It sounds like it has a battery problem try this take off the battery and conect the power cord see if it turn on if not unplug everything the battery and the power cord press the power button for 10 seconds after that tey to plug everyhing back as normal and see if it work from now on you might be able to charge your battery and turn on you pc and finally see what you can do about the bootloop by using saafe mode you might need to do a system restore but not available on safe mide if you tuurn it on before select safe mode do this.
To perform a System Restore using Command Prompt:
1. Start your computer in Safe Mode with Command Prompt. During the computer start process, press F8 key on your keyboard multiple times until the Windows Advanced Options menu appears, then select Safe mode with Command Prompt from the list and press ENTER.
. Next, type this line: rstrui.exe and press ENTER.
system restore using command prompt rstrui.exe
4. In the opened window, click 'Next'.
restore system files and settings
5. Select one of the available restore points and click 'Next' (this will restore your computer system to an earlier time and date).
select a restore point
6. In the opened window, click 'Yes'.
run system restore
7. If you are dealing with a ransomware infection, download and scan your PC with recommended malware removal software after restoring your computer to a previous date.
Note that in some cases, System Restore does not eliminate security infections - malicious programs can hide within restore points. After performing a System Restore, scan your computer with legitimate anti-spyware software.
Good luck.
Btw, I’m available to help over the phone in case u need at
https://www.6ya.com/expert/josem_e9ac89730196f220
