Question about Jandy Aqualink Rs4 One Touch Control System Control System
My aqualink rs4 display reads " service mode," how to I get it back to normal function?
  • 990 Answers
This is set out at your equipment. It will be a button you push three times. It will have LED lights next to it. The first position will just run regular, the second is what you have now so you can control the system out at the equipment. Then the last is a three hour time out and will keep the system running as you left it in service mode. Your pool guy will use this to circulate chemical's after he leaves. I could be wrong but I think this is on the left side of your power center at the equipment.
Posted on Sep 28, 2010
How do I turn off time out function on aqua link RS4
push button below auto service and time out 1 time to put it in auto
Dec 12, 2014 | Jandy Aqualink Rs4 One Touch Control...
Freeze protection on when temperature is 80 degrees
Your air temperature sensor may be broken. Does the display show the correct current air temperature? You can go outside and put the system in service mode. That will shut the pump off. Then you can disconnect the air sensor and see if the pump acts right after putting it back into auto mode.
Mar 19, 2014 | Jandy Aqualink Rs4 One Touch Control...
The inside control display on my Aqualink RS4 is red instead of green on the filter pump button. What does this mean?
either the temp is below 38 degrees if so it is in freeze protect if not 38 degrees or lower bad temp sensor go to system set up and go to program go to freeze protect and un check the filter pump
Feb 16, 2013 | Jandy Aqualink Rs4 One Touch Control...
On my Aqualink RS4 I am getting a read of 8158 Rev K - what does this mean?
shorted wires at plugs of 4 pin connectors or cut wire if ok try to make a cheater cord and see if ok at aqualink if bad a aqualink then bad bezel board
May 19, 2012 | Jandy Aqualink Rs4 One Touch Control...
Aqualink RS4 Water temperature reads 120 - obviously wrong.
No but this sensor is easy to replace. Just pull the sensor from the pipe by loosening the staniless steel clamp that holds it in the pipe. Then follow the wire back into the Aqualink box and unplug. Get a new one at your local store and replace. It's a common problem and you should be able to do it with ease.
May 21, 2010 | Jandy Aqualink Rs4 One Touch Control...
Jandy aqualink rs4: pool has been winterized with the spa left on. when switched from service mode into auto mode system switches back from spa into pool mode (motorized valve switches back to pool mode)....
the only thing you can do since the jandy does not have a "winter" mode is switch the valves off. Once you have the valves in spa mode, there should be a toggle switch on the valve actuators. You can set the switches to the middle position and that will lock them in that position. You will probably have to re-winterize the pool lines.
Nov 14, 2009 | Jandy Aqualink - Rs24 One Touch Pool / Spa...
Jandy Aqualink Rs4 One Touch Control System Control System Logo
1,182 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Pj Kiley
Pj Kiley
Level 1 Expert
Bill Jordan
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
