Question about Maytag MMV5186A Microwave Oven
Slow Heating We ahve a maytag MMV5186AA above counter microwave.  Recently it has been slow in heating food.  As an example a cup of water left in for 2 minuets is still cool but set for 5 min. is boiling.  Have power setting to 100% and have tried unplugging the unit to reset it.  Thanks for your help.
  • David Emmel
    David Emmel May 11, 2010
    How old is the unit? water is a poor example for determing heating times due to ground temperature changes. Also supply voltage can be a culprit, altough rarely. Try testing with a food items known cooking time and compare the 2. Example, frozen pastry 2 min. on high should be done within 2 min +/- 15 sec.
    If item takes much longer to cook then, you may have a weak magnetron tube,(buy a new oven) Note: Use recommended times on the product packages, not my example.
  • Maytag Master
  • 9,098 Answers
Water is always called for in standard microwave heating tests.
By design, water molecules are what are targeted by the microwave cooking process.
If your line voltage is correct and it is slow to heat, then almost certainly your magnetron is failing.
If it's within the magnetron portion of the warranty but out of the original full warranty, then your manufacturer will cover the part cost, but not the cost to visit you or the labor charge to do the work.
If you or someone you know wants to look into this, we have *critical* safety, disassembly, and troubleshooting info at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
NOTE: There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on May 24, 2008
The microwave is not heating the food.
When it did heat food before and you used the same settings now, the microwave must be defect.
But before you are sure, put a cup with water in the micro and try to heat that.
Dry food can't be heated in a microwave. There must be some moist in the food if you want to heat it in the microwave.
Mar 13, 2015 | Microwave Ovens
Microwave wont heat up food
If your microwave runs, but doesn'theat your food, verify that you have selected a cooking setting. You mayaccidentally set the timer. Test the magnetron by placing 1 cup of water in themicrowave and heating the water for three minutes. If the water doesn't heat,your magnetron is dead.
Mar 08, 2012 | Sanyo Microwave Ovens
Takes about 6 min to boil 2 cups of water-generally slow on all heating
This an early indicator that the magnetron "heats the food" is failing, usually they will go without warning and eventually will need to be replaced.
Jan 25, 2011 | Whirlpool MH1170XS Microwave Oven
Sparkscome from food (no metal involved) and heating VERY quickly!
Arcing in or above oven chamberThere is often a simple cause:
  • Arcing in the oven chamber with a normal load (a cup of water, for example), often just indicates that a thorough cleaning of the oven chamber is needed, particularly around and inside/above the waveguide cover. Any food that gets trapped here will eventually burn and carbonize resulting in a focal point for further arcing. Usually, the waveguide cover is designed to be removable without taking the (cabinet) cover off of the oven. However, burnt food and carbon often make this difficult so that some disassembly will be required. See the sections: "SAFETY" and "Getting inside a microwave oven".
for more information see "Arcing in or above oven chamber" section of online Microwave Repair Manual.
If the microwave is clean, please post a reply and I will look at it again (this time include a model # and/or approx manufacture date)
Oct 21, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Heating the cup more than coffee
make sure the stirrer motor located under the outer cover that distributes the microwaves is turning otherwise you will get hot and cold spots in the oven cavity
Apr 30, 2010 | GE JVM1870 Microwave Oven
Maytag microwave oven model mmv4205bab not heating food
maytag microwave model # mmv4184aaq operates normally but will not heat food or water
Mar 07, 2010 | Maytag MMV4205 Microwave Oven
JVM1540DN1WW leaves food cold
Put in one cup of water at 2 1/2 minutes on high -- it should boil.
The fan slowing down is normal becaue the magnetron, which does the heating and, which pulls about 10 amps, will drop the voltage across the fan and slow it down.
What type of circuit was your old microwave using? Was it a circuit dedicated to the microwave?
Charlie
Aug 22, 2009 | GE Spacemaker JVM1540 Microwave Oven
We have just purchased a GE microwave oven, model JES1358WL. the light is on, the turntable turning, the control panel shows cooking and seconds counting down when attempting to heat cup of water. it is...
First: never attempt heating pure water in a microwave, that is dangerous.
Ensure the oven is not set to the minimum power, otherwise the heating will be minimal.
Try heating some food at maximum power for two or three minutes, if it does not heat, take it back to the shop.
About water in the microwave, see here:
Microwaved Water - A MUST see
Superheating of water
Oct 16, 2008 | Microwave Ovens
Maytag Microwave model#MMV5186AA
Typically, no heating of food, indicates a bad Magnetron (tube) or associated components. The oven can be repaired. Magnetrons are not hard to replace and can be ordered online through MCM electronics www.mcmelectronics .
However, due to the dangers of high-voltage within the unit, I would recommend taking the unit to a repair center.
Look in the manual to see what the warranty says. See if there is any information regarding the magnetron or parts. You may be able to get it repaired for free parts, less labor.
Please let me know if I can be of further assistance to you.
Good Luck,
- Jim
Mar 20, 2008 | Maytag MMV5186A Microwave Oven
Maytag MMV5186A Microwave Oven Logo
1,645 people viewed this question
Top Maytag Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Maytag Microwave Oven Expert? Answer questions, earn points and help others
