Question about IBM ThinkPad R40 Notebook
How can i turn on wireless adapter on the IBM thinkpad R40 laptop.I can't see the wireless adapter switch.......the drivers are already installed successfully.Please HELP!!!!!!!!!!!
    Problem Solver:
  • 12 Answers
The r40 has no hardware switch. it has a software switch. you must first determine what type of wifi card if any is installed. most of the stock cards are intel or cisco and the ibm support site has the software used to control them. sometimes, thru the network connections, windows can take control if the drivers are installed
Posted on Dec 23, 2010
  • Jaramie Brescol Dec 23, 2010
    forgot about using the keys 'Fn F5' also
Where is the wireless switch on my IBM think pad laptop?
the r40 has no hardware switch. it has a software switch. you must first determine what type of wifi card if any is installed. most of the stock cards are intel or cisco and the ibm support site has the software used to control them. sometimes, thru the network connections, windows can take control if the drivers are installed.
Sep 29, 2010 | IBM ThinkPad R40 Notebook
How do I turn on the wireless on an IBM ThinkPad 2628 A20m Thanks in advance
To turn on the wireless on IBM Think Pad 2628 A20m you can try the below options
IBM
IBM General - Some models have the wireless slide button on the side of the laptop.
IBM DV series - use the antenna-like button found on the upper section of your keyboard.
IBM R40 - Use the Fn+F5 key-combo.
IBM Thinkpad (General) - Most have software switch or button on Left hand side.
IBM Thinkpad (model not further identified) wireless switch on Front edge of case.
IBM T43/X32 - Fn+F5 -Click "Turn On"
IBM ZD series use the antenna-like button just below the “Lock” key.
Let me know fi this will help
Dec 04, 2009 | IBM ThinkPad A21m 2628 Notebook
I have a IBM thinkpad R40, i upgrade to xp professional from windows 2000, i have a problem with the LAN which always display no connectivity, i have installed the LAN driver downloaded to the IBM website,...
http://www-307.ibm.com/pc/support/site.wss/MIGR-54046.html
start here,determine witch of the two options you have in yours,intel pro 100 VE network connection or intel pro 1000 lan adapter then download and install according to instructions good luck,aloha from maui todd0708
Oct 22, 2009 | IBM ThinkPad R40 2681
I got problem with installation IBM R40
Go to the IBM/Lenovo WEB site - support/download page and download the latest Windows XP or Vista device drivers for your model computer, Use this link :- http://www.ibm.com/products/finder/us/finders?pg=ddfinder&cm_re=other-_-suprcn-_-download You can download the various drivers and then you click on and run the variour drivers, they will then unzip and expand into a folder on C:\drivers Then install the various drivers from this folder.
Jun 16, 2009 | IBM ThinkPad R40 2722 Notebook
Lost wireless - Ibm thinkpad r40
haha worrying isnt it...
after reinstallation of windows no drivers for blutooth , wireless quite often modem and same vga,
windows by default does not install because need specific software ...(drivers)
what you need to do is first of all find out what wifi it is ; like wlan400 e.g.
you then need to download and install the driver for it .as soon as the driver is present windows will detect and install device,
look in device manager for devices with no drivers intalled.
same precedure for each device.
Jan 24, 2009 | IBM ThinkPad R40 Notebook
Ibm thinkpad r40 windows xp-pro after formatting and re-installing the system, all updates and SPs downloaded and installed, the wireless "disappeared"! the radio led wouldn't lit, in the connection list...
if drivers installed device is looking for wifi manager which is the software package for wifi.
you can goto control panel open administrative tools select sevices and scroll to wireless zero config and press start.
this will then use windows settings.done
Thinkpad r40 - wireless disappeared
Go to the control panel, then System, then Hardware tab, then Device Manager. Then Network adapters - you should have two network adapters one LAN and one wireless.
If most likely have one, the LAN adapter and a yellow ? against a network adapter - this will be a wireless adapter (its not installed)
Check your BIOS and make sure the wireless card is enabled.
You need to download from the IBM/Lenove WEB site the wireless driver (there may be several types that is installed for your model laptop). Make sure you select the correct Windows version driver.
When you run the driver,it will uncompress and copy to your hard drive in C:\drivers. You can then install the driver from this directory. If it doesn't work then repeat with another driver, most likely one that works will be the Intel one.
Ibm thinkpad t42 switch for wireless network
The T42 has a bulit-in wireless network adapter and a LAN network card. T42s most likely have an Intel wireless card or less likely a Cisco wireless card.
Your wireless network adapter may have been disabled in the BIOS
and/or
The drivers for the wireless network controller has not been installed.
To check the network adapter go to the Control Panel, Click on System, click on Hardware Tab then Device Manager. Then scroll down and click on Network adapters. If you don't see your network controller or you see a yellow ? against Other devices for the Network controller. Then either it has been disabled and/or the driver was not installed.
To get the driver for the network controller you need to dowload it from the IBM/Lenovo WEB site their support/download page from a computer that has Internet access. Make sure you select your laptop model and the driver for your Windows version.
Install the driver and you then need to configure the wireless adapter to suit your wireless router settings before you can access the Internet.
Jan 23, 2009 | IBM ThinkPad T42 Notebook
IBM ThinkPad R40 Notebook Logo
438 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
