Question about Microsoft Xbox 360 Console
I have an xbox that keeps giving me the 3 red rings and I was wondering if there was a permanent fix for it cause I'm getting sick of fixing it and then 3 months later UH-OH!!!! I SH@$TED ON YOU AGAIN!!!! Thanks in advance.
  • James Krych Sep 28, 2010
    well if it helps any i've already did the x clamp mod when it happened the first time and it is still doing it to me. I don't know what to do anymore, i'll fix it then 3 months later like i said.......
  • 767 Answers
Permanent fix no. But there is a solid repair for the console
provided the board is relatively straight. First is a solid reflow
of the G.P.U. after that you will need to install a hardware up date
Witch is a G.P.U.clamping bracket this bracket will compress the
G.P.U. to the board preventing open connections and will eliminate
G.P.U. errors. Just goggle "Conformail Compression Assmbley"
If you have any questions feel free to ask
Rob
Posted on Sep 27, 2010
Has 3 red blinking lights
Red Ring of Death: Red Flashing XBOX 360 Lights Explained Common Xbox 360 Red Ring Errors The XBOX has a reported 54.2% failure rate which makes the XBOX 360 gaming consoles' worst "lemon" to date. If you find yourself with the red flashing lights error, --> lg.php?category_id=15&content_type=article&content_type_id=2663399&key_page=682482001924178892&site_id=1&bannerid=11791&campaignid=3153&zoneid=23&loc=1&referer=http%3a%2f%2fwww.associatedcontent.com%2farticle%2f2663399%2fred_ring_of_death_red_flashing_xbox.html%3fcontent_type%3darticle%26content_type_id%3d2663399&cb=8da55f49a0 follow this guide to try and pinpoint the problem with your XBOX 360.
1 Red Ring = Serious Hardware Failure
I f your XBOX 360 has a 1 red flashing light error, you're more than likely in big trouble. The 1 flashing red ring of light can be due to GPU or CPU failure, RAM overheating, a DVD drive error, or some serious problem with your Xbox 360's internal components. The most common 1 flashing red ring lights error is the E74 error. The E74 error is no easy fix for the Xbox 360 and usually has to be repaired by the manufacturer [though some have managed to repair it with the heat gun trick - but be careful]
2 Red Rings = Overheating
Mostly all red flashing lights on the Xbox 360 rings are due to overheating in some way or other, but the 2 red rings singles out overheating as the main issue. When doing the X-Clamp fix the 2 red rings are required to fix the Xbox 360 by overheating the CPU. If you get this Xbox 360 error without doing the X-Clamp fix, you probably just need to let your Xbox 360 cool down for a few hours. Make sure that all vents aren't blocked off and that your Xbox fans are working properly in order to repair this problem.
3 Red Rings = Basic Hardware Failure
The most common error on the Xbox 360 is the 3 red rings - also known as the Red Rings of Death (RRoD). This flashing lights problem is the main cause of Xbox 360's 54.2% failure rate. The 3 red flashing lights can be due to lots of different errors but is mainly due to the X-Clamps in your Xbox 360 and overheating. Fortunately, lots of people were able to fix this issue using the X-Clamp and heat gun fix. Follow this list of error codes to find out the real issue with the 3 red rings because there are quite a few of them.
Jan 07, 2011 | Microsoft Xbox 360 Console
My xbox 360 keeps freezing when i put it on then when i turn it off it gets 3 red lights
You have the 3 rings of death. You need to send it to Microsoft. The machine can't be fixed with 3 rings. sorry.
Jan 05, 2010 | Microsoft Xbox 360 Console
My xbox 360 has an red light on and it keeps freezing and wont play any game
if u have 3 red rings that means you can just send it in to microsoft and they will fix it for free and they will fix those other problems for you.
Dec 08, 2009 | Microsoft Xbox 360 Console
How do i fix the x box 360 3 red rings of death
The Xbox 360 e74 error is a rather common problem on Xbox consoles, with similar roots to the now infamous red ring of death problem.
The e74 issue is actually caused by a problem with the scaler (ANA or HANA) chips located next to the graphics processor inside your Xbox 360.
It is believed that the error with the scaler video chip which causes the e74 error on your Xbox 360 is caused by overheating. This is also the cause of other errors such as the no video problem, as well as red lights in the power ring of an Xbox console.
To fix the Xbox 360 e74 code, there are a few steps you need to take-
1. Firstly, leave this article open, go to your Xbox 360 console and then remove the AV cable. Blow any dust out of it, then re-insert it snugly back into the console until a clicking is heard. Power on your console again and see if the problem has been fixed.
2. If that does not work, borrow another AV cable (get one off a friend or family member, or from your local video game rental shop) Try using this one in your Xbox 360.
3. If replacing the AV cable does not work, then you will have to repair the scaler chip and graphics processor inside your Xbox in order to fix the e74 problem. To do this, you will need an Xbox 360 repair guide, which will contain the video instruction files you need to be able to fix your console properly. You cannot fix the e74 yourself without one.
It is important to note that most Xbox repair guides focus on fixing the "red ring of death". However, the process for repairing the e74 will also be covered in the same guide as well, as it is extremely similar.
Aug 30, 2009 | Video Game Consoles & Games
3 red lights appear - XBOX
Your console is most likely in need of repair.
The 3 Red Lights (known as the red ring of death) is caused when the unit overheats, and burns out some integral parts on the motherboard.
Call Microsoft, if your Xbox is less than 3 years old, they'll set you up with an exchange. It'll take 4 weeks, and you'll have to pay for shipping your broken Xbox, but it'll get fixed.
As far as I know, there's no way to permanently repair the Red ring of death yourself.
Apr 10, 2009 | Microsoft Xbox 360 Elite Console
The 3 rings of feath lights on the xbox 360
Okay, chances are you have something wrong with the interior of the 360.
To fix it, follow this guide.
http://www.se7ensins.com/forums/xbox-360-tutorials/92550-permanently-fix-3-red-lights-scar.html
Mar 30, 2009 | Microsoft Xbox 360 Console
Red ring
The Best way to fix a problem like this is to use an XBOX 360 Repair Guide. That's what I did.
You can find a great one here:
www.BestXBOX360RepairGuides.net/?key2=macro
May 21, 2008 | Microsoft Xbox 360 Console
3 red lights
I am afraid that you may have the red ring of death. 3, I believe, is a major hardware failure. What you need to do is look online for the red ring of death and see if it is what your console looks like. If so, call MS and get support. They will send you a box and you will mail your 360 in, and within a month it will be back to normal. I believe this is the only way to fix the red ring of death.
Mar 08, 2008 | Microsoft Xbox 360 Console
3 red lights appear flashing then flashing stops no response help
nothing you can do , unit needs to be sent to microsoft.
Jun 21, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
42 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
