Question about JVC Cameras
LCD viewing monitor fails to display any imageand is blank. Tried to take it apart, and the plastic type film link between the monitor and camera body ripped.
    Brigadier General:
  • 11,967 Answers
That's why there are factory authorized service centers.
Posted on Sep 27, 2010
I have the Canon Rebel T3i and having troubles with the LCD monitor. When I turn the DSLR camera on, the camera works perfectly fine. I can take pictures and the camera itself works perfectly. The...
IT LOOKS LIKE YOUR LCD MONITOR IS NOT WORKING OR THERE MIGHT BE A CONNECTION PROBLEM. EITHER WAY IT REQUIRES A SPECIALIST TO PHYSICALLY CHECK IT OUT. IN THE MEANTIME YOU COULD STILL USE THE VIEW FINDER TO TAKE PICS.
REGARDS.
PLZ. RATE THIS
Jul 04, 2011 | Canon EOS 600D Rebel T3i Digital Camera
The problem i m having with my camcorder is when i want to record film screen goes blank but i can watch my previous recorded videos
Look in the view finder when recording instead of the screen. if you see the image there then the unit is probably set to look through there. Many of the new units dont' have a full view finder to lens item they actually have a small lcd screen inside the view finder. Check your options for recording.
Also if the view finder is tilted you need to close that before usign the lcd.
The image will not appear simultaneously on the LCD
monitor and the viewfinder. It will appear in the
viewfinder when the LCD monitor is in the lock position,
and it will appear on the LCD monitor when fully
extended.
Mar 02, 2011 | JVC GR-DVL820U Mini DV Digital Camcorder
Lcd screen goes on but then goes blank but rest of camera working
If your pictures after shoot are coming out well when downloaded , then it is the LCD display - the monitor to your view - that is faulty as the camera section is intact.
So if this comes on and then blanks out there is a possible chance that the Display is faulty, the driver to the display , possible electrolytic capacitors in the circuit or a wiring link to the LCD.
Remove and check only if confident and experienced but do not tamper a working camera.
Jan 22, 2011 | Fuji Finepix J50 Digital Camera
Model - Sony vaio FZ31Z Problem - The system went blank, and when i tried to restart, it was a blank screen again, i could hear some sound of start but cannot see anything on the moniter. After a few...
Please try to attach an external monitor & see if you can get any display on it. If you can get display on an external monitor, then the root cause of the problems you have might be either a failing LCD backlight or a failing inverter board.
Please refer to the following article for more details on how to diagnose & troubleshoot LCD backlight & inverter board issues:
http://www.fixya.com/support/r6430776-troubleshooting_laptop_power_failures
Dec 07, 2010 | Sony VAIO VGN-AR630E Notebook
The screen goes blank after 1 second display, flicks back again to the display for 1 second and back to blank, this goes on non stop. The little led next to the on/off button goes from green to yellow...
pandres, Your monitor will need troubleshooting to find out reason why the 2 "cold-cathode-fluorescent-lamps" fail to remain lighted. They provide "white light" so you can see what is on the lcd panel. Connect a "known good" monitor to your pc to prove monitor is bad. If pc is ok, then your monitor will need repair. This type problem not new and is very common for all brands of ccfl back-lit lcd monitors. Watch some video clips at YOUTUBE that show disassembly and repair of ccfl lcd monitors. Read fixya profiles of "budmrtn" buddymc" "12fixlouie" for more information. 12fixlouie
Sep 08, 2010 | Neovo S 19 19 in. Flat Panel LCD Monitor
My Monitor will not say on. Keeps turning off or Black screen when i click to do something. I am using my Laptop to ask this question
blorip, You will need to prove that x193w lcd monitor also does same when connected to different "known-good" pc!! Learn how to tell the difference between a "black screen" and a "black n blank screen" with use of a bright flashlight held 1 inch from lcd panel and at different angles. Yes, there is a difference!!! If problem proves not to be PC software, then must be problem with ccfl back-lit lcd display. You should view DIY repair and disassembly video clips at YOUTUBE before attempting to do any repairs to your Acer unit. Read some stuff in my fixya profile( pages 30 and up) for more info and links. Also view fixya profiles of "budmrtn" and "buddymc" . Follow links you find in profiles. Good luck with the repair. 12fixlouie
Jul 26, 2010 | Acer X193W LCD Monitor
Monitor displays for about 2 seconds then screen goes blank. switching monitor of and back does same 2 seconds the blank screen. tried on 2 different computers , problem still persists any clues thanks
The problem can be caused by bad caps (bulging or leaking) in the power supply, bad inverter back light circuits, or worst case will be lamps. Look for bad caps first since it is easy to see, post back what you see inside so we can guide you further, see example of failed monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Most monitors will fail after 2 years.
Feb 22, 2010 | Belinea (101705) (Gray) 17" LCD Monitor
The panel initially displays and then goes blank
johnerm, Good going John! At least YOU tried doing a swapout to another KNOWN GOOD pc to prove out that the E153FP is indeed the culprit!!! Now for the hard part. Do you have a bright flashlight? Reconnect E153FP to pc with WIN-desktop as the displayed image. then and only then turn on E153FP and note the time it takes to GO TO BLACK SCREEN. Is it 1, 2, --5,---20 seconds???? Now point at different angels about 1 inch from screen a bright flashlight to an area that "should" have a desktop "icon" showing. LOOK very closely!! If you SEE a very faint image of the desktop the units "switch-mode-power-supply" is in PARTIAL SHUTDOWN mode. (still has +5v or +3.3v to supply vga/lcd interface board) If you SEE NOTHING, then SMPS is in FULL SHUTDOWN mode. Get back to me, 12fixlouie with your SMPS flashlight evaluation and pay a visit to YOUTUBE fyi search and view video clips of "LCD monitor disassembly" and "LCD monitor repair" to see if DIY interests you! Also try www.ccl-la.com/badcaps.htm run by another tech on fixya nickname "buddymc" fyi. If this was of some help, rate this response on fixya. 12fixlouie aka louie12fix or lmistyrel @ aim.com
Nov 24, 2009 | Dell E153FP 15" LCD Monitor
PC monitor is black unable to view
Most probably your LCD screen has got spoiled and the liquid has leaked making the screen blank. Remember our old calculators, how its display changed colors(black) when pressure was applied on it?.....sodeep
Mar 19, 2009 | Dell Latitude X300 Notebook
Dark screen- No images- some shadows horizontally
If you get a blank LCD, dimly lightened by a whitish back light, then the LCD display eis either faulty, badly connected, or the ribbon connector to LCD is defective.
The camera must be taken apart, ribbon cable tested, and eventually replaced and adjusted.
If all contacts on ribbon cable return continuity (cable is fine), then LCD is faulty, and must be replaced.
Althought the job is not too difficult, an user without experience may damage the camera in attempting this repair.
My first suggestion is always taking the unit to a camera shop.
Aug 23, 2008 | JVC GR-D90U Camcorder
Cameras Logo
49 people viewed this question
Top JVC Cameras Experts
Jax Planet
Jax Planet
juanmireles1
Are you a JVC Camera Expert? Answer questions, earn points and help others
