Question about Seiko Smart 440 Thermal Label Printer
Slp print manager did not start - Seiko Smart 440 Thermal Label Printer
2003 infiniti slp vcd on why?
what is slp
what are you touching, AUDIO parts. (stock or aftermarket )
and VCD died years ago, is this a nastalag trek? (no judge)
vdc is video CD discs.
a dead horse.
name whats in hand, and where are you placing object exactly.
Jun 25, 2014 | 2003 Nissan Altima
Hp 2420 offline error
Upgraded all jetdirects to their latest firmware, DOWNgraded any jetdirect J7949E on firmware v33.15 to v33.14 (.15 is horribly broken and crashes after a couple of minutes usually).
I have enabled SLP protocol on all the print servers, I have then telneted into the jetdirect to set slp-keep-alive (available with the firmware updates) to a value of 2 (2 minutes between slp anouncments).
I have changed the MAC age time on all the switches to 900 seconds from the default 300.
Jetdirects now announce themselves every 2 minutes stopping the switch forgetting that they exist. I have added a logoff-period of 1800 seconds to a single port with a Xerox printer on it which stops it reauthenticating every 10 minutes (unable to change slp interval on it).
This may or may not help, but I've had the printers on line for the last week now and when I ping, they are still there!
Jul 22, 2012 | HP LaserJet 2420 Printer
Hi there I just got a new computer and try to copy the old smart label printer over, but when I try to print the label out, I got a message says.." SLP print manager can not start" What I...
when you say uyou copied the old printer over I assume you actually reinstalled the Printing Application from scratch?
You cannot just copy the seiko directry over, t doesnt load the .dll files
reinstall the application
biffo
Sep 08, 2011 | Seiko Smart 440 Thermal Label Printer
Recommended product key
It is my pleasure to guide you.
After doing some research I found what may be what you need. This comes from http://social.microsoft.com/Forums
QUOTE
Wednesday, October 13, 2010 9:00 PM
Darin Smith MS, Microsoft Contingent Staff, Owner
Computers, which are built by large manufactures that come with Windows Pre-Installed, come with two (2) Product Keys:
A) OEM SLP: This key comes pre-installed in Windows, when it comes from the Factory. This key is geared to work with the OEM Bios Flag found only on that Manufacturer's computer hardware. So when Windows was installed using the OEM SLP key (at the factory) Windows looks at the motherboard and sees the proper OEM Bios Flag (for that Manufacturer and that version of Windows) and Self-Activates. (that's why you did not need to Activate your computer after you brought it home)
B) COA SLP: This is the Product key that you see on the sticker on the side (or bottom) of your computer. It is a valid product key, but should only be used in limited situations (such as if the OEM SLP key stops self-activating for whatever reason). The key must be activated by Phone. (Note: All manufacturers that use the OEM SLP system are required by contract to include a Certificate of Authenticity (COA) sticker, that has a COA SLP key, on the computer)
Your Windows is using an OEM SLP key, but (for whatever reason) cannot see the special instructions in the computer's motherboard and is unable to Self-Activate.
To fix the issue, you will need to change out the OEM SLP key with the COA SLP key. The normal way to do this is to click the 'Start' button, right-click 'Computer', select 'Properties' and then click 'Change Product Key' (located in the lower right-hand side of the window). Enter the COA SLP key and follow the instructions in the Change Product Key Wizard.
Alternate steps to change the product key
1) Click the Start button
2) Type: slui.exe 3 and hit the Enter key
3) Type in the Product key from the sticker on your computer
4) Click the Next button.
5) You will be asked if want to Activate, click ok
It will attempt to Activate by the internet and will return an Invalid Key error (this is ok, continue to step 66)
6) Click the Start button
7) Type: slui.exe 4 and hit the Enter key
8) Select your location in the drop down menu and click the Next button
9) The next screen provides the number to call to Activate by Phone
NOTE: when you call that number, you will first hear an Automated Voice. If the Automated Voice gives you an option to talk to a Live Activation Rep., select that option. If not, do not enter any numbers. This should force the Automated Voice to transfer you to a Live Activation Rep. Trying to Activate thru the Automated Voice will not work, in your case; only thru the Live Activation Rep. will your Activation be successful.
UNQUOTE
I learned something new while doing this research. I like doing new things that is why I do this.
Good luck and please post back that you are successful or that I can be more helpful.
Jun 09, 2011 | Computers & Internet
Samsung slp 770 incomplrte session by time out
The Samsung CLP 770 produces an 'incomplete session by time out' if you switch off the computer originating the print in the middle of the print job (before the print is finished) OR if the network connection is lost between the computer originating the print and the CLP 770.
The printer may have printed the start of the print job but also recognises that it has not received the end of the print job information. It waits for a good while for the connection to be restored in an attempt to receive the rest of the print job - but if nothing comes then it times out.
The reason for this action is to prevent this situation effectively locking out any other computer on the network from printing while it 'waits' for the end of the print job.
Dec 28, 2010 | Samsung CLP-770ND Laser Printer
I record sports events on my dvd recorder on slp 6 hrs and when i rewatch the screen goes blurry when the action starts
SLP is the lowest picture quality possible for a DVD recording. Due to the extreme compression used for this mode, fast motion and detail are lost. It's one of the costs of long playing time. Try the next recording speed faster?
Apr 02, 2010 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Need to set DVD recorder process to SLP instead of SP.
Press the REC MODE button until slp shows up in the bottom right side of the tv.
Jan 01, 2009 | Philips Magnavox MWR20V6 DVD Recorder/VCR
VCR SLP playback problem
I would first have it cleaned.
Jan 29, 2008 | Sanyo DRW-1000 DVD Recorder/VCR
Seiko Smart 440 Thermal Label Printer Logo
128 people viewed this question
Top Seiko Office Equipment & Supplies Experts
Scott Kalvinek
Are you a Seiko Office Equipment and Supply Expert? Answer questions, earn points and help others
