Question about Canon Rebel XT / EOS 350D Digital Camera
My tamaron 28/200 lens when fitted to. cannon eos 350 d. shows err 99 when switched on ,previosly ok ,disconect lens and camera functions ok,only have one lense
    Brigadier General:
  • 11,967 Answers
Try cleaning the contacts on the camera body and lens where they meet with a cotton swab lightly dampened with rubbing alcohol.
Posted on Sep 27, 2010
DS 126151 error
What kind of error? Err 99?
You mention DS 126151, that's the model number. This camera is mostly know as Canon EOS Rebel XTi? Also known as the EOS 400D or EOS Kiss Digital X.
If you are getting a Err 99 while shooting, try any other lens that will fit on your Canon. In most cases the aperture will become defect in these lenses. Not worth repairing if you ask me. One thing you could do, is shoot only at its maximum aperture. So that'll be F4.0 at 70mm and F5.6 at 300mm. That might work, but that might not be suitable in every situation.
Dec 30, 2013 | Sigma AF 70-300mm f/4.0-5.6 DL Macro Super...
I have cannon EOS 400D problem is error 99, some times after shooting
Welcome to Fixya
Err 99 could mean several different things, such as... Memory Card, Lens or Lens contacts....
Here's what you can try:
Remove the memory card an enable "shooting with out memory card" and see if you still get the error. If it works your memory card is bad. Try another lens if you can. Clean the lens contacts with a pencil eraser (be careful not to get eraser dust in the camera body or in the lens). Worst case scenario is, Err 99 could be related to the shutter failing which would mean a trip to Canon.
Have a good one!
Apr 16, 2011 | Canon EOS Digital Rebel XS / 1000D IS...
Err 99 on canon eos 300d,what is it and how do I it
it is a miscellanous error and may be caused by installing a non cannon lens. Remove the battery and reinstall to see if this clears the problem
Dec 28, 2010 | Canon Digital Rebel / EOS-300D Digital...
Err 99 shows up on screen when I try to take a photo
This is usually a lens error. Take the lens off and clean the contacts on the camera body and lens where they meet with a cotton swab lightly dampened with rubbing alcohol.
Jan 09, 2010 | Canon Digital Rebel XT / EOS 350D Digital...
My canon eos rebel xti keeps showing error code 99
To isolate the cause of the issue, we suggest that you do the
following:
1. Turn off the camera.
2. Remove the lens, battery, and CF card.
3. Allow the camera to sit without power for approximately 20 minutes.
4. Insert a fully charged battery, and turn on the camera.
Does the "ERR 99" message appear? If it does, then the camera should
be serviced. If it does not, then please proceed to the next set of
steps:
2. Insert the CF card.
3. Turn on the camera.
4. Format the CF card in the camera.
Does the "ERR 99" message appear? If so, then the CF card is the most
likely source of the issue. Try using a different card.
If the message does not appear, please complete the following steps:
2. Clean the lens contacts by gently rubbing them with a pencil eraser
or soft cloth. Be careful that you do not let any debris fall into the
camera body.
3. Reattach your lens.
4. Turn on the camera.
If the "ERR 99" message only appears when one particular lens is
attached, then that lens should be examined by a service technician.
If you see the "ERR 99" with a different Canon lens attached, then the
camera should be serviced.
Sep 22, 2009 | Canon EOS 400D / Rebel XTi Digital Camera
My canon xsi about 8 months old. err 99 appear during my wedding coverage. and even i remove the cf card, the batt and change it still the err 99 appear. and wen i came home i change the lens and wen i...
err99 is a generic error code that the camera cannot identify to a particular component.
One thing to try is to switch off, remove the lens and clean the gold contacts on the camera and lens.
This is a common cause for err99 and in a lot of cases cures the problem
Jul 04, 2009 | Canon EOS Elan 7ne 35mm SLR Camera
Err 99 on canon rebel xt 350 d
The Err 99 problem occurs due to dirty contacts between the body and the lens. I recommend cleaning the contacts. You can then turn Off the camera and then remove and reinstall the batteries to reset the camera to get the problem fixed.
Jan 15, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Cannon Eos 400D Err 99?
Error 99 is a NONSPECIFIC error message. It is almost always associated with the LENS. I first got this error on my EOS 20D whei I tried to use an older Sigma zoom lens (7 years older than the camera). I don't use off-brand lenses with my Canons. Try removing the main battery first followed by the time & date battery which is hidden in the battery compartment beside the main battery. This will reset your camera. Good Luck!
Nov 30, 2008 | Cameras
Canon EOS 400D SLR - Err 99
Try going into the menu and turning off the lock for shooting without a lens. Then try firing it without a lens to see if it works. Very often a lens problem can cause the Err 99 message.
Also, check to make sure the pop-up flash is not stuck down. That could also cause it.
Unless you have used your camera a LOT, it shouldn't be a bad shutter. They usually only quit after many years of use. I think Canon quotes 125,000 shots as the normal life of a shutter in a digital SLR.
CameraRepairs
Jul 14, 2008 | Canon EOS Elan 7ne 35mm SLR Camera
Error 99
Assuming that other lenses function normally on the camera, the "Err 99" can be caused by a failure of the aperture component in the lens. Error 99 is a generic error, so unfortunately it does not indicate exactly what is wrong. There are other factors that can cause the failure, but there is a good chance that the aperture is not functioning correctly. You can try cleaning the electrical contacts on the lens, if this does not work you may need to get the lens serviced. Check with Canon, or check the web for other repair service providers. David Millier Advance Camera Repair
Mar 05, 2007 | Canon EF-S 17-85MM F/4-5.6 IS USM Lens
Canon Rebel XT / EOS 350D Digital Camera Logo
37 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
