Question about Air Tools & Compressors
HI GOT AN AIRMATE SIP 01564 COMPRESSOR TRIES TOO START THEN STOPS ANY IDEAS? ALSO REQ MANUAL AND PARTS LIST THANKS ...
3 Suggested Answers
  • 58 Answers
SOURCE: looking for a head gasket for sip airmate p3/150
hi try Machine mart in manchester uk failing that you will have to make 1 (not that difficult ) get hold of some copper sheet 1/16 thick trace out off the old gasket cut out ,clean up and aneal it ,,heat up till cherry red and quench it in water if you haven't got the old gasket put a piece of paper over the top of the barrel and go round all the edges with your finger this will give you a perfect copy/outline cut tis out and use as a template hope this helps merlin v12
Posted on Aug 19, 2009
miket756
  • 2702 Answers
SOURCE: problem starting fom cold
have you put too thick an oil in it???? or none at all??as if it starts and runs all day there,s not much wrong with it? i'm thinking its very thick oil, or lack of any oil or starter capacitor???
its very tight to turn over when starting up first thing,
are you running it on a long extension lead???
is it a 1,5hp??? it needs a 13amp fuse???,
the sip has a capacitor start motor fitted, it could be the cap going down on you?? dont play with the capacitor, they can and will kill you!!! machine mart may fix it for you?
Posted on Oct 20, 2009
Testimonial: "thanks mate i`ll try your advice about the capacitor"
Low output pressure from Airmate Compressor
You have this posted in the wrong prioduct category. please re-post
Jun 07, 2012 | Cars & Trucks
2001 s500 airmatic problem car air compressor stays on long and the car is very high
check the relay for the airmatic compressor it is on the passenger side in the engine compartment right next to the hood hinge. pull the cover off and its the 3rd relay back from the front. the relay might be sticking closed but have it checked before it causes the compressor to burn itself out
Oct 21, 2010 | 2000 Mercedes-Benz S-Class
I have the car to low error message on the display the bags are bottomed out and wont raise up. its on a e 500 2003
The suspension has a leak somewhere and/or the airmatic compressor has stopped working properly. You need either the Mercedes star diagnosis system (SDS) in order to access the suspension control module to tell it to raise the vehilce or you can try to trick it by jacking up the car so it thinks it's sitting at the correct ride height. But as long as the display reads a warning it won''t allow the airmatic compressor to run.
Oct 12, 2010 | Mercedes-Benz 500-Class Cars & Trucks
I need the assembly instructions for an emglo airmate am77 1 1/2 hp air compressor head and valve assembly. please help!
there is aweb site called www.mastertoolrepair.com in the search type am77 should get schematic break down for your compressor, then go to internal parts and you should get a brek down and schematic on your compressor hope that helps
Oct 22, 2009 | Air Tools & Compressors
Problem starting fom cold
Oct 20, 2009 | Air Tools & Compressors
Emglo airmate AM78HC4V; when trying to start compressor the motor will only hum
I had the same problem. Replace the motor capacitor. small white cilinder part with two wire plugs conected to it. This will have a single bolt holding it to the frame casing, you will find it under the black plastic shroud that covers the motor. Take it into any electrical or compressor shop and they will check it for you. costs about $35.00.
Jun 08, 2009 | Dewalt d55151 factory reconditioned emglo...
Looking for a head gasket for sip airmate p3/150 code 06646 can anyone help
Jun 06, 2009 | Air Tools & Compressors
Nortel Meridian - Admin Password changed & forgotten
Log into the system,
goto>
LD 20
req: prt
type: dn
cust: 0
DN: <the extension number>
press enter till you get req: again
Now write down the TN number.
while in LD 20
req: prt
Type: TN (which you wrote from previous command)
enter till you get a long list
find out a prompt 'SCPW'. The number beside SCPW is the password.
Nov 12, 2008 | Lands Phones
Fridge won't run
hi brenda,
can u hear a humming sound as if it is trying to start then it would stop after a clicking sound?
if it does then it is your compressor trying to start but can not do it.
you could either have a problem in your starting relay of overload protector of the compressor or the compressor itself is the defective part and it needs to be replaced.
i hope i was able to help.
pls rate me
tnx
drcool
Jul 21, 2008 | Magic Chef MCBR440 Compact Refrigerator
Air Tools & Compressors Logo
82 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
