How can i restart my print spooler when i get error 3
    Brigadier General:
  • 5,158 Answers
This is for xp but it should work for any windows operating system.
http://www.ehow.com/how_2319117_restart-print-spooler-xp.html
Posted on Sep 27, 2010
Bizhub 222 spooler error
If you received a spooler error,do this
Go to Start / Run and type in "services.msc" without quotation marks, then press Enter or click OK.
In the window that opens (Services) look for "Print Spooler" on the right
Right-click "Print Spooler" and select "Properties".
Click on the "Recovery" tab and change all 3 drop-down boxes to "Restart The Service".
Make sure the 2 text boxes underneath say "1" in them.
Click Ok until you are back at the Services window, close it and you're good to go.
Go back into the properties of the "Print Spooler" tab and be sure to click Start to restart the Print Spooler service and it will restart the service immediately.
The Print spooler depends on the Remote Procedure Call (RPC) service. Is this service disabled? Go to services.msc look for RPC. Check state: Automatic
Oct 13, 2011 | Konica Minolta Bizhub 222 Black and White...
My hp deskjet ink adv2060 K110 not print the spooler service not running?
Hello there Marejen,
See if there is any spooler.exe running in your task manager. Press ctrl, alt + delete to go there. If you see the process, click to highlight then end it. Then restart your computer and the printer itself. Then try to initiate a print again once everything is loaded.
Please let me know if this helps. Thank you for using FixYa.
Aug 02, 2011 | HP Deskjet 2460 InkJet Printer
I cannot print, the service spooler is not running
In run window type services.msc and the go to print spooler option just stop and restart the service.
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Feb 22, 2010 | HP LaserJet 1022 Printer
Microsoft said spooler subsystem app not working
1) Click the Star>Run, type in "Services.msc" in the Run dialog box.
2) A services window popup, find the service name "Print Spooler", double it and change the Service Status to "Start".
Now u can use your printer with your spooler services enable now.
YBC (/\)
Nov 12, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
I have installed hp photosmart and get an error message '' restart print spooler error 1068'' I have tried everything but cannot restart my printer spooler.
go back to your services where you start the print spooler. open the dependency tab. there it will tell you what other services the print spooler needs to have running. check them and if any are disabled change them to auto and restart them. reboot and you should be OK.
Nov 05, 2009 | HP Photosmart 7450 InkJet Printer
Fsm 1608 not scan
Solution I:
Error 1068 'dependency service or group failed to start' :
1. Click Start,
2. Click on System Configuration Utility.
3. This opens the System Configuration Utility.
4. Click the Services tab.
5. Make sure all the following services are turned on. To turn on a service, click to select the check box.
* Application Layer Gateway Service
* Network Connections
* Network Location Awareness (NLA)
* Plug and Play
* Remote Access Auto Connection Manager
* Remote Access Connection Manager
* Remote Procedure Call (RPC)
* Telephony
* LexBce Server (if you have it)
7. Click OK, and then click Restart.
After performing the steps check the functionality of the All-in-One. If the issue persist, perform the below steps.
NOTE: After each step, check whether the issue is resolved. Once the issue is resolved, you may stop troubleshooting.
If the issue persists perform the below steps provided in solution 2.
Solution II:
1. Go to Start > Run and type in services.msc then press Enter.
2. In the window that opens find "Print Spooler" on the right
3. Right-click "Print Spooler" and select "Properties".
4. Click on the "Recovery" tab and change all 3 drop-down boxes to "Restart The Service".
5. Make sure the 2 text boxes underneath say "1" in them.
6. Click Ok until you are back at the Services window, close it and you're good to go.
7. Go back into the properties of the "Print Spooler" tab and be sure to click Start to restart the Print Spooler service and it will restart the service immediately.
Now when ever your Print Spooler craps out, it will automatically reset itself.
Now check the functionality.If the issue persists perform the below steps provided in Solution 3.
Solution III:
Printer Spooler Error 1068:
1. Click on Start--> Run----> type msconfig.msc
2. Go to services tab and startup tab. Make sure that all items that starts with hp should be enabled.
3. On the Run box type services.msc
4. Look for print spooler and stop this service.
5. Open a command prompt windows and type the following:
sc config spooler depend= rpcss
6. Go back to services.msc (item 3) and start print spooler service.
7. Re-installe driver
If the issue still persists perform the steps provided in the below weblink.
Solution IV:
Perform the steps in the below link.
http://www.winhelponline.com/articles/9/1/
Sep 12, 2009 | HP DeskJet F380 All-In-One Printer
"fatal print spooler error" error message
Completely uninstall the printer driver and install again. If this does not work, there is a corruption in the windows registry or in the print spooler cache files.
For a temporary workaround, disable print spooling. But, if you do, you will need to remember to never close an application you print from until printing is actually finished.
Jun 28, 2009 | Konica Minolta magicolor 5430 DL Laser...
Print Spooler not running
follow these steps to correct the issue:
2. In the window that opens find "Print Spooler" on the right 3. Right-click "Print Spooler" and select "Properties". 4. Click on the "Recovery" tab and change all 3 drop-down boxes to "Restart The Service". 5. Make sure the 2 text boxes underneath say "1" in them. 6. Click Ok until you are back at the Services window, close it and you're good to go. 7. Go back into the properties of the "Print Spooler" tab and be sure to click Start to restart the Print Spooler service and it will restart the service immediately. You're all set! Now when ever your Print Spooler craps out, it will automatically reset itself.
Let me know if this helped,
If it did please rate it, if not I'll research it some more
Nov 20, 2008 | HP Color LaserJet 2600n Printer
ok..you'll need a new set of drivers.
take old ones out first(add/remove programs)
go here for new ones..by model number
and re install
May 28, 2008 | Office Equipment & Supplies
PRiNt SP00lER
1. Go to Start > Run and type in services.msc then press Enter. 2. In the window that opens find "Print Spooler" on the right 3. Right-click "Print Spooler" and select "Properties". 4. Click on the "Recovery" tab and change all 3 drop-down boxes to "Restart The Service". 5. Make sure the 2 text boxes underneath say "1" in them. 6. Click Ok until you are back at the Services window, close it and you're good to go. 7. Go back into the properties of the "Print Spooler" tab and be sure to click Start to restart the Print Spooler service and it will restart the service immediately.
Jan 08, 2008 | Dell A960 All-In-One InkJet Printer
Computers & Internet Logo
59 people viewed this question
David Payne
David Payne
