Question about IBM ThinkPad T30 2366 Notebook
Cooling fan going out. computer now has vertical lines and image on screen shakes all the time. could it be the graphics adapter or video adapter and if so are they build into motherboard. thanks ron email address (beretta 007@aol.com
    Scholar:
  • 65 Answers
Check the motherboard first test it ... den you must have external video display plug it to any monitor and check f it works if not video adpater must be gone bad
Posted on Sep 27, 2010
Laptop screen is flickering and colorful lines vertical and horizontal.
The Graphics Adapter my be bad. Try connecting a external monitor to verify, if the external monitor has the same, it's most likely the Graphics Adapter. Also, a way to verify a Graphics Driver issue is to boot to Safe Mode, the computer uses the generic driver, if you have the same issue, it also points to the Graphics Adapter. Has the Laptop been damaged? Dropped? Jarred? Has the Laptop been overheating? Have you cleaned the fan, vents, heatsink lately? Have you done ALL your Windows and Laptop manufacturer's updates? Any Graphics Updates?
Apr 07, 2013 | Computers & Internet
Tip
Fix colored vertical lines on LCD display.
If your LCD monitor is displaying vertical lines whether they be green, blue,
black, red, yellow, etc then the following info is for you.
When it comes to vertical lines being displayed on the LCD screen it could mean two things; either the monitor itself is faulty or the video card is faulty. In the case that the video card is faulty it could be due to old/outdated/incorrect drivers being installed. For each of these options it's best to have your monitor's or laptop's user manual handy.
Adjusting the resolution
The first thing you'll need to try is adjusting the screen resolution. If you're
unsure on how to do this or want more info about it then see my tip here.
Try setting the resolution lower. If you're using a 4:3(square LCD panel) then your optimal resolutions are: 800x600, 1024x768, 1152x864, 1280x960, 1280x1024, 1400x1050, 1440x1024, 1600x1200. There are some other higher 4:3 resolutions but 4:3 ratio monitors that can support these resolutions are rare.
If you're using a 16:9 or 16:10(wide-screen LCD panel) then your optimal
resolutions are: 1024x640, 1152x720, 1280x720, 1280x720, 7280x800, 1366x768, 1440x900, 1600x900, 1680x1050, 1920x1080, 1920x1200, 2048x1152, 2048x1280, 2560x1440, 2560x1600. There are higher resolutions but they need faster graphics cards and larger LCD panels.
Start at a lower resolution and work your way up until the vertical lines appear. This will help you to find the most stable resolution for your setup. If they are still present even at a lower resolution then we will now try to adjust the refresh rate.
Changing the refresh rate
The next thing we're going to do is try a different refresh rate. Normally the
LCD panel manufacturer specifies the optimal refresh rate for the panel, this information should be printed on the packaging and displayed in the monitor's user manual. If you're unsure on how to do this or want more info about it then see my tip here.
If you've ever used a CRT monitor, you know that fine-tuning your refresh rate is essential. The refresh rate of a display is measured in Hertz (abbreviated Hz) and specifies the number of times per second that a display is illuminated. Setting the refresh rate to 60 Hz - a common default value - tells the monitor to redraw itself 60 times per second. For most people, that setting on a CRT monitor is too slow, resulting in an annoying flicker that can cause headaches, eyestrain, and fatigue. Bumping the refresh rate to a higher number can reduce that flicker, as long as the monitor itself can handle the faster rate. If you're using an LCD monitor then a safe refresh rate lies in the 60Hz-75Hz range. A greater refresh rate when it comes to LCD's means greater performance.
If changing the refresh rate doesn't affect the vertical lines then it may be time to update those video drivers. If you have a graphics card installed in your system then you can go to the various websites to get the latest drivers for them:
If you have an Nvidia card: http://www.nvidia.com/Download/index.aspx?lang=en-us
If you have a ATI/AMD Radeon card: http://support.amd.com/us/gpudownload/Pages/index.aspx
If you aren't using a graphics card and are using onboard graphics or have a laptop then you will need to go to the Pc's motherboard manufacturer's website or laptop manufacturer's download support website. A quick Google search can help you there.
Once you have downloaded and installed the appropriate drivers restart your system and see if the vertical lines are gone. If they are then well done!!! If not then we'll need to diagnose this problem on a physical level.
Try resetting the monitor to factory settings
Most monitors have an on-screen menu that you can use to reset the settings to default. You will have to follow the monitor's user manual procedure to do this.
Check the cabling (For Pc's not applicable to laptops)
Unplug the video cable between the computer and the monitor and check the ends for bent or broken pins. If any pins are damaged, replace the cable. Otherwise make sure the cable is securely connected at both ends namely the computer's graphics card or onboard graphics, and the monitor.
If the monitor has more than one type of connection available such as VGA, DVI, or HDMI, try a different type of connection.
Test out the monitor on another PC
If possible, connect the monitor to another computer. If the lines appear when the monitor is connected to the second computer, the monitor might be damaged or defective. If the lines disappear when the monitor is connected to another computer, connect the monitor to the original computer and check the step again where we updated the video drivers.
Test out another monitor on the system
If you can, try out another monitor on the PC. If there are no lines on the second monitor then it is indeed the first monitor that is faulty. If there are lines on the second monitor then review the section where we updated video drivers.
Where to from here?
If updating the drivers does not correct the problem, the graphics adapter might be damaged. Typically, video cards are damaged by too much heat caused by an accumulation of dust around fan areas. Cleaning the components inside the computer, especially the graphics card area, might correct this problem. You could also swop out the graphics card for one that you know works and see if the problem changes. Faulty or corrupt memory RAM modules can also cause vertical lines and interference; you'd better give these a clean. External intereference can be caused by magnets, check to see if there are maybe magnets nearby your PC (This only affects CRT monitors).
If the mouse cursor shows up fine when you put it on the vertical line, then it's you're video card. green lines are artifacts caused by VRAM or GPU overheating. Try using compressed air to clean your video card to the best of your ability. If by any chance you are using an integrated video solution, clean the northbridge heatsink.
If all these tweaks and troubleshooters fail to change the situation then it may be the fact that your monitor has reached the end of its life span. If it's still in warranty then have it sent back, if not then it may be time to upgrade.
on May 31, 2011 | Computers & Internet
Toshiba screen freezing and turning gray
Do you get the same when you connect to a external monitor? Have you cleaned the dust from fan and vents? Is it overheating? You didn't post the Make, Model or OS you are using? Are your Graphics drivers up to date? Open the Device Manager, Network Adapters, try to update or Roll back the graphics driver. Hopefully the Graphics Adapter is not going.
Mar 08, 2013 | Computers & Internet
The screen when powered ON shows vertical colored lines from top to bottom. what can i do to resolve this?
Problem 1-cause from monitor or graphic card
Either the monitor is going bad or the video card is going bad. If you can get your hands on a spare monitor, try swapping it out and see if the lines are still there. If they are, then the problem is with the video card. You'll want to replace the video card if that is the case.
Solution-
Try restart your pc in safe mode. It will disable vga mode. If you are using pci-e card(external graphic card), try to change using internal graphic card to check wether that problem is cause from graphic memory problem.If your motherboard have internal memory, then you can change using internal memory. If your motherboard dont have it, that you need to buy new external memory.Before that, you can try clean and clear using eraser, to clean dirty at gold contact .
example link to follow.
Problem 2-cause from ram module
Ram modules can also cause vertical lines on a monitor.It's hard to believe but i have experienced it multiple times.The ram is detected by the system,yet the display is corrupt.If you open up the pc and touch the ram modules the lines go away.This is very rare yet a possible cause and easily overlooked.
Solution:
Same like memory graphic. Link
Try clean the dirty. Or if it cause from overheating, try using fan for ram.
Problem 3-overheating in graphic card
The video card could be over heating which causes what you are seeing, lines can also be called "Artifacts". Try opening the side of your case and see if you see these lines. Also, it could be a driver issue, try cleaning out your drivers using Driver Cleaner, and reinstalling the appropriate drivers.
If you have another computer, if the video card is a expansion video card (Meaning you have it in a PCI/AGP/PCI-E slot) try it in another computer to see if the problem persists, if so your card is probably bad and needs to be replaced.
Solution:
For this problem, actually, i try using fan.
 Absolutely is solve the problem. i'm added internal fan, modified it for to cool graphic (PCI-E). fOR THIS CASE, mostly the problem you face is your pc will restart, or suddenly your screen became white. However, you can try.
Problem 4-magnet radiation
Also check to see if there are any magnets near the screen or hard drive.
For this, make your screen like rainbow. and sometimes, it make your screen, showing the line and it also will cause problem with your pixel in screen/ monitor
video in youtube for vertical line solution
May 25, 2011 | LG W2243T-PF Monitor
With my G5 I use a Viewsonic monitor. But often the screen is shaking a lot, and I see a double or triple image of the desk, and I shall switch off the Mac some hours. I dont know if is a screen problem...
From the sound of it, your video card is going bad.
If turning off the computer for several hours fixes the problem temporarily, this points to the video card overheating. By turning the PC off, you are giving the video card time to cool down, thus fixing the issue if only for a brief time.
I would definitely take the PC in for repairs as soon as possible.
Apr 12, 2011 | Apple ATI RADEON 9600 XT for Macintosh G5...
I have a HP LP2065 monitor, and it is currently displaying lines (red, blue and green) vertically on the screen, how do I resolve this problem?
Hello
OK, firstly, this problem can be due to a couple of factors. I will explain it in as much detail as possible.
Internal cracked LCD:
This is the most probable cause for these lines on the screen. Unfortunately this is not something which can be fixed without replacing the whole screen.
Damaged DVI cable:
A faulty DVI connection between the computer and the LCD screen will also cause this symptoms.
Faulty Graphics Adapter:
Lastly, this can be due to a faulty graphics adapter. If you use the on-board adapter, i would suggest that you first test the graphics adapter with another screen. Also, take out the graphics adapter and place it back in, just to make sure that there is not bad connection.
With all of the above explained, i will suggest that you start by testing the system with another screen. If the problem persists, check the connection with another cable.
If all else fails, have a look at the graphics adapter you are using.
Feel free to let me know if you need any further assistance.
Kind regards
Andrea
Nov 12, 2010 | HP LP2065 Monitor
Vertical lines on startup. code 43 Adapter display. 8800GTS win 7
check to see your direct x status by typung dxdiag in run and test if they all pass then I would check the card wattage rating and you max power supply load the card may be to much for your power supply
Feb 02, 2010 | Leadtek GeForceĀ® 8800 GTS, (320 MB) PCI...
Thin vertical line appears on projector
I have found that vertical lines that suddenly appear from projectors are due to poorly connected cables. Sut off your projector and wait for the fan to go off. Then unplug the connectors from the computer to the projector and secure them again, making sure to go all the way. Hope this helps.
Nov 25, 2008 | Office Equipment & Supplies
Vertical lines o my desktop
uninstall video driver reboot it should start on windows basic video drivers if it does and screen is good try reinstalling your original card drivers. or search on the net for updated ones
Jul 20, 2008 | Sis 6326, (4 MB) Graphic Card
Problem
uninstall ALL video drivers reboot computer should reboot with standard windows video drivers does the screen still play up if so you may have faulty video card.let me know please
Jul 17, 2008 | ATI Mobility RADEON Graphic Card
IBM ThinkPad T30 2366 Notebook Logo
Top IBM Computers & Internet Experts
Computer Links
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
