Question about Pioneer PureVision PDP-502 50 in. Plasma Television
Pioneer pdp 502mx goes to standby no picture after power on
Hi, I turn on the main power switch, the fans start to spin, but before i get a picture (within about 7 seconds) i hear a click and the fans shut down, still no picture. and standby light on green flashes every 5 seconds. Red led diagnostics lights in back come on, first D439 then within 5 seconds D407.
what to do?
  • 2 more comments
  • Anonymous Sep 16, 2008
    hi my plasma switched of and the green power light is flashing but no picture
  • Frankrocks Oct 11, 2008
    I have the same problem but the green power light stay on after the TV powers down...Anyone have a solution to this..
    Thanks
  • froggy53 Dec 18, 2008
    my pioneer pdp-502 mx comes on when i plug my video game in but show only darts of graphics i hear sound but no pitcure
  • Anonymous Mar 22, 2014
    Sharp Aquos television, wont stay on. It switches on & the power light goes green, but no picture is displayed & it turns itself off again within seconds
Contact Pioneer at 1-800-421-1404 about getting an in-home power supply replacement. This is a known issue with some plasma displays. Some of you would experience a loud pop and then the power supply fails. You get a red light below the ON button, when you press on, the red light will turn green for a second and then back to red. The plasma display will not turn on after the power supply fails. Call Pioneer at 1-800-421-1404.
Brought to you by http://abstravel.com and http://reservaciones.com
Posted on Mar 29, 2009
    Problem Solver:
  • 5 Answers
I'm not receving any power to my PDP 502 MX and I read that this is due to a power supply failure with our particular models. You might want to contact Pioneer.
http://www.pioneerelectronics.com/PUSA/Support/ci.Important:+Updated+Information+Regarding+Free+Power+Supply+Replacement+for+Certain+Pioneer+Plasmas.Print?format=Print
Hope this helps.
Posted on Jul 20, 2008
    Problem Solver:
  • 13 Answers
I recently purchased one of these at auction for $30.00. I got it home, plugged it in, and had nothing but a green light flashing on the stand-by button.One of the relays was also clicking about every 3-4 seconds. I removed the back panels, and lo and behold, on the power supply there were two blown transistors, as well as a blown ceramic capacitor. Hidden behind the heat sink I also found a blown voltage regulator. Now I did some research, and found this to be a common problem due to the excessive heat generated. I am going to try and rig a small fan on the board to move some of the heat to the exhaust fans. Check your boards for any blown components, typically signified by black residue. Also, be especially aware of any of the small surface mount resistors in the area which may have blown. I will keep you posted as to the progress.One more thing, I have found a great place for electronic components. It is called DIGIKEY, and they have everything. Prices are good too.
Posted on Feb 02, 2010
  • spawn_29210 Aug 30, 2011
    Did you get this model working with your attempted fix? Also, I was given one for free and it does the same thing. I get 4 red glowing lights on start up and the fans click on. Within about three seconds, the fans cut off and I am down to one red light on the main power board showing main drive.
  • Gilbert Gonzalez Dec 12, 2011
    Thank you guys for your responses. I took the back panel off but dont seem to find any blown components. I must say im no repair guy but according to my research blown components are visible. I dont really know what else to look for. I unpluged power source and reconnected with the 8 second rule to attempt to reboot with no luck. Again, the tv clicks like its turning on but I only get a slow blinking Green Light on standby mode. (no red)
PDP-4340HD keeps turning off.
Continuous blinks of standby light indicates a fault in the IIC data bus. The main board is likely to be faulty. If you wish to know more Check this link.
Feb 03, 2013 | Pioneer PureVision PDP-4340HD 43 in....
My pioneer plasma tv in standby mode and wont turn on
Try restting it by unplugging the tv for a few mins and it should rest to original factory default settings but leave it unplugged 10-15 mins to be sure.
Dec 18, 2011 | Pioneer PDP-4270HD 42 in. Plasma...
When power turn on tv goes in to standby mode when you press standby button on the remote control for split second the blue comes on then goes back to standby mode
Hi these pioneers are difficult to work on you are better off taking it to a technician you will save a lot of headaches trying to fix it. If you still want to do it the first thing I would suspect is teh siganl board.
You can get parts for this tv at www.interliquidparts.com
Dec 18, 2011 | Pioneer PDP-4270XD 42 in. HD-Ready Plasma...
PDP 5030 blinking red light on monitor
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Jun 07, 2017 | Pioneer PureVision PDP-5030HD 50 in....
I cant get the fans to turn on!!!!!!!!!!!
Call up the 'Integration Menu" - the fans can be switched between 'auto' and 'full speed'.
To do this switch the display into standby. If the standby light flashes 4 times it is indicating a fault in the Thermal Sensor Assembly which will explain why your fans aren't working. With the display in standby press the menu button and within 3 seconds press the power button. The display will turn on with the integration menu. Select the option tab and scroll down until you see 'fan control' - press 'set' to toggle between 'auto' and 'max'. When you select 'max' the fans will run at full speed within a few seconds. The fans are a bit noisey at full speed so you may want to look into replacing the sensor eventually.
Feb 19, 2009 | Pioneer PureVision PDP-503CMX 50 in....
Loud pop and tv went off...
Here is a solution from the Pioneer web site:
http://www.pioneerelectronics.com/PUSA/Support/Important%3A+Updated+Information+Regarding+Free+Power+Supply+Replacement+for+Certain+Pioneer+Plasmas
Important: Updated Information Regarding Free Power Supply Replacement for Certain Pioneer Plasmas Pioneer is continuing to offer a free, in-home/office power supply replacement for certain of its second and third generation plasma models listed below for customers who experience a problem with the original power supply. If a model is not listed below, no power supply replacement is needed and no further action needs to be taken.
If you own or use a plasma listed below, please call our toll free hotline at 1-800-421-1404 to arrange a time to have your plasma's power supply upgraded at your residence or office at no charge.
Plasma Models (15 listed):
  • PDP-505HD
  • PDP-503PU
  • PDP-5030HD
  • PDP-5031HD
  • PDP-433PU
  • PDP-4300
  • PDP-4310
  • PDP-4330HD
  • PRO-800HD
  • PRO-800HDI
  • PRO-1000HD
  • PRO-1000HDI
  • PDP-433CMX
  • PDP-502MX
  • PDP-503CMX
The issue with the power supply in the plasmas listed above does not pose any health or safety risk. Pioneer has received reports that the power supply in the affected models may fail. In some cases, a loud popping sound can be heard when a power supply fails. After the power supply fails, the plasma is no longer operable.
Anyone with questions can call Pioneer's toll free hotline at 800-421-1404.
We apologize for any inconvenience.
Aug 09, 2008 | Pioneer PureVision Pro-800HD 43 in. Plasma...
Pioneer PDP 502MX
Overload fault in the power supply or a short in one of its load circuits. In some cases, the low voltage (including B+) will just be reduced to a fraction of their normal value as a result of an overload on one of the outputs - usually the main B+.This may be caused by a shorted rectifier in the power supply, flyback, or even the yoke, but check the the loads first.
Jul 20, 2008 | Pioneer PureVision PDP-502 50 in. Plasma...
Pioneer pdp 503
Hi, my PDP 50XE just cut out, when powered back on the screen powers down and the standby light flashes twice followed by a 5 sec gap.  Anyone got any thoughts? Thanks
Jun 28, 2008 | Pioneer PureVision PDP-5030HD 50 in....
Pioneer PureVision PDP-502 50 in. Plasma Television Logo
2,078 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
