Question about Nintendo Wii Console
HOW DO WE NEED TO SWITCH ON THE WII REMOTE (PLAYER 2)?
  • 219 Answers
When you turn on the system and are at the main screen:
Take the back battery cover off of the remote (make sure it has a usable set of batteries) and you'll see a little red button.
On your wii console next to where you put the disc's in you'll see a long flap that you can open. Open it and at the top you'll see a big red button, push it (hold it in for a second).
Without too much delay, hit the little red button on the back of your wii-mote and give it a minute to sync up
You should be good to go. If not, consider getting another remote because this is the proper way to sync it up.
Respectfully,
Don
Posted on Sep 27, 2010
Wii hand will not show up we tried syncing, taking out batteries, unplugging and plugging sensor bar and nothig works
Synchronizing the Wii Remote with the Wii Console Synchronizing the Wii Remote to a Wii console allows the Wii Remote to communicate with the console. The Wii Remote included with your system should already be synchronized to your console. However, all additional Wii Remotes you use with your system also need to be synced in order to function properly..
There are two different modes of synchronizing (syncing):
  • STANDARD MODE - The Standard Mode procedure is used when adding additional Wii Remotes to your system or if you want to re-synchronize your original Wii Remote. Once synchronized, the Wii Remote will stay synced to the console unless you overwrite the settings by syncing the remote to a different console. For instructions on Standard Mode syncing, please click here.
  • ONE TIME MODE - This mode allows you to temporarily use your remote on a Wii console other than your own, or to use a friend's remote on your console. It can also be used to change the order of the Wii Remotes, without the need to turn off the Wii console. One Time Mode does not delete the Standard Mode setting stored in the Wii Remote. In this mode, the Wii Remote will only communicate with the Wii console while the power is on. When the power is turned off, the Wii Remote will lose its sync with the Wii Console. For instructions on One Time Mode setup, please click here.
Note: Only a Wii Remote in Standard Mode can turn the Wii console power ON or OFF.
    Standard Mode Synchronization
    Note: Make sure you have placed batteries in the Wii Remote (how to).
  1. Press the Power button on the Wii console to turn it on.
  2. Open the SD Card Slot cover on the front of the Wii console. Remove the battery cover on the back of the Wii Remote you wish to sync up.
  3. Press and release the SYNC button just below the batteries on the Wii Remote; the Player LED will blink. Quickly press and release the SYNC button on the inside of the SD Card compartment on the console.
  4. When the Player LED blinking stops, the syncing is complete. The LED that is illuminated indicates the player number (1 through 4).
  5. wiiremotesynchstandard.gifThis procedure must be followed for each additional Wii Remote added to your system.
    Go to the Next Step (Playing Game Discs) >
    One Time Mode SynchronizationNote: This mode temporarily removes Standard Mode synchronization setup for all Wii Remotes until the power of the Wii console is turned off. When the power is turned back on again, the Standard Mode settings will return.
  1. Press the HOME Button on a Wii Remote that is synchronized with the Wii console.
  3. Select the Wii Remote Settings option from the Home Button menu.
  5. Select the Reconnect Option.
  7. Press the 1 and 2 Buttons at the same time on the Wii Remote that you want to synchronize with the console. If you are syncing multiple Wii Remotes, press the 1 and 2 Buttons on each Wii Remote immediately (without a significant pause) in the order you want them synced. The order in which you synchronize Wii Remotes determines the player order (1 through 4) for multiplayer games. The Player LED will blink during the syncing process. When the blinking stops, the connection is complete.
Jan 27, 2011 | Nintendo Wii Console
Player 2's remote won't work when the dancing starts, but it will work for everything else. Player 2's motions are not being registered and won't count for points. Then the player 2 disappears (because it...
We had the same problem: IF YOU OPEN THE BACK COVER ON YOUR WII REMOTE THERE IS GOING TO BE a red button and some where on the WII too so you press that at the same time and your done
Dec 26, 2010 | Ubi Soft Just Dance 2 for Nintendo Wii
LEGO Batman: Player 2 remote unresponsive in 2-player mode
It's probably because you have two diferent brand remotes and the wii doesnt know which one your using
Jul 01, 2010 | Nintendo LEGO Batman The Videogame for ...
How do i set up a second wii remote to my wii console
  3. Press and release the SYNC button on the inside of the SD Card compartment on the console. Press and release the SYNC button just below the batteries on the Wii Remote.
Hope this helps!
Feb 02, 2010 | Nintendo Wii Console
My wii counsel turns on fine, my remotes are with new batteries and flash when pressed the red light, but yhe remotes don't seem to be able to connect to the screen?
if your Wii Remote is not responding It may need to be synced up. I have given you both ways of syncing your Wii. After doing this Please don't forget to rate me as " Very Helpful" & feedback is appreciated - thanks
  • STANDARD MODE - The Standard Mode procedure is used when adding additional Wii Remotes to your system or if you want to re-synchronize your original Wii Remote. Once synchronized, the Wii Remote will stay synced to the console unless you overwrite the settings by syncing the remote to a different console. For instructions on Standard Mode syncing, please read below.
Standard Mode SynchronizationNote: Make sure you have placed batteries in the Wii Remote
Sep 22, 2009 | Nintendo Wii Console
I lost my player 1 wii remote my others don't work.what do i do
open the battery cover on the wii remote you want to make player 1 press the red button while it is facing the sensor bar. Then open the memory card door on the front of the wii and press the red button on the top. the remote should flash a few times then it will be your new player 1 remote. You can only do this if you have 2 AA batteries in the remote. It will not work with the rechatgeable batterie packs because the remote must have power while you re-synch it.
Jun 10, 2009 | Nintendo Wii Console
I bought a second wii remote it is fully charged but it flashes several blue lights then switches itself off! please help
wen you go to play a muliplayer game and the second remote won't turn on automatically wen a button is pressed then with the player one remote go onto the wii menu then go onto wii remote settings ( at the bottom of the screen) then click on reconnect press 1 and 2 at the same time on the player one remote after a while it will turn on the do the same thing with the player 2 remote and it should turn on afer a few seconds
hope that helps =]
Apr 23, 2009 | Nintendo Wii Remote Controller
I feel really dumb...can I get help, please?
my player 2 remote doesn't work properly. My player 2 remote doesn't respond when player 2 is up to bat on wii sports and when pitching, player 2 throws without command and the e golf, ya know none of the sports games are working properly for the number 2 player. What in the hell do I do!?
Jul 14, 2008 | Nintendo Wii Console
Can't play with 2 players
Make sure you have paired both remotes to your Wii console.
Open the little door on the front of the Wii (under the disc slot), and open the battery cover of the Wii remote (but leave the batteries in).
Push the red button on the Wii (next to the SD card slot), then push the red button on the Wii remote (next to the batteries). You should see the Wii remote's lights blink.
Do the same for your other Wii remote.
Now on the bottom row of 4 lights on the Wii remote, one should have the first light lit, and the other should have the second light lit. You should also be able to see a cursor for each remote on the Wii Menu.
Apr 03, 2008 | Nintendo Wii Console
Nintendo Wii Console Logo
18 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
