Question about VXI Corporation Blueparrott B250-XT Bluetooth Headset
Connects but no audio - VXI Corporation Blueparrott B250-XT Bluetooth Headset
I am looking for a solution for this problem
Posted on Oct 06, 2010
How do I change the audio setting to use a digital optical audio cable on model 42LG30
bout 7,180,000 results (0.54 seconds) Search Results
    Xbox Audio Settings ' Connect And Configure Digital Audio ...
    https://support.xbox.com/en-US/xbox.../configure-audio-settings
    XboxConnect your Xbox 360 E console to your HD TV using the HDMI cable. Connect one end of a cable (not included) to the digital audio output port on the television. Connect the other end to the digital audio input port your stereo or home entertainment system.
    PS3™ ' Audio Output Settings
    manuals.playstation.net > Settings > Sound Settings
    These settings are mainly used when the system is connected to audio ... and theaudio device using a digital optical cable and switch to [Optical Digital] under ...
    Enabling the optical digital input for an audio source - Bose
    worldwide.bose.com/.../en_us/...optical.../page.html
    Bose CorporationWhen you use optical cable to connect digital audio from another device to your system, the optical input needs to have the correct source assigned.
    HDMI vs. optical: Which digital-audio connection to use ...
    www.cnet.com > Home Entertainment
    CNETMar 13, 2014 - Both HDMI and optical pass digital audio from one device to another. Both are better ... The cables are cheap, and having just one wire simplifies setup. If you can't, ..... Try changing the decoding on your ps3. You have the ...
    Selecting Audio Settings for a Non-Contour DVR Cable Box
Jan 19, 2016 | LG Televison & Video
How do I connect a Pioneer S508 amplifier to a Samsung Bluray DVD player?
This is a common problem. Not all models of DVD players have analog audio connections.
The image of the back of the DVD is suppose to be a BD5700?
The connections AUX on the amp and the connections audio out red and white RCA connector are connected with a audio cable.
The images marked with the red are these locations
If your model of DVD player does not have a set of red/white audio connectors you have two other choices.
  1. If TV is connected via HDMI that the audio is included to the TV. The TV will likely have a set of red/white audio "out" RCA connectors that would connect into the Pioneer.
  2. Purchase a specific powered adapter that takes the Optical audio signal and converts to a analog RED/White RCA connector that will connect via audio cables into the AUX of the Pioneer,
Dynex Optical Coaxial Digital Audio to Analog Audio Converter Black
Jan 07, 2016 | Samsung BDD5700 BluRay Player
Can I use the Phono audio connection (only RCA connection unused) on my old school Technics SA-GX290 receiver in order to connect to an audio extractor so that I can have stereo sound on my new Roku ?
No you can't. The phono connection will have a built in pre-amp which amplifies the signal from Magnetic Cartridges. If you connect anything else to it, it will either damage the pre-amp or distort the signal of your device.
It's possible to get an audio switching box that can be connected to say a tape audio in jacks and safely connect it that way.
Jan 30, 2015 | RCA Audio Players & Recorders
Attaching reciever to new hd LG tv...best wiring setup for the Technic without buying new
Only connect audio...you do not have a video option available with this unit but the optimal connection is always audio only between TV-receiver.
Connect any RCA cable jack of your choice from the audio out connection on the TV it may be labeled as "variable audio out" or simply "audio out" into the audio left and right channels of the TV section of your receiver. Be sure the channel connections between the receiver and TV match up and power it all on, connecting is finished.
Feb 21, 2012 | Technics SA-AX530 Receiver
Audio out locations on back of tv
Hello
You want to connect your TV with an external audio device, and want to hear sound from it, I assuses, and posts this solution.
There is audio out sockets at the back side of the TV, very near to S-Video socket. Marked audio "L" & "R". These two sockets are audio out socketsfrom TV to connect any external audio amp. Just use an audio cable to connect these sockets, to 'Audio IN' of the amp socket. Switch ON both the devices. You can hear the audio of your TV programmes by the amp you conneccted with.
The picture of the AV cable is given here. Take red and White colourd connections to connect the TV with amp. Left the Yello coloured pins free. It is meant for video. 2_11_2012_3_19_43_pm.jpg
Feb 11, 2012 | Element Electronics FLX3210 32 in. LCD TV
Why? no sound from the speskers at all.
There are a few things that could cause no sound and although some are obvious I'll got through them all..
1) Sound is on Minimum
2) Sound is Muted
3) No Power to Subwoofer
4) Speakers connected Incorrectly or Faulty
5) No AUDIO IN connections to TV-IN or AUX-IN
6) Incorrect Input Source is Selected (See Below)
Connecting audio from TV
When connecting the audio output from your TV to this Home Theater Audio System, you will have the sound of the
TV output on all the speakers. It will enable you to enjoy the multi-channel surround sound capabilities.
Use an audio cable (red/white - not supplied) to connect the TV IN jacks on this DVD system to the AUDIO OUT
jacks on the TV. To listen to the sound, press TV on the remote control as the sound source that you want to play.
Connecting audio from an audio/video device
This DVD system provides analog and digital audio connection. You can connect the audio output from an
audio/video device (e.g. VCR, Cable/Satellite Box) to this Home Theater Audio System in order to enjoy the
Use an audio cable (red/white - not supplied) to connect the AUX IN jacks on this DVD system to the AUDIO OUT
jacks on the connected device. To listen to the sound, press AUX/DI to select "AUX" as the sound source that
you want to play.
Or
Use a coaxial cable (not supplied) to connect the DIGITAL IN jack on this DVD system to the DIGITAL OUT jack on
the connected device. To listen to the sound, press AUX/DI to select "DI" as the sound source that you want to play.
Please leave feedback
Cheers
Andy
Apr 27, 2011 | Philips HTS3450 System
How to connect audio from TV to Hi-Fi for stereo speakers
Most of the TVs are having an analog audio or digital audio output.
However, it is not possible to connect direct speakers to it.
It is required to use an amplifier/receiver to connect the speakers..
You can also connect PC speakers (like 2.1 and 5.1) using a compatible cable as it has built in amplifier.
Please get back to me if you need further assistance. www.fixya.com/users/shajanrs
Jan 17, 2011 | Televison & Video
HOW TO CONNECT FRONT AUDIO PINS
the connector is marked F_audio and it is located directly behind the rear facing audio jacks. should be only one plug either marked "hd audio" OR "ac97 audio". some cases are setup for either, but you only need one of them depending on what your motherboard supports.
11) F_AUDIO (Front Audio Connector)
This connector supports either HD (High Definition) or AC97 front panel audio module. If you wish
to use the front audio function, connect the front panel audio module to this connector. Check the pin
assignments carefully while you connect the front panel audio module. Incorrect connection
between the module and connector will make the audio device unable to work or even damage it.
For optional front panel audio module, please contact your chassis manufacturer.
By default, the audio driver is configured to support HD Audio. To connect an AC97 front panel
audio module to this connector, please refer to the instructions on page 72 about the software
settings.
Pin No. Definition
1 MIC
2 GND
3 MIC Power
4 NC
5 Line Out (R)
6 NC
7 NC
8 No Pin
9 Line Out (L)
10 NC
AC'97 Audio:
Pin No. Definition
1 MIC2_L
2 GND
3 MIC2_R
4 -ACZ_DET
5 LINE2_R
6 FSENSE1
7 FAUDIO_JD
8 No Pin
9 LINE2_L
10 FSENSE2
Mar 27, 2010 | Gigabyte GA-945GM-S2 (0818313003065)...
How to connect dvp 3356 t0 samsung 29 inch tv with crt tube.
Please check the connection. If you are connecting the 3 RCA cables to DVD component input/output, you need another pair of RCA cables to connect to audio out (FL&FR rear of DVD player) and Audio in (L&R) in your TV set. Else connect 3 RCA cable in 1-Video out & 2 Audio out of DVD player and 1-Video in & 2 Audio-in of TV.
Dec 15, 2009 | Philips Televison & Video
No output to Zone 2 from preout to 2nd power amp for second room speakers
OK, From what I am understanding is that you both are trying to uilize a digital audio source (HDMI cables are digital audio only) and hence this is the problem. You can only use an analog audio source (connection) to utilize the audio output to zone 2. A simple soultion is to use the analog audio in conjuction with the digital. Connect the digital (HDMI, Optical, Coax) to the main zone and the left and right audios to zone 2.
Dec 22, 2007 | Denon AVR-3803 Receiver
VXI Corporation Blueparrott B250-XT Bluetooth Headset Logo
103 people viewed this question
Top VXI Corporation Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a VXI Corporation Radio Communication Expert? Answer questions, earn points and help others
