Question about Canon L120 Fax Laser Printer
When trying to send a fax from a Canon L16-L140 the error message: "Document ready, checking scan error, please press OK" appears. When pressing OK nothing happens. I can receive faxes fine though Please assist
  • 385 Answers
Hey! If the take out the cover that's covering the receiving paper,Look in there and u will see a black lever with a green sticker on it!Make sure its clipped into place by pushing it upwards un till you hear the click sound!Then press ok!!Enjoy! Good Luck!
Posted on Jan 06, 2011
How to fax?
This section describes dialing and sending faxes directly using the Numeric buttons.
note:
  • A PBX (Private Branch Exchange) is an on-site telephone switchboard. If your machine is connected through a PBX or other telephone switching systems, you have to dial the outside line access number first, and then the number of the party you are calling.
Sending a Fax with the Numeric Buttons .
Click here for other useful sending methods.
1. Preparing for sending a fax.(1) Make sure that the power is turned on.
(2) Load a document on the Platen Glass or in the ADF.
important:
  • When sending a double-sided document, set the document on the Platen Glass. You cannot scan double-sided documents from the ADF.
(3) Press the FAX button.
The fax standby screen will appear.
(4) Adjust the density (scan contrast) or image quality (fax resolution) as necessary.
See "Adjusting the Sending Quality"
2. Sending the fax.
  • When the document was loaded on the Platen Glass:
(1) Use the Numeric buttons to dial the recipient's number.
(2) Press the Color button for color sending, or the Black button for black & white sending.
important:
  • Color sending requires that the recipient's fax machine supports color faxing.
(3) Press the OK button.
The machine starts sending the fax.
note: When loading two or more documents
  • Load the next page, and press the same button as you pressed in (2) of step 2. Repeat the same procedure to scan all pages of the document, and press the OK button.
  • When you have sent the first page with the Black button, the following pages will be sent in black and white.
When the document was loaded in the ADF:
The machine scans the document automatically and starts sending the fax.
important:
note:
  • To cancel sending a fax, press the Stop button, and follow the instructions on the LCD.
  • If documents remain in the ADF after pressing the Stop button during scanning, "Close the feeder cover [OK]Eject the document" will appear on the LCD. Press the OK button so that the remaining document is automatically fed out.
Automatic redialing
  • When sending a fax and the recipient's line is busy, the machine will redial the number after a specified interval. Auto redial is enabled by default. Auto redial can be enabled or disabled by selecting ON or OFF. Select ON to specify the number of redialing in Redial times and redialing interval in Redial interval.
Redialing the Number Dialed with the Numeric Buttons
1.Prepare for sending a fax.
(4) Adjust the image density (scan contrast) or quality (fax resolution) as necessary.
2. Select the telephone number recently dialed.
(1) Press the Redial/Pause button.
Most recently dialed fax number using the Numeric buttons will appear.
(2) Use the g0016984.png (-) or g0008875.png (+) button to select the number to redial.
The selected number will appear in the fax standby screen.
3. Send the fax.
important:
Jun 03, 2011 | Canon PIXMA MX340 Wireless Office...
How do you send a Fax?
1 Load the document face up into the Document Tray.
2 Dial the receiving party's fax number.
3 Press [Start/Copy].
The fax begins sending.
Note
If an error occurs during sending, the fax beeps intermittently for a few seconds and an error
message appears on the LCD. If this happens, correct the problem and then press [Stop], then
try sending the document again.
The fax automatically redials if the receiving party does not answer or if the line is busy.
Feb 21, 2011 | Canon FAX-JX200
Hi, I have a Canon i-Sensys L140 Laser Fax machine. Please can you tell me if it is possible to set it up so it prints out a sent message confirmation report each time I send a fax, as this would be very...
Press menu and go to report settings with the arrow right!!Press ok and go to settings,press ok,go to tx report,press set and go to output yes,press set and stop!
Dec 21, 2009 | Canon Office Equipment & Supplies
how it can used as a pc printer??<!-- from fixya rte -->
Nov 23, 2009 | Canon Office Equipment & Supplies
Canon MX330 - trying to use ADF. No doc inside on
Canon Pixma MX330, ADF error, Code : 2,103,0
Here's what I found. There were no stuck gears or pieces of plastic caught anywhere.
The ****** can still feed paper, except for (consistently) the last page -->error/stuck.
1) In order to CLEAR THE ERROR you need to do two things
a) & b):
a) Press OK, WITH THE HOOD OPEN, with a piece of paper loaded in the ADF, being careful to grab the paper manually as it comes out of the bottom of the hood.
b) Windex the strip of glass surface which sits under the ADF next to the platen. This needs to be done with attention to minute detail, and a bright LED flashlight; since ink smudges off of documents and collects on the glass with alarming frequency. The machine may think these smudges are caught/jammed paper.
2) In order to SCAN a stack of paper, add one blank sheet to the bottom of your document. This page will be the one that
fails to clear the ADF, generates an error, and must be manually cleared before the next job.
The rest of your pages will have already scanned.
Repeat Every Time You Use it
Sep 11, 2009 | Canon PIXMA MX310 All-In-One Printer
Can't send faxes. Dials Ok but no connection to send fax
If you are unable to send the faxes, please try decreasing the modem speed and disabling the "Error Correction Mode." To decrease the modem speed, please follow the steps given below:
1. Press the "Fax" button.
2. Press the "Options" button 15 times till it reads "Advanced Fax" on the display.
3. Press the "Select" button.
4. Then press the "Options" button 10 times till it reads "Max Send Speed."
5. Now press the "Right Arrow" button and choose "9600 bps."
6. Press the "Select" button.
To disable "Error Correction," please follow the steps given below:
1. Please press the "Fax" button.
4. Then press the "Options" button 11 times till it reads "Error Correction."
5. Now press the "Right Arrow" button and choose "NO."
May 19, 2009 | Lexmark X4270 All-in-One Multifunction...
Cannot copy or fax - Canon i-sensys L140
CHECK THE ADF
IT IS JAMMED OR NEEDS TO BE REPLACED!
CHEK AGAIN ..EVEN THE TINNEST PIECE OF PAPER CAN JAM IT.
Jun 09, 2008 | Office Equipment & Supplies
Canon MP530 - Fax Memory is Full... How do I clear?
Check your ink cartridges and fill any that may be low. I got that error because one of the cartridges (magenta) needed to be refilled. The printer was storing failure reports in its memory until they could be printed out, leaving no room to fax new documents. As soon as the ink cartridge was replaced, the reports printed and freed up the memory to send out faxes.
Dec 28, 2007 | Canon PIXMA MP530 All-In-One InkJet...
Hi, Remote Fax Error being displayed
As some fax machines are not capable of receiving color faxes, legal size faxes, or faxes at 200x200 dpi resolution, make sure you are sending an A4 or letter size (not legal size) page at standard resolution:
Press the Black button for a black-and-white fax. Press the Quality button to check the selected resolution.
Make sure the All-In-One has enough memory free when you want to save the scanned documents into memory before sending the fax. Please refer to the following document: Click here to link to the relevant document.
Note: The scanned documents will only be saved in the memory before the whole fax is sent if the Scan Before Dial option is turned on. (This is the factory default.) Up to 50 black-and-white fax pages can be stored in memory at standard resolution when there are no pending faxes in the queue.
Turn off the Scan Before Dial option by pressing the following keys on the operator panel:
Press the Fax button, then press Options 15 times to get to ADVANCED FAX mode.
Press Select.
Press Options nine times until SCAN BEFORE DIAL appears on the LCD display.
Change the setting from Yes to No using the + (right arrow) button.
Press Select.
Note: The Scan Before Dial option controls whether a document is scanned before a call is dialed. This parameter only applies to a mono fax that uses either 200x100 or 200x200 resolution. Higher resolution mono faxes and all color faxes are scanned after the call is dialed and the receiving machine's capabilities are known.
Lower the fax transmission speed to 14400 or even 9600 bps, as some older fax machines are not capable of receiving a fax at a high speed. To do so:
Press the Fax button, then press Options 15 times to get to ADVANCED FAX.
Press Select.
Press Options 10 times until MAX SEND SPEED appears on the LCD display.
Change it to 9600 BPS using the - (left arrow) button.
Press Select.
Turn off ECM (Error Correction Mode) by pressing the following keys on the operator panel:
Press Select.
Press Options 11 times until ERROR CORRECTION appears on the LCD display.
Change the setting from On to Off using the + (right arrow) button.
Press Select.
Note: Turning off this option makes it possible to receive a fax when the receiver fax machine does not support certain error correction modes. The X6100 Series only supports 1-D MH encoding with the error correction. Fax transmissions without ECM and other ECM types can result in bad quality on the received page.
Dec 19, 2007 | Lexmark X5470 All-In-One InkJet Printer
NOTE this option may vary to printer try USING OPTIONS TO SET CHANGES
To resolve the problem, try the steps below. After each step, try to send a fax again.
1. As some fax machines are not capable of receiving color faxes, legal size faxes, or faxes at 200x200 dpi resolution, make sure you are sending an A4 or letter size (not legal size) page at standard resolution:
* Press the Black button for a black-and-white fax. Press the Quality button to check the selected resolution.
2. Make sure the All-In-One has enough memory free when you want to save the scanned documents into memory before sending the fax. Please refer to the following document: Click here to link to the relevant document.
3. Turn off the Scan Before Dial option by pressing the following keys on the operator panel:
1. Press the Fax button, then press Options untill u see ADVANCED FAX mode.
2. Press Select.
3. Press Options nine times until SCAN BEFORE DIAL appears on the LCD display.
4. Change the setting from Yes to No using the + (right arrow) button.
5. Press Select.
4. Lower the fax transmission speed 9600 bps, as some older fax machines are not capable of receiving a fax at a high speed. To do so:
1. Press the Fax button, then press Options untill u see ADVANCED FAX.
2. Press Select.
3. Press Options untill u see until MAX SEND SPEED appears on the LCD display.
4. Change it to 9600 BPS using the - (left arrow) button.
5. Press Select.
5. Turn off ECM (Error Correction Mode) by pressing the following keys on the operator panel:
1. Press the Fax button, then press untill u see to get to ADVANCED FAX.
2. Press Select.
3. Press untill u see ERROR CORRECTION appears on the LCD display.
4. Change the setting from On to Off using the + (right arrow) button.
5. Press Select.
Nov 16, 2007 | Lexmark X4270 All-In-One InkJet Printer
Canon L120 Fax Laser Printer Logo
455 people viewed this question
old marine
old marine
