Question about Olympus FE-140 Digital Camera
Cannot be turned on by power button,turns on with view pic button. Lens remain extended. Its just stuck in view pics mode
  • catherine Derry Jun 12, 2008
    Exactly the same problem - only used the camera twice but got it as a present so can't return it as faulty.
    Exactly the same problem - lens sounds like it is trying to close but is jammed. Brand new camera but it was a present so i cannot return it to the retailer!
  • 20 Answers
If these cameras are less than a year old then they are still under warranty, and Olympus repair shops( found on their website) will repair them for free minus shipping charges. The lenses probably have broken gears or have just been pushed out of alignment and can be repaired by someone mechanically inclined and very gentle with components. Can find good used and or possibly new lenses on ebay. Not that hard to replace.
Posted on Jun 15, 2008
I have a casio digital camera qv-r52 3x optical zoom when I turn power button on it will not stay on the lens retracts but I can view the pic's on the dish
Katie, Joe alerted me to your problem. The symptoms that you're experiencing suggest that you're experiencing a lens error. Lens errors are fairly common, but there are many causes. Some causes include poor or drained batteries. Or sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...Here are some troubleshooting steps that you can try that may (or may not) correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try. Some of the later steps do involve some risk to the camera, so carefully weigh your options before deciding to conduct them:
Nov 16, 2011 | Casio Cameras
CAnnon Powershot A630 LCD screen will not light up when trying to take a pic. I can, however view old pics that I've already taken.
First press the DISP or DISPLAY button to see if that corrects the problem. If not, a stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Nov 09, 2011 | Canon PowerShot A630 Digital Camera
When turned on just shows black screen. Used to be able to pwer off and back on and would work. Lens issue? Can view pics on memory card just can't take pics anymore.
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Oct 14, 2011 | Canon PowerShot S2 IS Digital Camera
When I switch on the lens goes in and out a few times but no viewing screen. It asks to be switched off and then on. I can view stored pics but it won't allow me to take any?
Error: TURN THE POWER OFF AND ON AGAIN is displayed on the LCD screen when the Lens Mechanism is stuck or when affected by any malfunction. If turning the power on and off again does not resolve the error message, try doing a power reset and Initialize option.
Performing a manual power reset
· Turn off the camera.
· Remove the battery pack.
· Press and hold the power button for 30 seconds.
· Allow the camera to remain without power for 60 seconds.
· Reinsert the battery pack.
· Turn on the camera.
To reset the Camera back to factory default, select the INITIALIZE Option from the SET UP1 Menu of the Camera to OK.This will set the user defined settings back to factory default. The images and videos will not get deleted.
If the issue persists, service may be required.
Thanks,
KenSolutions
FixYa
Oct 21, 2010 | Sony Cyber-shot DSC-W55 Digital Camera
Canon elph 880 can display pic's but can't take a pic,,,,screen remains black and new pics are black
Aug 01, 2010 | Canon PowerShot SD880 IS / Digital IXUS...
Turn camera off and on again -- fried in outlet
Turn on the camera.
To reset the Camera back to factory default, select the INITIALIZE Option from the Main Settings 1 Menu of the Camera to OK. This will set the user defined settings back to factory default. The images and videos will not get deleted.
Thanks for contacting FixYa.
May 22, 2010 | Sony Cyber-shot DSC-W120 Digital Camera
Lens wont retract or extend when pushing the power button and cannot take photos. power will not remain on.
Can you turn the camera on by pressing the playback button? This should turn the camera on to view pictures on the card without opening the lens.
Check the tab on the battery door. it should activate a micro switch next to the card slot on the main board. If this is damaged then the camera will not power up.
If the lens is stuck then this will also prevent power up
Nov 15, 2009 | Fuji FinePix E900 Zoom Digital Camera
Lens Errors 17 & 27 on Sanyo VPC-E760
My camera was showing lens error 12&25 and then shutting off. I tried gently trying to twist and pull the furthest out part of the lens and it popped back into place easily. It made a noise when it did this, and then i turned the camera off, and the lens went back in!! Completely fixed now!!
Aug 03, 2008 | Sanyo VPC-E760 Digital Camera
Les extended, screen remains black
tuen on camera then press display a few times. it sounds like the display is just turned off. the lens system should be open.
Jan 03, 2008 | Pentax Optio S50 Digital Camera
Can view memory card but wont power up to take pics
Try using brand new fully charged rechargeable batteries like NiMH or NiCd. Also try viewing though the computer via USB.
Sep 17, 2006 | Olympus Camedia Stylus 300 Digital Camera
Olympus FE-140 Digital Camera Logo
67 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
