Question about Casio Cassiopeia Fiva MPC-701M30E PC Notebook
Hi,how to remove bios password of casio laptop?
I need to reset my Toshiba laptop. It has been a couple of years since I have used the laptop; therefore, I have forgotten the password.
  • How to Reset BIOS Password on a Toshiba Satellite Laptop ... www.youtube.com/watch?v=TbXW6-PngZk
    • BY DIY TECH
    • 5 MIN
    • 365K VIEWS
    2012-07-31 · Video embedded · In this video we reset the BIOS password on a Toshiba Satellite Laptop. Visit our website for more information ...
  • How to remove bios password - Toshiba Laptop - iFixit https://www.ifixit.com/Answers/View/79319/How+to+remove+bios+password I have a Toshiba Satellite C655D-S5136. I forgot my bios password and need to reset it. I already tried removing the CMOS battery, but it still won't let me reset my ...
  • Passwords: setting and removing (for BIOS, Supervisor, and ... support.toshiba.com/support/viewContentDetail?contentId=108503 Passwords: setting and removing (for BIOS, Supervisor, and Windows passwords) ... If you forget the BIOS password, only a Toshiba Authorized Service Provider can ...
  • Reset Toshiba Satellite BIOS Password ' Find Password findpassword.net/reset-toshiba-satellite-bios-password Heres a quick and dirty way to reset the password on the Toshiba Satellite A205 BIOS. Warning! You can only use these tips on your own Toshiba computer if you forgot ...
  • HOW TO REMOVE BIOS PASSWORD ON A TOSHIBA SATELLITE ... www.youtube.com/watch?v=aHLzz77oP4Q
    • BY TIGGAR COMP
    • 7 MIN
    • 233K VIEWS
    2012-04-24 · Video embedded · HOW TO REMOVE BIOS PASSWORD ON A TOSHIBA SATELLITE A305 AND C655D ... How to Reset BIOS Password on a Toshiba Satellite Laptop ...
  • Bypass BIOS password set by faulty Toshiba firmware on ... superuser.com/questions/243413 Bypass BIOS password set by faulty Toshiba firmware on Satellite A55-S1065 ... you cannot reset the bios password of the Toshiba laptop just by removing the CMOS ...
  • How to Reset a Toshiba BIOS Password? - tech-faq.com www.tech-faq.com/reset-toshiba-bios-password.html
    • 2/5
    • 5 RATINGS
    Reset the Toshiba BIOS Password Using Parallel Loopback Plug. Another option to resetting the Toshiba BIOS password on older models is to use a parallel loopback ...
  • Toshiba Satellite BIOS password reset - BIOS - Motherboards www.tomshardware.com > Forum > Motherboards Hi. Does anyone know how to reset the BIOS password for a Toshiba Satellite C660D 19X please? There are a number of very good YouTube videos for almost identical ...
  • How to reset BIOS password on a toshiba laptop - Laptops ... www.tomsguide.com > Forum > Laptop Tech Support Basically, I accidentally set a BIOS password on my parents toshiba laptop. I was messing around and now I don't know how to reset it. I do know what the password is ...
  • Removing BIOS password on Toshiba Satellite Laptop - YouTube www.youtube.com/watch?v=dd06-tVVq8I
    • BY BRAD HYMAN
    • 4 MIN
    • 549K VIEWS
    2012-10-06 · Video embedded · This video will describe how to reset the BIOS password bug on a Toshiba Laptop. What you will need to make sure you do before ...
  • Jun 08, 2016 | Toshiba Computers & Internet
    BIOS password
    It can be attempted in several ways.
  • Using a manufacturers backdoor password to access the BIOS
  • Use password cracking software
  • Reset the CMOS using the jumpers or solder beads.
  • Removing the CMOS battery for at least 10 minutes
  • Overloading the keyboard buffer
  • Using a professional service
  • Feb 22, 2008 | IBM ThinkPad R40 2722 Notebook
    Hi. Casio ce3400 e02 error. Can't get rid of. . True doing different clerk thing.. doesn't help .. par help
    check hear
    BIOS Password
    Laptops in general have much better hardware security than PCs. Some of them even come with fingerprint reader build in.
    Most laptops come with a very strong BIOS password capability that locks up the hardware and makes the laptop completely unusable. This is the password that has to be entered before the operating system loads, usually on a black screen a few seconds after the laptop is started.
    Of course BIOS password can be set on a PC too, but there it is stored together with the other BIOS settings - date, time, hard disk size, etc. It is very easy to reset the BIOS settings (and the password) on a PC - usually there is a jumper near the BIOS battery on the motherboard that needs to be moved from connecting pins 1+2 to pins 2+3 for a few seconds and than moved back to pins 1+2. Next time the PC is started it will alert you "... BIOS settings invalid... Defaults loaded... Press F1 to continue..." or something similar, and.... the password is gone!
    However most laptops store the BIOS password in a special chip, sometimes even hidden under the CPU, that is not affected when the rest of the BIOS settings are reset. This makes the removal of a BIOS password on a laptop almost impossible. The only option in most cases is to replace the chip which is quite expensive and risky procedure and, of course, not supported by the manufacturers.
    Some manufacturers (like Dell) can generate a "master password" for a particular laptop (from their service tag) if sufficient proof of ownership is provided. Others (like IBM) would advise replacing the laptop's motherboard (very expensive). On some old laptops (4 - 5 years or older) the BIOS password can still be reset relatively easy, usually by shorting two solder points on the motherboard or by plugging a special plug in the printer port, etc.
    In almost all cases on newer laptops it is either a big hassle, expensive or even impossible to reset the BIOS password, making it a very good way of protecting your laptop from unauthorized use.
    However what makes your computer exactly yours are your own files, documents, emails, pictures, etc. They are all stored on the hard drive. So, even if your laptop has a BIOS password that locks it up and makes it completely unusable to anyone that doesn't know it, your hard drive can still be removed from the laptop and connected to another computer, and your files retrieved quite easily.
    goodluck
    Jun 08, 2014 | Computers & Internet
    How to Disable Acer Travelmate 240 BIOS Password?
    To disable the bios password on your laptop, you will need to remove the cmos battery on your laptop for some minutes and insert back, the cmos battery is located on the motherboard of your laptop, once the cmos battery is removed from the motherboard for some minutes, the bios password will be reset, and the bios password will be disable.
    Take care.
    Nov 19, 2010 | Acer TravelMate 240 Notebook
    Hi i am an indian.sir my laptop toshiba model:satellite A130/A135 Series is asking for bios password.ples help me.
    Hi.
    If you dont remember the BIOS password, you may remove it by resetting the BIOS password.
    Please follow the below steps to reset the BIOS password:
    1) Please remove the bottom casing of the Notebook.
    2) Once you have removed the below casing, you should be able to see a CMOS Battery.
    3) The CMOS Battery will be of a size of a coin.
    4) Once you have found the CMOS Battery, please remove and re-insert it again.
    5) The CMOS Battery will have the information about the Computer Date, time, BIOS Password etc.,
    6) Removing and re-inserting the CMOS Battery will reset these settings, which will also remove the BIOS password.
    Please perform the above steps and let me know the results.
    Hope this helps.
    Please feel free to contact for further information and assistance.
    Oct 02, 2010 | Toshiba Computers & Internet
    I have a Wipro Laptop. His BIOS is Phoenix. It has a CMOS password. How shall I clear the password.\?
    Hi Nayanranjani.
    As you trying to reset the BIOS password, let me provide the required steps.
    You may reset the BIOS password by just removing and inserting the CMOS Battery.
    The CMOS Battery will have the Computer date, time and also the BIOS password saved in it.
    Hence, removing and re-inserting the CMOS password will reset the BIOS password.
    Once the BIOS password is removed, you may assign a new BIOS password.
    Hope this helps.
    Please feel free to ask further questions.
    Aug 18, 2010 | Computers & Internet
    I have laptop dell inspiron 9400 and it is lock with bios password please help me to unsecure my laptop code : J6VYT2J#-595B
    Hi
    Bios password differ for every model, try with the below mentioned password to unlock it.
    AMI BIOS PASSWORD CONDO LKWPETER
    If not you have to reinstall the OS.
    Thank you
    May 14, 2010 | Dell Inspiron 9400 Notebook
    How is removr bios password
    Hi..
    To remove BIOS password you need to open your laptop and reset the CMOS, get and screw driver and opened it.
    Once you have already open your laptop find the cmos jamper in the south bridge of your laptop motherboard. The jamper located near the CMOS baterry, To reset remove the jamper within 5 second and turn on your unit. After that reinsert the jamper, now the bios password was cleared.
    Regards
    PCmania
    Sep 26, 2009 | Acer TravelMate 240 Notebook
    Casio Cassiopeia Fiva MPC-701M30E PC Notebook Logo
    Top Casio Computers & Internet Experts
    k24674
    Piyal Perera
    Piyal Perera
    Are you a Casio Computer and Internet Expert? Answer questions, earn points and help others
