Question about Frigidaire 24.9 cu. ft. Chest Freezer GLFC2528F
It keeps beeping even though it appears to be cooling properly
Ok, upright freezer, frigidaire, read -12 after power outage but working ok..when I tried to reset temp to 0, light went off, freezer went off, front display reads 56..any ideas?
Thank you for your post, Cynthia!
Based off the information you have provided your Frigidaire freezer is not cooling properly and is now displaying the temperature of 56. It sounds like your freezer is not on, even though it has power the compressor is not turned on. I would suggest pressing either the down or up arrow three times within five seconds. That should power on your compressor and it should start cooling properly. I hope this is helpful and if you should need further assistance please feel free to reconnect. -Matt
Feb 28, 2015 | Frigidaire Freezers
Www frigidaire com MY FFHS2313LM6 the temperature is sky high and won't cool down.
Thank you for your post, friend!
I see your Frigidaire refrigerator is not cooling and you have performed a reset on your appliance by unplugging it. You could be experiencing an issue within your control panel or sealed system. I would recommend seeking assistance from a professional to come and diagnose your appliance for the proper repair. Hopefully this is helpful. -Matt
Aug 25, 2014 | Frigidaire FFHS2313LM 22.6 cu. ft. Side By...
Freezer keeps running
Hello David, thank you for your question! Based on the symptoms you are describing, it sounds like the issue may be related to a possible wiring failure between the thermistor and control or the control itself is faulty. At this point, I would recommend having a service technician to diagnose the problem before investing in unnecessary parts.
Aug 29, 2013 | Frigidaire 14.1 cu. ft. Upright Freezer...
Red light showing high tempature
cooling temperature of freezing is damaged and also damaged heater machine which keep in deep freeze but controller point keep in normal side,you must be repair that problem as soon as possible otherwise full freezing system get damaged.
Mar 22, 2013 | Frigidaire Freezers
Commercial freezer stops cooling and goes into delay start mode.
unfortunatly the company has gon out of buisnees and parts available
are kind of hit and miss. As a profesional technician it really frustrating.
I would definitly look at the control side of it. some it could be the relay or digital controller. Good luck hunting the parts down. There are some online parts dealers that still carry some parts. Have your model number
and serial number readily available when ordering.
Jan 17, 2013 | Coldtech 21 cu. ft. / 595 liter Commercial...
My GE freezer stopped cooling. I turned it off,
Hi
I think the problem you are experiencing might be due to the temperature control.
1. Check if the temperature control is off if you dont hear the freezer operating.
2.If you do not see an interior light,when you open the door,then make sure the freezer is properly plugged into an electrical outlet.
3.Move the temperature level to a colder level if the freezer is not cold enough.Warm weather can also be a factor.
4.Find the condenser and check to see if it needs to be cleaned. The condenser is located behind the decorative paneling at the bottom of the freezer.
5.If it doesnt work still then contact a technician.
GOODLUCK
Jul 28, 2010 | GE 16.7 cu. ft. Upright Freezer FUF17DTR
Sub-Zero model 550 does not cool properly
make sure the coils are clean first both coils, then check the r22 freon
Jul 21, 2009 | Freezers
Circulation fans quit running after we shut down the compressor, and won't come back on . even though the fan when pluged direct to out let works.
check the door switches and see if they are engaging when the doors are shut. they are mounted just above each door. If just one is not being pressed in it will keep all of the inside fans off. also there is afan delay mounted by the inside coil that will keep the fans off until the coill cools to a certain set point to prevent recirculating hot air. depending on conditions it may take the fans a good 15 minutes to come on ,or longer in a very hot start up.
Feb 22, 2009 | True 72 cu. ft. / 2039 liter Commercial...
Temp light keeps beeping. Power has not gone off.
I have the same problem.. I turned the temp control on the side back and forth a couple of times, and the light went out. Still don't know how cold it should be inside though??
Feb 01, 2009 | Kenmore 19.7 cu. ft. / 558 liter Chest...
Frigidaire 24.9 cu. ft. Chest Freezer GLFC2528F Logo
Top Frigidaire Freezers Experts
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Dan Webster
Dan Webster
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
