Question about Canon PIXMA MX700 All-In-One InkJet Printer
We had a paper jam, got the paper out but now it reads error 6A80, we turned the printer off but that has not solved our problem
    Brigadier General:
  • 5,158 Answers
Fix it by moving the print cartridges to the far left, and on the far right there is a little white plastic tab that is spring loaded. i just puched this tab towards the front of the printer and realised it has jammed on me. after doing this i closed the lid and restarted the unit. worked straight away no more issues
Posted on Sep 27, 2010
  • jjm5432 Feb 09, 2011
    I can't seem to get the print cartridge to move to the far left. Any suggestions
    Problem Solver:
  • 10 Answers
  • Switch the printer OFF
  • Press buttons 1 + 2 + 3 and 4 (simultaneously using four fingers)
  • Keep pressing this four buttons for 10 seconds
  • Release the On/Off button (number 4) (Keeping pressing the others)
  • After a few seconds (when the printer go ON), release buttons 1, 2, 3
Posted on Dec 13, 2010
  • Canon Master
  • 17,129 Answers
Remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and connect the Printer to be detected and installed. Check printer properties to see the ink levels.
Use head cleaning before a test is taken . It is possible that the head is not reacting to the need of the command .this resetting must solve the issue, make sure all the paper bits are taken out.
How can I fix error No. 6A80 on my Canon Pixma iP4700
Hi, That error may cause of a paper jam, check your printer if there is blockage and then remove those blockage if no blockage, and the error still appear try to reset your printer.
To reset follow this:
1. Turn off the printer.
2. Pressed simultaneously for 10 seconds on the following buttons:
3. Release the button "On / Off".
4. After a few seconds release the other buttons.
Thank you for using FixYa
Nov 15, 2010 | Canon iP4700 InkJet Photo Printer
Says paper jam, worked fine yesterday but there is no paper even in the machine...
Those errors that deal with paper jams. An error code "6A80" can either represent a sheet feeder error or a debugging unit. This means that there may be scattered bits of paper or other debris trapped inside the unit itself. The potential for this error is high; when the paper is removed from a jammed feeder, bits are prone to fall off and cause this error code. The user must inspect the inside of the printer thoroughly. This error can result from problems with the unit serving or the electronic card; however, the most likely cause is debris caught inside the printer interfering with the printer's operation.
Nov 09, 2010 | Canon PIXMA MX340 Wireless Office...
My cannon printer MX700 just now paper have jam inside. After i taken out of paper that jam inside my cannon printer have a error of 6A80 and it can't fixed. Pls help. Thanks.
The 6A80 indicates that the mechanism called the `purge unit' does not work correctly. In some cases after a paper jam, some paper gets in the unit. Try this:
Turn on the unit and open the cover. Hopefully, the printhead will come to the center. If it doesn't, unplug the printer and try to move the printhead by hand, to the left. Do not force it. If you are able, get a flashlight and inspect the area inside the unit to the right. There may be bits of paper in that area. Being careful, remove it with a tweezers or some such tool.
If you cannot see anything, then the machine will need to be dismantled for service. I recommend authorized service.
Sep 20, 2010 | Canon MX700 Office All-In-One InkJet...
Printer error 6A80 when printer is turned on. No paper jam noted. Tried unplugging, and turning off and on.
6A80
6a90
c000
6C10 feeder unit and / or purge unit defective.
Blocked Zahnrad-/Kupplungs-Verbindung between the two systems / defective.
Troubles with purge pump and or purge tube plugged (clogged). Needs service tech.
Nov 24, 2009 | Canon PIXMA MP620 All-In-One InkJet...
What does 6A60 error message indicate and how do I resolve on my Canon MX700 all in one machine.
6A60 error is an APP (Application Printer) position error. It means that an error has occurred when the motor was running during the purging operation on start up.Check the sheet feeder and purge unit.Sometimes pieces of paper stuck in purge unit.
Thank you!
Nov 02, 2009 | Canon PIXMA MX700 All-In-One InkJet...
How do I re-set error 6A80? on my Canon PIXMA MX700 lcd display?
6A80 is APP position error.First, make sure there is no paper jam anywhere in the machine.. look inside, rear, where the paper tray (output)
is, etc to see if you find any shreds or torn paper that may have gotten stuck and you didn't see.Look carefully in the zone of Purge unit, using flashlight in the right side on printer.Check the sheet feeder.If this not help your printer need service.
Nov 01, 2009 | Canon PIXMA MX700 All-In-One InkJet...
Service Error 6A80
That error says there is something jammed in either the purge assembly or the sheet feeder on the back not able to turn. The purge assembly is on the right where the printhead parks for cleaning.
Oct 29, 2009 | Canon PIXMA MP600 all-In-One InkJet...
My pixma mp630 had a paper jam which I fixed. Now
The error is the APP position error. Uusually caused by foreign object in feed system or Auto sheet feeder. Check for bits of paper in the feed system.
Oct 21, 2009 | Canon PIXMA iP4000 InkJet Photo Printer
Canon PIXMA MX700 All-In-One InkJet Printer Logo
575 people viewed this question
old marine
old marine
