device under the grey cover (This cover will lift exposing the scanner glass)
May 27, 2009 | HP PSC 2210 All-In-One InkJet Printer
HP 2210 scanner self test problems
If the glass of your scanner is too close to the scanner array it can jam. The cure for this problem is to open the case and put some narrow strips paper under the glass. If under Guarantee take it back.
Doubt if you can bypass the self test.
Mar 06, 2009 | HP PSC 2210 All-In-One InkJet Printer
Won't initialize
You've stripped something out, its a mechanical problem. Probably on the bar that drives the print head.
Aug 03, 2008 | HP PSC 2210 All-In-One InkJet Printer
Re: Printer HP 2210
well darlene maybe you should change the cartriges they might be too old the second option clean the top glass beneath and above so that the scunner might read clearly thomas
Apr 15, 2008 | HP PSC 2210 All-In-One InkJet Printer
PSC 2210 Scanner Doesn't Work
I'm not sure about this specific model, but I've had similar problems with other HP all-in-ones and usually what fixes it is uninstalling and reinstalling the software (make sure to follow their directions properly and not plug the printer in until they tell you to). You should also make sure you're using the most updated software from the HP website rather than the one that came on the CD with the printer which may be outdated.
Jan 05, 2008 | HP PSC 2210 All-In-One InkJet Printer
Have problem with hp psc 2210 scanner.
pls take the machine to a repairs center,it is thier job!save your worries for other troubles
Apr 02, 2007 | HP PSC 2210 All-In-One InkJet Printer
HP PSC 2210 All-In-One InkJet Printer Logo
302 people viewed this question
Ben Johnson
