Question about Dryers
Need a manual for a hoover maxi 6 TV30 tumble dryer.
Illeagle
  • 525 Answers
SOURCE: When loading the dryer (Hoover
I attempted to locate an answer to resolve the issue for you, but you have not provided me with enough information to access my service database. Please observe the TIP below, and post me back and I will be happy to assist you further. Should you require more extensive consultation to help resolve your complaint(s), you may contact me through our premium chat service.
Tip: Always provide the complete information provided on the manufacturers product information data tag, located on the unit, and not in the user’s manual. This will help you acquire a more accurate and expeditious response to your complaint.
Based on your complaint it, certainly sounds like a relay,(typical), or it could be the timer motor. I have no way of knowing if it has a relay. Generally this is harmless.
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
Posted on Jun 21, 2008
wildbear6
  • 192 Answers
SOURCE: Hoover Maxi 6 TC50 Tumble Dryer making squealing noise
Have you fixed this problem? I also have a Hoover condenser dryer, only a few months old, and has started to make a squeal/whistle. I'm thinking it might be the front fan needing some WD40, OR too much water vapour around the belt that moves the drum causing the sounds.
If it's the fan, lubricating the shaft and its components should fix the problem, if a wet fan then I'd think maybe fully cleaning the condenser filter, reservoir ect will fix the problem.
The problem seems to go away though "mostly" 15 or so minutes after you start the dryer, so that makes me think ones it gets warm something is expanding to allow more "give" so maybe the belt.
Posted on Jan 01, 2010
  • 234 Answers
SOURCE: Hoover TV30 tumble dryer belt gone..how do I
On models that do not have disengageing clips for the top to be removed, you must remove the front (face panel) and this is usually done by 2 small screws at the bottom of the front panel. Then you tilt the front out and will be able to unhook the front from the top. Now, you need to undo a small bolt or screw inside between the top and the side panel (there is one on each side). Goodluck, Macgivor
Posted on Jan 02, 2010
SOURCE: my hoover maxi 6 reverse air tumble drier has no
The thermal overload has failed. Replace the heater assembly on the rear of the drier, under the metal cover.
Posted on Jun 05, 2010
emissionwiz
  • 77169 Answers
SOURCE: I have a hoover maxi 6 tv30 sorry the serial
most dryers regardless of the make and model use the same basic procedure to replace the belt, while u are in there make sure the drum rollers are in good shape. go to the link below instructions with pictures
http://www.diyprojectsonline.com/projects/interior/fix_dryer_belt.php
Posted on Sep 26, 2010
I have a Hoover nextra 6 kg condenser tumble dryer which is leaking water and the collector is empty and seems not to locate fully into the hole at the back?
Check for Lint/Dirt in the Drain and then you need to ensure it is fully connected in the Washer to the Drain...
Jan 03, 2015 | Hoover Dryers
My hoover maxi 6 reverse air tumble drier has no hot air when drying. the filter care light is on. what does this mean?
Jan 27, 2010 | Hoover Dryers
Hoover TV30 tumble dryer belt gone..how do I access the belt area? I cannot slide the top off!
Jan 02, 2010 | Hoover Dryers
Hoover Nextra 6 1400 6+4kg - the tumble dryer
under top cover there are 2 thermal cut outs to reset.situated centre front
Sep 12, 2009 | Hoover Nextra HNWL 3136 Front Load Washer...
Aug 26, 2009 | Hoover Dryers
Noisy when running need to check belt and bearings
i need the serial # to assist you better
thank you
May 14, 2009 | Dryers
When loading the dryer (Hoover Maxi 6 TV30) a continuous 'buzzing' noise can be heard when the on switch is pressed. This can be heard for a few moments or a little long then everything is OK. Occasionally...
Thank you,
Dave E. (Illeagle)
Jun 21, 2008 | Hoover Dryers
Dryers Logo
203 people viewed this question
Top Dryers Experts
