Question about Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet front load washer is locked up. The light is on for the conrol locked. the washer will not start now. The F2 light had been on and I turned the washer off using the pause cancel mode and then restarted it in the morning. After that the light was on for the "control Locked" and I can't get the washer to response. I have unplugged it but it didn't help. When I plug it back in the light was still onl.
  • 15,935 Answers
This advise is for Kenmore Elite and Whirlpool Duet front loader washers and dryers with a Control Lock problem.
This may or may not be an indication of a serious problem. In the majority of the cases, this is a simple operator error. Nearly all these model appliances have some sort of Control Lock feature on the front panel now. This is a designed safety feature that is used to prevent small children from manipulating the controls. The controls can be easily locked or unlocked by pressing and holding the following button on the front panel:
Whirlpool Duet Washer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Whirlpool Duet Dryer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Kenmore Elite Washer - Press and hold the DRAIN/SPIN button for 3 seconds.
Kenmore Elite Dryer - Press and hold the AUTO DRY LEVEL button for 3 seconds.
These instructions may not be all inclusive for all Kenmore and Whirlpool models, but they are the most common. Chances are, if you have a Control Lock feature, the instructions will be printed on the front panel adjacent to the button that is required to lock or unlock the controls.
NOTE: These instructions may also work for newer model Maytag, Hotpoint, Admiral and Fridgidaire model front loaders as well. Refer to your owner's manual or front panel for instructions pertaining to your sepcific model.
If the Control Lock feature will not lock or unlock the appliance, unplugging the unit for AT LEAST 30 minutes is recommended in order to reset the main control board. In many cases this is all that is required to correct momentary glitches.
"F02" is a Long Drain error. If the drain time exceeds 8 minutes this error code will be displayed. In addition, a "SUDS" error may also be generated as a secondary error. This is an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1. Check the drain hose to make sure it is not kinked or clogged.
2. Check the electrical connections to the pump and ensure the pump is running.
3. Remove the drain pump filter and check for foreign objects and/or debris.
To check the drain pump, click on the following link for step-by-step instructions.
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 30, 2010
Describe your Whirlpool Duet GHW9150P Front Load Washer Problem the control lock button is on
Hello & Welcome to FixYa
This is a common issue with Whirlpool Duet washer however; your whirlpool duet washer needs a reset to resolve the control lock problem. Press and hold the END OF CYCLE/CYCLE SIGNAL button for 15 seconds to reset the control. Please get back to me if you have any other questions.
Kevin
Aug 15, 2011 | Whirlpool Duet GHW9150P Front Load Washer
My washer says that the conroles are locked. How doi fix this?
Put clothes in washer like always and pushed control button to start the cycle. No lights appeared on for any cycle or the digital timer window. The only light that remains on is the "controls locked" in the verticle status row leds on the left side of control panel. The door was closed. I unplugged and re-plugged the machine for possible reset and there is no change.
Feb 17, 2011 | Whirlpool Duet GHW9150P Front Load Washer
My husband stacked my dryer on top of the washer today with the kit purchased with it. Now my washer has the control lock light on, I can't find my instruction book. How do I get the control lock off?
The following link explains how to correct a control lock problem on a front loader washer:
http://www.fixya.com/support/r2469429-kenmore_elite_amp_whirlpool_duet
If this is a Maytag (which is the image you have this posted under) these instructions still may apply. The newer model Maytags are manufactured by Whirlpool (makers of the Kenmore Elite and Whirlpool Duet) and many of the conrol features are the same. I suspect that in the process of mounting the dryer one of the front panel control buttons may have been leaned against and locked the controls.
If you have any questions, please let me know. I hope this resolves your problem.
Jul 23, 2009 | Maytag EPIC MFW9700S Front Load Washer
Reset the 'Conrol Lock' on a Whirpool Duet Washer?
press and hold the end of cycle signal button for 3-5 seconds
Mar 23, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Front Loader
F2=Long Drain If the drain time exceeds 8 mins the water valves are turned off and F02 is displayed
Check drain hose
check pump filter for foreign objects
check pump motor for proper operation
Jul 30, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet Front Loading Washer
go over to the end of cycle button and hold in for 3-4 seconds and you have it fixed
Apr 15, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Help with Model #GHW9400SU0 Whirlpool Duet Front Load Washer
To unlock the controls
Select and hold END OF CYCLE SIGNAL for 3 seconds until the
CONTROL LOCKED status light turns off.
Nov 19, 2007 | Whirlpool GHW9200L Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
184 people viewed this question
Dan Webster
Dan Webster
Sal De
