Question about Whirlpool LER5636P Electric Dryer
Hot air coming in but not drying Model LE6800XTWO
Just recently, we noticed that when we turn the dryer on, the hot air is blowing in it, but after the whole cycle finishes, the clothes are still wet. We cleaned the filter. My husband moved the dryer and looked at the tube. He removed the tube and noticed that not much air is coming out to the back of the dryer when the dryer is running, and his perception is that much more air came out of the dryer in the past, when it is working properly. Anyway, we feel heat in the dryer, but it does not dry the clothes. Can you help? Thanks.
  • mrbarbermusi Mar 01, 2009
    Hot air does not vent out. I thought I cleaned all lint out of channel behind filter screen.
  • 5,911 Answers
Sounds like you have a clod inside your dryer that may be preventing the blower fan from cycling air properly. When was the last time you inspected the dryer vent and/or inside the dryer for lint? The symptom sounds like you could have a couple of possible issues. The dryer may have restricted air flow (Meaning, the vent hose is clogged from where it leaves the dryer to the vent outside. Or...the dryer may be clogged inside the air baffle inside the dryer where the lint screen goes.) You may also have a high limit thermostat that is malfunctioning or a blower fan not working properly. Here's some recommendations:
1. Remove the dryer vent hose from the dryer and turn the dryer on. Is the air leaving the dryer forceful and warm? (The air should measure about 140 degrees F) If so...you probably have a clog or kink in the ducting somewhere between the dryer and where it exits the house. If the air is weak and cool, you will need to inspect your dryer interior to find what is obstructing the air flow. Rodents are notorious for building nests inside the vent line or air baffle. Check the air blower fan to see if it is rotating. If enough lint is allowed to build up, it can obstruct the rotation of the blower fan. It some cases, the fan can shear off on the motor shaft and must be replaced.
2. Can you access the heating element so you can see it? Start the dryer with the casing removed so you can watch the heating element. The element should glow red, but not so bright that it glows like the sun, and it should cycle on and off. If it glows continuously, the high limit thermostat is a likely suspect and should be replaced. (NOTE: It is recommended that you replace the high limit thermostat and thermal cut-out at the same time. Some manufacturers will sell the two as a pair).
HINTS: If you have a lint screen in the door, you should be able to access the heating element by removing a panel under the door. If your lint screen is on top of the washer, you will have to remove the rear panel of the dryer to see the heating element.
If the dryer is left to run in an overheated or clogged condition, the thermal cut-out and/or heating element will eventually blow. It is recommended that you inspect the dryer to see what is causing your current problem. You should inspect the dryer ducting and exhaust about once per season and keep it cleaned. Clogged dryers are a hazard and can contribute to house fires.
CAUTION: Always unplug the dryer if you are servicing the inside of the unit. Dangerous voltages are present even with the unit turned off. Also, unplug the dryer if you have to remove the rear panel. The 220VAC terminal is directly behind the panel and can cause electric shock if touched.
I hope this information helps you and post back if you need any further assistance.
PS Improper sorting of laundry can also attribute to longer dry times. Try not to dry dense or heavy items (i.e., towels and jeans) with lighter items like cottons and linens. More dense material holds moisture longer and can transfer this moisture to other articles you are attempting to dry.
Posted on May 24, 2008
I recently had a water leak in the crawl space of my house. It is being dried out with several fans,and a dragon, blowing hot air under the hose. This will continue to go on for another week. Now I&#
Very likely.
Here's why.
Because of the real danger of overheating and fire, dryers are "loaded" with overheat switches which will shut thr dryer off if they get hot.
One reason is that lint catches fire so easily.
Here's hoping you problem will resolve soon!
Be blessed
Jan 27, 2013 | Kenmore Dryers
GTDX100EM1WW GE Electric Dryer smells hot and electric cord is very hot Problem not present on air dry. Vent is connected and air blows through. Cord is quite hot to touch at the outlet.
Usually the motor, if you're not experienced, better to have a service person come out. Almost always the motor in the dryer that causes this
Oct 10, 2011 | Dryers
It doesnt want to blow hot air
It could be several things the heating element , thermal cut out, thermal fuse. Most of these parts are very inexpensive and all are easy to replace. There is a video at http://appliancehelponline.com/edryerelementvideo.html that can walk you thru the troubleshooting of your problem. It may be a different model but the troubleshooting will be the same. You can also get diagrams and illustrations of your specific model by entering your model #. All parts come with installation instructions. Not all models are available. If you need help disassembling your machine there are videos of this also for most styles. This tutorial should be very similar to your model
http://appliancehelponline.com/electricdryertroubleshoot.html
Jun 07, 2010 | Frigidaire Electric Dryer
Dyer really hot, not drying clothes
Is the dryer tumbling? If not, you may have a broken belt or some other drive assembly issue.
Also, turn the dryer on and go outside to the vent discharge - you should feel air coming out at a pretty good clip. If not, the vent line is obstructed and will need to be cleaned out.
Jan 07, 2010 | Dryers
No longer blows hot air, only cold air
when a dryer does'ny blow hot air,it's normally either the element or the stats on the element.
Nov 01, 2009 | Dryers
Our dryer does not blow hot air? The cloths do not
more than likely the heating element has gone out. if your clothes have no heat then the element is the most likely cause. you can get one for anywhere between $30 - $50. you'll need to know model and serial #'s. usually easy to replace.
Jul 30, 2009 | Estate Dryers
Maytag electric dryer model mde308dayw not heeting up
CHECK YOUR WALL VENT AND DRYER VENT AND MAKE SURE THEY ARE CLEAR,ALOT OF THE TIME IF BLOCK THEY HOLD THE DAMP HOT AIR IN THE DRYER AND WILL TAKE FOREVER TO DRY,IF NOT THAT IT CAN ONLY BE YOUR HEATER BOX OR HEATER BOX FUSE,IF YOU HAVE A METER YOU CAN CHECK BOTH,LET ME KNOW-MIKE
Dec 06, 2008 | Dryers
Dryer
Disconnect the vent from the back of the dryer and dry a load unvented too make sure you don't have lint built up in the vent line causing an air flow restriction.
Jul 30, 2008 | Kenmore Dryers
Dryer doesn't dry
no but are you sure your replacement parts are correct the cycle stat is usally running about 140 - 160 temps did you switch the high one and the cycling wires or parts?
May 12, 2008 | Dryers
Whirlpool LER5636P Electric Dryer Logo
143 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
