Question about Philips 42PFL5332D 42 in. LCD Television
No Input Signal From My Xbox360 In HDMI or Scart?
I dont have any idea whats wrong with my Tv. the xbox was working fine, then i play it a few times and the screen was kinda pink everywhere And now theres just a message saying "No Input Signal" tried turning it off and on and pretty much everything i can think of. Cant really reset this Tv. i'm going to try leaving it off for a day of so,unplugged so maybe that will solve it. Any ideas or Problems like this????
  • 138 Answers
Connect the xbox to anothe source and make sure the resolution is correct on the Xbox. If so and the set is in warranty contact Philips @1-888-744-5477 and have them take care of the repairs under warranty.
Posted on Aug 20, 2008
I have an old school Curtis mathes TV for my son Xbox 360 can not get right channel no code works any suggestion
The XBOX360 does not connect via any RF channels (TV aerial). It connects through either the analogue video & audio inputs e.g. SCART or PHONO connectors, or via HDMI (which will not be supported on your old TV). If you have connected via the SCART or PHONO type then you can select 'AV' or 'EXT' via the remote to get input from the SCART/PHONO.
Apr 15, 2016 | Curtis Televison & Video
No signal on tv screen
Is it registering the correct input? HDMI/ AV1/ AV2/ SCART!
Nov 05, 2014 | Televison & Video
I can't connect my xbox360 to my sony pfm-42b2 tv
Keep in mind that your Sony IS NOT A TV, but a monitor instead. There is an actual XBOX360 VGA adapter that's available at most gaming retailers. It was initially designed for those who wanted to use their PC monitors for there console gaming. HDMI is NOT compatible with a VGA input as HDMI is a digital signal type and VGA is an analog type connection. You must also remember to have the XBOX set to a NON-progressive resolution (480i) if trying to hook it up using the standard XBOX video cables.
Apr 17, 2012 | Sony Televison & Video
It was working fine yesterday but today the tv screen says no signal! any ideas? i am running it through hdmi cable.
cheack it workes as a standard conection AV/Scart socket first.if this is ok reconnect the hdmi cable Then make shoure you have it on the hd channel not the av channel
May 26, 2010 | Microsoft Xbox 360 Console
MX 3950D Philips - PS3 no sound
Aside from the xbox360 working via the coaxial digital cable. I got the PS3 to work this way.
I had to use the supplied SCART > (Y-video) (Red-Audio) (White-Audio) cable. Basically plugged this in from the PS3 directly to the MX 3950D Aux (Auxiliary) audio input.
On the PS3 audio settings menu, switched from HDMI to the 3rd option SCART.
Turn on the MX 3950D and set to Aux. Bang, got sound again.
I missed this cause I "assumed" the video/audio cable that came with the PS3 was a HDMI to Audio/Video cable, and didn't even see the SCART port in the back of the PS3. So I thought I didn't want to lose 1080p ..etc etc. Anyways. MX 3950D still good =)
May 18, 2009 | Philips MX3950 System
Help with connecting home cinema to xbox
if your tv supports this. go to ebay type in "hdmi" buy one for around $10.00 plug into xbox. set your tv to which port you have ,(if you have more then one). bingo,bango ,your done.
"no hdmi"? and you have com. on your tv. plug corrosponding color plugs for component ,L&R audio plugs .
change tv to comp.( not video) your done
Jan 30, 2009 | Audio Players & Recorders
Sony str-dg820. having a problem getting video on tv
Hook up Composite / Component Monitor Out wire from receiver to TV video input because receiver will not change analog input into HDMI
You need to connect receiver and TV through analog video terminals as above.
Actually you are expecting that receiver will convert DVD player and Xbox analog video input into digital HDMI signal for TV and This is incorrect.
Jan 04, 2009 | Sony STR-DG820 Receiver
HDMI XBOX360 Elite -"No Signal"
The connection order can be a key issue as to whether or not the HDMI signals will pass through the system. For best results the receiver should be turned on first, then the source device(s) and then the display. The reason for this has to do with getting the equipment to handshake properly for the HDCP protocol.
If HDMI video will not pass through your receiver, you may with to just connect the xbox using the component cables. Since component will pass through 720p and your TV is 1080i you should expect the same qualtiy and a more crisp picture.
Oct 12, 2008 | Denon AVR-2307Ci Receiver
PS3 - tv says no signal
You need to change the resolution output on your PS3 to match the capabilities of your TV. If your TV is not HD you can't leave the PS3's video output on HD. SCART is for european television connections. Have you tried using component cables? Have you tried changing your tv's source to Video 1 or Component 1 or HDMI or anything that might work? Good luck!!
Sep 30, 2008 | Sony Playstation 3 (PS3) Console
Philips 42PFL5332D 42 in. LCD Television Logo
768 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
