Question about Microwave Ovens
I have a Nespresso KRUPS XN2100 ESSENZA FLOW STOP PIANO BLACK. The green lights keep flashing rapidly. I've tried to restore factory settings by holding "full cup" and switching on, but it doesn't rectify the problem. Please help!
3 Suggested Answers
  • 11800 Answers
SOURCE: When our Nespresso is turned
The indicators flash while the unit heats up the water to steam and builds the pressure - they should stop when the optimal pressure is reached. If they don't stop then that pressure is never reached, which means that either the heater or the steamer are malfunctioning.
This is a mechanical failure that you can't repair yourself, you will have to take it to an certified repair shop or a dealer to have it fixed. I'm sorry to tell you but it will be expensive, so ask an estimate before accepting the repair, you might find out that it will be more cost effective to get a new unit.
Posted on Feb 25, 2011
  • 1833 Answers
SOURCE: When powered up get red
If this is your coffee maker machine, then follow these: Turn the hot water nozzle on for 45 seconds and then check.The water is getting clogged. Try to run out hot water through it and see ifthe clog is getting cleared. But if that is not helping, then I think"water turbine" also called flow meter is broken and has to bereplaced. Check your water flow meter. Check the turbine is not scaled orclogged. If the draining is not helping then yes it's a turbineissue. Hope this will help you. Good Luck.
Posted on Jul 19, 2011
How do i fix keypad
Keypads will flash when new oven or when disconnected and setting are lost. First try setting the clock
  • push CLOCK--enter numbers--push CLOCK to see if keypad becomes operational.
If not, unplug, replug and try again. As for "fixing" keypad ....that is not likely to be the problem and even it it were, keypads are not user repairable. For further info, dial the the factory customer support phone number.
Mar 14, 2015 | Microwave Ovens
Door Open light flashes and relay clicks rapidly
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If it still fails, please post a new help request with the full model number from the tag in or on the unit.
Apr 29, 2013 | Whirlpool WMH1163XVS Microwave Oven
KithenAid model KUDSo1DL wont operate, clean green light flashes non stop
This is a issue with the way the water is moving & or heating in the unit. There should be a tech mini manual behind the motor kick panel. The manual describs the failure and it's correction. Depending the the model year & run / revision code, this error could be caused by low water level, a bad thermistor, the control board not sensing inputs, bad heater or door interlock switch issues. attached is a couple of help sheets. They are general in scope.
Mar 27, 2012 | KitchenAid Microwave Ovens
Lost directions - how to descale keurig ?
Hello, Here is a tip i wrote, see if this helps you.
Have you ever wondered, 'how do I descale my expresso machine?' First lets us understand what is exactly is scaling. The build up of minerals inside the hot parts of your coffee machine or espresso machine is commonly called lime scale. When lime scale builds up inside the Espresso machine, it slows down the water flow, reduces the boiler capacity and can prevent your coffee machine from working properly. To keep your Espresso machine operational at full order, it is important to descale it every three months. The time intervals between descaling depend upon many factors. Quality of your water and the amount of water running through the machine are the two main factors that decide the frequency at which you should descale your Espresso machine. The more you your machine, more often should you descale it. In some cities, in conjunction with a water filter you can use your coffee machine for a year or more without descaling at all. If you use less water by drinking espressos you'll need to descale less often than if you make cappuccinos.
Descaling products are widely available from stores that sell coffeemakers and espresso machines. Be sure that the product you buy to descale your Espresso machine is intended for this specific use only. Before you descale your Espresso machine, always unplug it and make sure that it is cold. Also, never immerse the appliance in water and nor should you use abrasive cleaning products or scouring materials on any part of your Expresso machine. In case your Espresso machine does not come with a instruction guide or booklet, then use a proper citric acid based descaling solution designed for espresso machines. This should be mixed and prepared as per the instructions on the bottle or packet. Once your Espresso machine has been descaled properly you would not be left wondering, 'how do I descale my expresso machine?', treat yourself to a great cup of coffee. Some popular models of Espresso machines are Krups EA8080 Espresseria Automatic, DeLonghi Magnifica EAM3200S, Krups Nespresso CitiZ & Milk XN 7106 Fire-engine red, DeLonghi Perfecta ESAM5400, DeLonghi PrimaDonna ESAM6600, DeLonghi Magnifica ESAM4200S, DeLonghi Perfecta ESAM5500 and Magimix Nespresso Citiz M190.
Jun 29, 2011 | Microwave Ovens
What does it mean to descale my tassimo? the yellow light is on and the screen keeps saying "descale". thanks
In order to keep your Tassimo machine operational at full order, it is important to descale it every three months. Descaling products are widely available from stores that sell coffeemakers and espresso machines. Be sure that the product you buy to descale your Tassimo machine is intended for this specific use only. Mix the descaling product directly in the water container, following the instructions provided on the descaling packaging. Then replace the water container on the machine. Place a large cup or mug on the cup stand, insert the cleaning disc, bar code down and close the brew mechanism. As soon as the AUTO light illuminates, press and release the start/stop button. This will fill the brew cycle with descaling solution. Empty the cup and let the machine stand for 15 minutes. Then open the brew mechanism and close it again, leaving the cleaning disc in place. Repeat this step two more times for maximum descaling effectiveness.
Discard the remaining descaling agent from the water container, rinse it well and refill with fresh, cold water. Clean the machine by flushing water through it in the same manner and emptying the cup as it fills. Make sure that all the descaling solution has been completely rinsed away, and then flush two full water containers through the machine before using it again. Remove the cleaning disc, rinse and refill the water container and your Tassimo machine is ready to use. Also, before you descale your Tassimo machine, always unplug it. Also, never immerse the appliance in water and nor should you use abrasive cleaning products or scouring materials on any part of your Tassimo machine. This method works for most espresso machines, including some of these popular models: the DeLonghi Magnifica EAM3200S, DeLonghi Magnifica ESAM4200S, DeLonghi Perfecta ESAM5400, Gaggia 74507BCN Classic, Krups EA8080 Espresseria Automatic, DeLonghi PrimaDonna ESAM6600, the BC0255 DeLonghi coffee machine and the Krups Nespresso CititZ XN 7006.
May 16, 2011 | Microwave Ovens
I have a Shapr Microwave Convection model R-8880(W) T which is flashing after being stored for 3 months. It won't work, the timing light just keeps flashing on andoff 88-888. Does it have a reset...
Try pushing / stop reset first. The setting the time by pushing clock button .... punch in the time and push the clock button again. Just respond here if that does not work. 88-8888 is what you get after your first plug it in. Sometimes you will get PF if you unplug it and plug it back in. If that appears push stop / reset / clear. (Same button)
Kelly
Dec 26, 2010 | Sharp Microwave Ovens
I have the west bend 56870 the prgramable coffee pot and I never got a manual with it and I have no idea what the red light or yellow light is or even how it works send me instructions and itll be well...
Customarilym RED represents there is power and the ubit is on. Yellow/amber would indicate ubit is preheating the water in the resevoir and once heated properly, a green light should appear. Check all around the unit for a master on/off switch. Make sure it is on. Now, The timer is your actual start/stop controls. It should start at the time you set for brew and shut off at a predetermined time so it's not left to burn dry.. Sometimes, or more often than not this off setting is regulated by a temp sensor or timer factory set. I don't have a manual so I hope this helps. Remember, the setting you make is the setting it starts doing anything. Good Luck. I'm sure yoou will appreciate it once you get it to fire up. -Ned_
Nov 16, 2010 | Microwave Ovens
I need a users manual to Krups Nespresso Household Expresso Maker Typw 995.
hi here is a link that will have your user manual on the site hope this helps please vote and rate thanks, just click link and input your details
http://www.krupsusa.com/Consumer+Services/Product+Support/Manuals/Use+Intructions.htm
Aug 23, 2010 | Microwave Ovens
Microwave Ovens Logo
422 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
