Question about Health-O-Meter 599kl Health O Meter Digital Scale
Calibration menu for 599kl healthometer - Health-O-Meter 599kl Health O Meter Digital Scale
Tip
SERVCIE MODE
Panel Check
You have to check Panel Maker Because of different adjustments as follows. First of all, Check the label rating!
1) Label Rating File
- LCD PANEL MARK
A:ACER(AUO) S : SEC C : CMO
* If not printed you could consider S(sec) panel mark.
Method of Color Calibration (AV)
1) Apply the NTSC Lattice (N0. 3) pattern signal to the AV IN 1 port
2) Press the Source key to switch to "AV1" mode
3) Enter Service mode
4) Select the "Calibration" menu
5) Select the "AV Calibration" menu.
6) In "AV Calibration Off" status, press the " RIGHT ARROW" key to perform Calibration.
7) When Calibration is complete, it returns to the high-level menu.
8) You can see the change of the "AV Calibration" status from Failure to Success.
Method of Color Calibration (Component)
1) Apply the 720p Lattice (N0. 6) pattern signal to the Component IN 1 port
2) Press the Source key to switch to "Component1" mode
5) Select the "Comp Calibration" menu.
6) In "Comp Calibration Off" status, press the "RIGHT ARROW" key to perform Calibration.
8) You can see the change of the "Comp Calibration" status from Failure to Success.
Method of Color Calibration (PC)
1) Apply the VESA XGA Lattice (N0. 21) pattern signal to the PC IN port
2) Press the Source key to switch to "PC" mode
5) Select the "PC Calibration" menu.
6) In "PC Calibration Off" status, press the "RIGHT ARROW" key to perform Calibration.
8) You can see the change of the "PC Calibration" status from Failure to Success.
Method of Color Calibration (HDMI)
1) Apply the 720p Lattice (N0. 6) pattern signal to the HDMI1/DVI IN port
2) Press the Source key to switch to "HDMI1" mode
5) Select the "HDMI Calibration" menu.
6) In "HDMI Calibration Off" status, press the "RIGHT ARROW" key to perform Calibration.
8) You can see the change of the "HDMI Calibration" status from Failure to Success.
FOR MORE DETAILS CHE THE FOLLOWING LINK
www.electro-medical.blogspot.com
google.com/+AjinGopakumar
USE SEARCH TAB FIND MODELS OR USE DROP DOWN MENU
on Jun 30, 2015 | Samsung LA32A450 32 in. HD-Ready LCD TV
I want to change the time and date on healthometer scale
Google (healthometer)(model)(manual) without parens to get instructions.
Jan 25, 2017 | Healthometer Health & Beauty
Healthometer change kg to lbs
With scales off. Hold select button for approximately 5 seconds, lbs flashes hit select to confirm
Apr 28, 2012 | Sunbeam Healthometer Body Fat and Weight...
I have a healthometer model bfm884dqn-60 and i have already set the height the first time. how do i change it?
Took me a minute or two to figure this out. You hold the number of the user that you want to change (1-4) and then, while holding it down, you press and hold the 'select' button. The screen will blink, and after holding both down for a few seconds, a flashing 'Erase' message will appear. Select YES, and then you can enter new information.
Feb 06, 2010 | Sunbeam Healthometer Body Fat and Weight...
I replaced the printer head but it won't calibrate
Press menu.
Press �� until Calibrate Printer is selected.
Press OK. A new screen appears with Print Calibration Page selected.
Press Start and follow the instructions on the LCD screen to complete the calibration.
If you want to clean them...
Press Menu to display the Main Menu.
Press �� until Clean Printhead is selected.
Press OK to go to the Clean Printhead menu.
Press OK to perform a Basic Clean.
Regards.
Apr 11, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Plotter needs recalibration
You need to enter the service calibrations menu, to do this select the set up menu, once inside the set up menu press the up arrow & enter keys together. This will take you to the service tools menu, from here select service calibrations (printhead alignment and colour calibration are both in this menu). If you still here problems after you have calibrated your machine or the calibration fail replace the printheads.
Oct 16, 2008 | HP DesignJet 500ps (42 in.) InkJet Printer
Health-O-Meter 599kl Health O Meter Digital Scale Logo
61 people viewed this question
Top Health-O-Meter Health & Beauty Experts
Shehu Pro
Shehu Pro
Red721
Level 1 Expert
richie46
Are you a Health-O-Meter Health and Beauty Expert? Answer questions, earn points and help others
