Question about Xerox WorkCentre PE16 All-In-One Laser Printer
Xerox PE16 cru fuse problem
I have xerox PE16.my problem is cru fuse problem on display.how can i do this problem.
  • Anonymous Apr 04, 2009
    same problem i change the fuse and display the screen cru fuse problem how can i reseeolve problem
Mr jaiku thank you
Posted on Aug 16, 2008
  • 79 Answers
Better u replace a fuser assay..
Posted on Aug 14, 2008
XEROX PE 16 problem cru fuse error on display what is this
Remove copy cartridge. On left top of cartridge there is a glass fuse. replace it with proper rating. it is meant for cart existence
Jan 29, 2011 | Xerox WorkCentre PE16 All-In-One Laser...
Which cartridge is used in workcenter pe16e
Hello
Xerox 113R00667 Genuine Xerox Toner Cartridge for Workcenter PE16E
You can get more information from here
http://www.tonercartridgedepot.com/xerox-workcentre-pe16-5759-d.html
Good Luck, and do rate the solution if got help
Dec 26, 2010 | Xerox WorkCentre PE16 All-In-One Laser...
How to install Xerox WorkCentre PE16 scaner? i ...
How to install Xerox workcentre PE16 scaner?i install twin & driver but not work . Please help...
May 20, 2010 | Xerox WorkCentre PE16 All-In-One Laser...
Display messge cru fuse error
Normally that means the fuser module has failed.
You can order and replace it yourself, I believe they are about $100.
That's what I paid for the last one I replaced.
You can call 1-800-835-6100 and order one.
All you have to do is remove the 4 screws that hold the back cover on, then remove 2 or 4 screws that hold the fuser in. Unplug a couple of plugs and slide in the new fuser. It is really an easy replacement.
Mar 31, 2010 | Xerox WorkCentre PE16 All-In-One Laser...
Windows vista cannot connect to xerox workcenter pe16 networking printer, error not enough memory
not surprised..vista is a nasty program. not enought memory refers to vista not your PE16
try downloading from xerox website..website is useless but try
Nov 17, 2009 | Xerox WorkCentre PE16 All-In-One Laser...
Ow to change resolution in xerox workcenter pe16 scanner
resolution for impression or copie if impression enter from propriété printer if copie you choose it from screen
May 28, 2009 | Xerox WorkCentre PE16 All-In-One Laser...
Error code
NOTE: Some Status codes will not clear even though the problem has been fixed. Status codes that will not clear must be manually reset using the 'Fault Reset 14 Procedure'.
  1. Locate the [C] (Clear) button on the Control Panel, at the far right.
  2. Locate the Image Quality button, below the Auto on the Control Panel, toward the left side.
  3. Press the buttons in the following sequence within 4 seconds. Press [C] (Clear), press [Image Quality], press [C] (Clear) again, press [Image Quality] again.
  4. The error code should disappear. If the Status code does not clear, repeat step 3 until the status code clears; but no more than five times.
  5. Use the [10] and [1] buttons to enter 14 on the Display Screen, as if you were to make 14 copies.
  6. Press the [Start] button. The machine should be ready to use.
  7. Make a copy, to check that the machine is working properly
May 18, 2008 | Xerox WorkCentre PE16 All-In-One Laser...
Xerox workcentre pe16
Remove the back cover. And looking from the back, remove the right side cover. There is a white ribbon cable and one connector with mostly red wires, remove and reseat those. Return power to the machine and see if it comes on.
If not, then remove the right side cover, the 2 screws that fasten the scanner to the frame, remove the scanner and then the controle consol, ( display.) then unplug all the connectors on the display and reconnect them.
It the display still does not work after reseating all the connectors, the display itself is defective.
Mar 13, 2008 | Xerox WorkCentre PE16 All-In-One Laser...
Xerox WorkCentre PE16 All-In-One Laser Printer Logo
1,036 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
