Question about Harman Kardon HK 3480 Receiver
HK 3480 sound suddenly cuts out
I recieved this reciver as gift in december. after a few months of not having speakers, i bought some JBL's and everything was sounding great. however, now i'll be listening to music (mostly via a connected laptop) and it will just cut out.
i thought this maybe something odd, so i then just put the reciever on AM radio same thing, so obviously it has nothing to do with the cables. but just to be sure i've checked the cables (reciever -> amplifier & laptop -> reciever) nothing wrong. i'm not hitting mute on the remote, i'm not turning the wrong speakers on or off (i.e. speakers A instead of speakers B), and the power does not go out.
i know it's still under warranty. i just hope i don't have to get it fixed. because i'm just now able to enjoy it... sort of.
thanks.
Ken
  • slcollom Aug 23, 2008
    The same occurs with my HK3480 as well. I cannot even make it through both sides of a vinyl without the receiver suddenly cutting out. I can switch between phono and FM and the sound temporarily returns but for only a few seconds. This also happens when I switch between phono and tape mon. I hope it is something that I can fix instead of having to send it back
  • Anonymous Oct 29, 2008
    I Have the same problem. Every thing is fine during a few minutes. Just after it suddenly cut off and there is nothing to do... When I change the source (CD --> Tape or something else) I also have the sound during approximatively 1sec. I don't understand. It seems that the automatic protection is doing its job too often...
Your fuses are blown by possible crossing speaker wire - and + together. I did this and kept turning it on but I ended up frying the unit. Check your wires and make sure that they are seperated properly. If problem continues then unscrew the shell and replace 1 or all 3 fuses (depending on what was blown) with GMA 8 amp fuses. good luck.
Posted on Jan 03, 2009
  • rdera336
    rdera336 Jul 14, 2012
    I'm having a similar problem but I can't even find the fuses. Are they the traditional glass tubes or something different? Any help would be greatly appreciated. Thanks, Ray
I did a system reset by unplugging the receiver from the wall for around an hour. I read this from Harmon Kardon maintenance manual. It worked perfectly for mine.
Iphone6 states "connected" to JBL Charge but no sound. Worked fine up until a few days ago. Both show paired.
Are they connected or paired now? Make sure you don't have any other device near that may have Bluetooth on. Like a laptop, PC,or tablet. Try forgetting the device, and reconnecting. If this fails make sure your phone isn't on wifi and cellular. If this all fails. I imagine its not the fault of your transmitter, but lies in the fault of your reciever, the JBL flip. Also, is it fully charged and is the speaker holding a charge? I'm a small Bluetooth speaker junkie, and I'm sorry but I am not impressed with these at all. There are much cheaper, and better made out there, than this one.
Apr 04, 2015 | JBL Charge Wireless Portable Speaker for...
Hi, I bought a new JBL SCS 140 system with amp HK
Fuses blow when something is shorted. In this case it will be a semi-conductor of some kind. If the device uses IC for the main amplification then you are right to be worried!
The 158 amp is totally unsuitable for the JBL.
This is the specification of the JBL:
  • Recommended Amplifier Power 10 Watt
  • they are also 4 Ohm speakers.
  • 158 is: Output Impedance / Channel
    8 Ohm.
May 31, 2017 | JBL PB10 Subwoofer
I have hk 3390 reciever
What I did is bought a splitter, plugged it in the headphone jack at the back of the iMac. One side goes to my computer external speakers and one to my receivers aux input, or tape one input. I works, just make sure that the volume on your iMac is not higher than half way, or your sound might be distorted and your external computer speakers are off. Not unless you want them on. Keep your iTunes EQ set to flat, that also will create unwanted distortion. Use you receiver tone controls if needed. Hope this works for you, that's how I did it.
Jan 19, 2013 | Harman Multimedia HK 3385 2 Channels...
When hooked up get sound but only with volume turned way up and it is very quiet like its working but no power
Is this a new installation or did this problem just appear spontaneously?
Perhaps MUTE is on. Don't troubleshoot this with the power turned up because you may suddenly find a wrong settign and blow up you speakers.
Dec 25, 2010 | Harman Kardon HK 3480 Receiver
Reciver goes into protect mode as soon as I turn it on.
Remove speaker wires and try again. If it still goes into protect mode, the problem is internal...shorted power transistors or some other fault. Check fuses also.
Apr 01, 2010 | Harman Kardon HK 3480 Receiver
My JBL EON cuts out from time to time (usually when there is a lot of base) and will go back on with a good tap to the side. It has been in for repair and has some solder joints checked and re-soldered. ...
hi there... i have same problem and i believe the main amp (part 339555-001 EON 15 G2) have to be replaced. jbl prosound sell it for $112.80 and you need to do the job yourself, which is not too big deal but not too easy either.
i did not start yet.
please post later if you did it. thanks.good luck. joel.
Dec 01, 2009 | JBL EON 15-G2 Powered DJ Speaker With EQ...
Why does my harmon kardon reciever keep protecting when i turn it on? i checked the fuses.... nothing wrong...?!?
Check the speaker wires.
Make sure your ohm loads are stable especially if you are using more than one pair of speakers to any output.
Check the starting volume.
Nov 23, 2009 | Harman Kardon HK 3480 Receiver
No audio output device installed
If the speakers came with your computer check the Support link at the computer manufacturers website. If you bought them separately then you'll need to check the speaker manufacturers website to see if they have a Vista driver available. Hope this helps.
Aug 15, 2009 | HP JBL Platinum Computer Speakers
Harman Kardon HK 3480 Receiver Logo
666 people viewed this question
Top Harman Kardon Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
