Question about Day-Timer Mwave Tx12626x Timex Electronic 7 Day Timer
Looking for schematic for Timex TE109, aka TX12626X. Thanks.
Open following link for misc Timex manuals.
http://waterheatertimer.org/Woods-timers-and-manuals.html#Timex
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Posted on May 08, 2011
Return policy
Fixya does not sell or warrant timers
Copy following link to identify Timex timer.
Timex does not show timers on their website, and unknown who carries warranty for this line of timers.
If you want clear warranty coverage, I suggest Intermatic timers, and Woods timers, or Sylvania, Leviton.
Each of these brands has clear warranty procedure shown on website for each.
Add a comment for more specifics
May 21, 2013 | Day-Timer Mwave Tx12626x Timex Electronic...
When i plug it in there is no display is it broken ?
Reset timer using reset button, and see if functionality begins.
Plug timers into different outlets.
Test outlets for correct polarity and that they deliver at least 80% rated value, 115 volts x 80% = 92 volts.
Most timers have 1 year limited warranty through manufacturer.
Timex timers are not made by or display on Timex website.
Unknown where warranty is honored.
Suggest GE, Woods, Intermatic timers since these have specific web links for warranty coverage, but you have to send timer in.
This is why I suggest buying timers at local box store, then if problem occurs, buy another timer and return defect in new package, thus giving convenient extended warranty coverage.
Nov 23, 2012 | Day-Timer Mwave Tx12626x Timex Electronic...
I have completed the setup of my Day-Timer Mwave Tx12626x Timex Electronic 7 Day Timer. I turned on my television, then plugged it from the outlet, then plugged it into the timer. The TV will not turn on...
Open following link to identify your timer
1) Don't expect the timer to turn on the TV picture.
I have my TV plugged into power strip.
Each night the power strip is off. When power strip resumes next day, the TV is READY to be turned on with the remote control. The picture does not pop up when the power strip goes on.
Same is true for timer.
Try your power strip and see if picture turns on after power strip is turned off-on.
Timer will work same as on-off switch on power strip.
2) Is the power strip interfering with timer?
Plug timer directly into wall outlet and see what happens.
Add a comment and let others know what happened.
3) Battery: Timer requires 2-hours for initial battery charge.
Battery back-up protects programs when power is off.
I don't know if battery is made for repeated on-offs if you turn off power strip each night.
These batteries are not replaceable however timer has 1 year limited warranty.
4) Plug lamp into timer and see if timer operates lamp. This will say if TV electronics are interfering with timer operation.
5) Load: This timer says it is for appliances, which implies it should be rated typical 15A 1800 watt
Absolutely feel obligated to upvote the help.
Or take advantage of fixya expert assistance live.
May 04, 2011 | Day-Timer Mwave Tx12626x Timex Electronic...
I need to know how to set my timer, I've had it for a while but i don't have the instructions that came with it. Day-Timer Mwave Tx12626x Timex Electronic 7 Day
Open following link to identify timer for sure.
http://waterheatertimer.org/Woods-timers-and-manuals.html#Brinks
Several companies sell a similar timer, and there is a manual for Westek version.
http://waterheatertimer.org/pdf/Westek-TE05WHBL-manual.pdf
Add a comment if this manual is correct for the Timex also.
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Feb 01, 2011 | Day-Timer Mwave Tx12626x Timex Electronic...
Lost instructions for TE109 appliance timex timer.\r\nCan you help? Thank You & Merry Christmas
    • Plug your Timex seven day timer into a standard electrical outlet. Allow the timer's rechargeable battery to charge for at least 10 minutes before attempting to program the appliance; the battery will serve as a backup power source to prevent your custom programmed settings from being lost in the event the timer is unplugged or the power goes out.
    • Press the depressed "RST" button on the timer with the tip of a ballpoint pen to reset the timer's internal memory.
  • To Set the time on your Timex timer. Press and hold the "Set" button for three seconds or until the day-of-week indicator begins to flash. Press the "->" or "<-" button repeatedly until the desired day appears on the digital display; press "Set." Use the "->" or "<-" buttons to set the hours when they begin to flash; press "Set" when the desired hour is shown. Use the same process to set the minutes, then press the "Set" button again to confirm the day and time settings.
    • To Program a start time for your seven day timer. Press the ">" button to access the appliance's programming mode; the program number will begin to flash. Use the "->" and "<-" buttons to highlight the desired program number, then press "Set." Highlight the desired day and press "Set" again. Program the hour for your timer; press "Set." Set the minute and press the "Set" button to confirm.
    • wait for the timer to go back to std mode (like 10 seconds)
To program a stop time for your timer. Press the "Set" button to cause the day-of-week indicator to flash. Highlight the desired day and press "Set" to confirm. Adjust the timer's hour with the "->" and <-" buttons; press "Set" when the desired hour is shown. Set the minute for your timer and press the "Set" button again. Press the "Time" button to exit the setting mode.
Dec 17, 2010 | Timex Hardware & Accessories
How to set timer
Upvote the help.
Nov 28, 2010 | Day-Timer Mwave Tx12626x Timex Electronic...
Need schematic instructions on how to operate a Timex 50 lap Ironman watch.
You can get instructions from the Timex web site "timex.com".
At the bottom of the screen click on "manuals/downloads", then on "product
manual download"
Enter your watch type in the search box and click on "search"
Sep 03, 2010 | Watches
Need instruction manual
Open following link for misc Timex/ Westek manuals.
Upvote the help.
Jun 23, 2010 | Day-Timer Mwave Tx12626x Timex Electronic...
I m looking for a manual for timex ironman M586. I
manual download"
Jun 03, 2010 | Watches
Day-Timer Mwave Tx12626x Timex Electronic 7 Day Timer Logo
487 people viewed this question
Top Day-Timer Hardware & Accessories Experts
Gene Haynes
Craig Butler
Craig Butler
Are you a Day-Timer Hardware and Accessory Expert? Answer questions, earn points and help others
