Princeton Digital VL1918  Monitor
Problem for Princeton Digital VL1918 (Black) Monitor
Flickering screen with a claping sound...
By sailor56 on May 23, 2008
read your solution suggestion...
did replacing the three 470 microF capacitors on the Power supply fixed the problem?
I talked to an outfit called www.monitorv.com and they sell a 'repair fit' that 'reuires soldering' - for $25. is there more to it?
V
Comments:
Jun 02, 2008
- Thank you Bob,
I tried and it worked!
a short trip to Radio Shack, $10 and 30 minutes of work - saved my LCD display from a trip to the junk yard.
Greatly apriciated!
Best Solution
posted on Jun 01, 2008
Helpful)
bobjimbo2
Rank: Apprentice
Rating: 97%, 24 votes
From other posts here the repair kit appears to be just the 3 caps and instructions to unsolder the 3 blown caps and replace ( solder back in) the 3 new caps.
Once you get the back off the monitor and start taking it apart you will see 3 capacitors- they are labeled with 470uf25v- it is the only set of 3 caps.- in the power supply ( near where the 110 power plugs in). - Go ahead, take the monitor apart- look for the capacitors- do you see them? If it looks like unsoldering them and replacing them is something you could do- give it a shot, what have you got to loose.
to see pictures of capacitors and to find way more information than you probably want to know - check out www.badcaps.net.
- bad or blown capacitors seems to be a problem with motherboards and evidently monitor power supplies also.
I ordered my caps from Mouser.com- Shipping costs about the same as a gallon of gas and I didn't have to hunt them down.
I ordered their part number 647-UHE1E471MPD6.- There are lot of capacitors of this type listed and honestly I just nearly randomly picked one with the same spec and size- but a different brand since the original ones blew. These fit the existing holes on the board exactly and were the same physical size so they didn't get in the way of any other components when I reassembled the monitor.
look at the caps carefully or take a picture before you remove the old ones, to be sure you get the new ones in correctly- there is a positive and negative on them!
My monitor has been working fine since it was repaired in January- 5 months ago.
Was this helpful?
Yes
No
Solution #2
posted on Oct 24, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Right on! That worked perfectly. $4.45 for the parts at Radio Shack and an hour of my time. The monitor's back up and running now. Thanks so much!
Popular Solutions for Princeton Digital VL1918
Questions and Unsolved Problems for Princeton Digital VL1918
Do you recommend Princeton Digital VL1918 (Black) Monitor?
Answer
Answer
princeton 19 inch LCD blinks and chirps. i need a manual for it ,plus i have anHP pavillion zd7310... (More)
Answer
turn on power monetor flashes off on off ect also how do i install
Answer
I have a Princeton VL1918 Monitor with built in speakers. the volume is to low. how do I increase... (More)
Answer
It is a bit blurry and I want to know if there is a way to adjust the focus, or sharpness. None of... (More)
Answer
Princeton VL1918. Speakers stopped working. Check all connections. Other functionality is OK.
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Monitor Experts
Top Computer & Laptop Repairmen
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
