SOURCE: ptac fan keeps blowing
Try setting the fan control to "AUTO" this will cause it to cut out with the compressor.
SOURCE: Amana PTAC
Sounds like if this is a heat pump, maybe it tripped out on high pressure. Maybe just unplugging the system may reset the control boards. This maybe due to a dirty filter or dirty evaporator coil.
SOURCE: Window air conditioner unit frosts over and stops working.
COILS USUALLY FREEZE UP DUE TO INSUFFICIANT AIRFLOW ACROSS THEM. IF THE FILTER IS DIRTY, THEN IT SHOULD BE REPLACED IF IT IS DISPOSABLE, OF CLEANED IF IT IS A PERMANENT ONE. THE ONLY OTHER REASON FOR A FREEZING COIL IS A LOW FREON CHARGE. IF THE UNIT HAS A LEAK, AND IS STILL UNDER WARRANTY, THEN RETURN IT TO THE MANUFACTURER. HOPE THIS HELPS. THANKS FOR AN HONEST RATING AND FOR USING FIX-YA. GOOD LUCK
SOURCE: unit starts and stops to often
No this is not normal. You have a problem refered to as "short cycling". This is an indication of low refrigerant charge. You need to have the unit leak checked, repaired and recharged,
SOURCE: looking for manuel reset on heater amana ptac
I have a Amana PTAC Model PTH153A50AC with the DigiSmart upgrade kit (DSUK01B) which as of last night stoped generating heat. I tried the Diagnostic and got a "LF" displayed. But I find no reference to what LF means. HELP please. Also I looked but can't find a reset button either.
Signed
House without heat
