Question about Apple MacBook Pro 17-inch 2.4GHz Notebook
How can i remove the dvd from my mac, it is stuck. macbook pro 17 inch
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Apple Master
  • 1,099 Answers
A few ways of doing this
restart mac and press down the trackpad after you hear the startup noise
if that does not work try opening up disk utility and click on the icon of your disk under the left hand column then go up to eject button and click eject
or open up terminal found in the utilities folder within your applications folder and then type in
drutil tray eject and then press return
Finally what to do is try pick up your macbook tilt the macbook to the one side and ise the eject key and hopefully the effect of gravity will allow the DVD to fall out.
One other way to do it which I have used recently but IT CAN BREAK THE DVD DRIVE, so only use it as a last resort. Get a thin piece of plastic and put a piece of double sided tape on it then with the macbook switched off insert the piece of plastic with the tape facing down in relation to the keyboard. Put it in about half an inch and you may be able to drag the dvd out.
Hope this helps.
Posted on Sep 27, 2010
MacBook Pro 17 inch thermal paste
you can use any standard thermal paste on the macbook pro, however the processor is soldered to the board.
Jan 27, 2014 | Apple 17" MacBook Pro Laptop Computer...
Brand new apple dvd drive will not accept dvd
The DVD works by just pushing it in far enough till you get resistance, then the drive pulls the DVD in by itself. If after it pulls the DVD in, it just ejects it, The DVD drive thinks you are using an incompatible disk.
You can also try resetting the SMC.
This is how to reset SMC on most modern Mac laptops:
Shutdown your MacBook Air / MacBook Pro
Connect the power adapter to your Mac
On the MacBook/Pro's keyboard, hold down the Shift+Control+Option keys and the Power button at the same time
Release all keys and the power button at the same time
Boot your Mac as usual
Here's the key sequence to hold down:
Reset the SMC of a MacBook Air or Retina MacBook Pro
Do keep in mind that by resetting the SMC you will lose power specific settings, like the time it takes to sleep a Mac and other customizations to power settings. No big deal, but if you have made many changes to your hardware behavior you will want to adjust stuff like sleep behavior again.
Reset SMC of an iMac, Mac Pro, Mac Mini
Resetting SMC is different for non-portable Macs:
Shut down your Mac
Disconnect the power cord
Press and hold the Mac's power button for 5 seconds
Release the button
Reattach the power cables and boot the Mac as usual
Reset the SMC of a MacBook or MacBook Pro's with detachable batteries
sad mac reset the smc Older MacBook laptops with a removable battery can reset SMC with the following approach:
Shutdown the MacBook/Pro and remove the battery
Disconnect the power adapter, hold the Power Key for 10 seconds
Release the power key and reconnect your battery and power adapter
Turn your Mac on
Let boot as usual
Hopefully that will clear up your problems, if not it might be worth a visit to the Apple Store or a certified repair center.
Happy New Year,
Kerry
Jan 24, 2014 | Apple MacBook PC Notebook
I can not update my mac to 10.9
Hard to say without knowing exactly what Mac you have and what specs, but most likely reason would be your system doesn't meet the requirements (From Apple support site) - To install Mavericks, you need one of these Macs:
  • iMac (Mid-2007 or later)
  • MacBook (13-inch Aluminum, Late 2008), (13-inch, Early 2009 or later)
  • MacBook Pro (13-inch, Mid-2009 or later),
  • MacBook Pro (15-inch or 17-inch, Mid/Late 2007 or later)
  • MacBook Air (Late 2008 or later)
  • Mac mini (Early 2009 or later)
  • Mac Pro (Early 2008 or later)
  • Xserve (Early 2009)
Your Mac also needs:
  • OS X Mountain Lion, Lion, or Snow Leopard v10.6.8 already installed
  • 2 GB or more of memory
  • 8 GB or more of available space
Jan 18, 2014 | Apple OS Computers & Internet
Stuck disc mackbook pro lap top
The MacBook has a dvd slot load design, I recommend a technician who is trained to work on these laptops because they are more complex than the regular computers.
Jul 31, 2012 | Apple MacBook Pro Laptop Computer with...
Stuck disc in Macbook pro
CD and DVD drives have a manual release.On the door,look for a small hole.You an usually insert a paper clip in this hole to manually release the latch and open the door.
How do I get the DVD out of my Mac Book Pro
1) restart mac and press down the trackpad after you hear the startup noise
2) if that does not work try opening up disk utility and click on the icon of your disk under the left hand column then go up to eject button and click eject
3) or open up terminal found in the utilities folder within your applications folder and then type in
4) Finally what to do is try pick up your macbook tilt the macbook to the one side and press the eject key and hopefully the effect of gravity will allow the CD to fall out.
However, I would say that DVD drives in all macs are a bit suspect and if
your macbook is still under warranty or under AppleCare take it back to the Apple Store and tell them that the DVD drive is faulty and they will replace it free off charge.
If it is out of warranty there is one other way to do it which I have used recently but IT CAN BREAK THE DVD DRIVE (Use it at your own risk), so only use it as a last resort. Get a thin piece of plastic (or credit card) and put a piece of double sided tape on it then with the macbook switched off insert the piece of plastic with the tape facing down in relation to the keyboard. Put it in about half an inch and you may be able to drag the DVD out.
Hope this helps.
Jun 25, 2012 | Apple Computers & Internet
Macbook pro mb766ll will not turn on. Light blinks on for 1 sec then goes away . black screen
i would take the battery out and just use AC power and when you push the button pull out the power straight away.
Jun 16, 2011 | Apple MacBook Pro MB766LL/A 17-Inch...
Apple MacBook Pro 17-inch 2.4GHz  Notebook Logo
153 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
