Question about Nokia E63 Cell Phone
When i connect to a wireless network it is telling me no gateway reply. what does dat mean?
    Sergeant:
  • 194 Answers
It means that wireless network is very feable or protected.
Posted on Sep 27, 2010
Im signing up for optimum wifi and the last step to complete it telling me insure my wifi is turn on
It means make sure the wireless router is plugged in and powered on and your wireless connection is enabled on your devices.
Sep 18, 2012 | NetGear WNDR3400 N600 Wireless Dual Band...
My computer can't connect to the internet and i don't know if I lost a driver or I need a new ethernet card?
Hi, to check if your ethernet card is working, follow this instruction to check the presence of your lan card driver.,
For wired/wireless connection,
1. on your desktop right click my computer/properties/hardware/device manager
2. in device manager locate the network adapters, click + sign to expand the content. in your network adapters folder there should be the list of installed driver with no X sign or exclamation mark which means it is installed but disable. If disable, right click the icon and tick the enable option. The presence of the driver is the same with both wireless and wired connection.
The other one is, right click the Network Neighborhood icon on the desktop and select properties, inside the properties it will display, Local Area connection or wireless connection, the one your were choosing must have an status of connected,an icon with two small monitors cascading.
If no drivers installed, Install the driver, if there is hereunder is the next isolation.
The other thing also is to check your connectivity, go to your command prompt and at your c:\ prompt type c:\ipconfig /all then enter, it will display your IP address and gateway.
Ethernet adapter Local Area Connection:
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : Intel(R) PRO/100 VE Network Connecti
on
Physical Address. . . . . . . . . : 00-01-E7-6C34-11
Dhcp Enabled. . . . . . . . . . . : No
IP Address. . . . . . . . . . . . : 192.168.253.111
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Default Gateway . . . . . . . . . : 192.168.253.253
DNS Servers . . . . . . . . . . . : 192.168.253.253
To check if your have internet connectivity type in your c:\ prompt
c:\ping ip address of your gateway {sample c:\>ping 192.168.253.253 then enter, it will prompt like this if connected
C:\>ping 192.168.253.253 -t
Pinging 192.168.253.253 with 32 bytes of data:
Reply from 192.168.253.253: bytes=32 time<1ms TTL=254
Reply from 192.168.253.253: bytes=32 time=1ms TTL=254
if no connection it will display.
Request time out.
Jun 27, 2011 | Dell Dimension 1100 PC Desktop
I am getting an error of 51330 what does that mean?
Hi ahelton239,
51330 - means that you cant connect to the internet. Most likely that you've enter a wrong Network Key or Passphrase.
You need to access your Wireless Settings Page of the Router to get the Network Key or Passphrase. Listed below are the steps on how to access your router. if you don't know the username and password of your router just reply to my answer and provide the make and the model of it.
How to access the Router:
1. You need to know the ipaddress of your router. You can refer to the manual or check the Default Gateway of your computer (Make sure that you connect the computer to the router using an ethernet cable for you to get the Default Gateway). Click on START then RUN. Type CMD on the small box on the lower left of the screen. Type IPCONFIG on the black window and get the value of your DEFAULT GATEWAY (it starts with 192.168.x.x)
2. Open a Browser, Type the DEFAULT GATEWAY on the address bar of your Browser. It will ask you for a username and password. (Refer to the manual of your router or post a reply so that i can provide you the username and password of your router)
3. Go to the Wireless Settings Page of your router. Look for the SSID or the Network Name and the Network Key or Passphrase. You can personalize it so that you can easily remember the details.
4. Make sure you connect to your SSID and enter the Network Key to make it secure.
Rate me if this helps so I can help others. Thank for using Fixya.
Feb 04, 2011 | Nintendo Wii Console
Hello. I have a unique problem. I have a Windows Vista home premium system that can ping to my gateway and other systems on the local network but can not ping beyond my gateway and can not browse the...
If you can PING your gateway, then there was no need for the 'WINSOCK FIX'.
Access the web-server "inside" the router, and look at the table of DHCP clients -- confirm that your computer's "wired" and "wireless" connections are listed, and that they have been assigned IP-addresses.
The router should have its own 'PING' interface, so try PING-ing to 'ns.watson.ibm.com' -- you should get output like:
Pinging ns.watson.ibm.com [129.34.20.80] with 32 bytes of data:
Reply from 129.34.20.80: bytes=32 time=126ms TTL=241
Reply from 129.34.20.80: bytes=32 time=103ms TTL=241
Reply from 129.34.20.80: bytes=32 time=91ms TTL=241
Reply from 129.34.20.80: bytes=32 time=93ms TTL=241
if your router has an Internet connection.
Oct 23, 2010 | HP Computers & Internet
you have to enter that wifi password or set network gateway IP address
Aug 19, 2010 | Nokia E63 Cell Phone
Im trying to connect to a wireless network and it says it is connected but when i open the internet it does not work
check the configuration of your laptop. use another laptop to check the wireless configuration if its working in another laptop...check all possible setting of your laptop..make it fault all if needed
Jun 24, 2010 | Acer Aspire 5050-3242 Notebook
Cant access internet through wireless network.
How do you know your notebook is connected to your wifi AP? Did you try pinging the gateway? If not, open your command window & type "ping 192.168.0.1" (put in your own gateway address.) If you get replies, then ping something outside of your network: "ping 4.2.2.2" (this is a verizon dns server). If you get replies, then "ping yahoo.com". If it does not fail at any of the above steps, you don't have a connectivity problem. If you fail any of the above, then report back & we'll continue the troubleshooting.
Jun 08, 2010 | Acer Aspire 5536-5224 Notebook
Problems with wireless connection - gateway notebook
Might be several things, but perhaps start with checking for any driver updates that might be available.
Feb 11, 2009 | Gateway (802.11usb) Wireless Adapter
No Network Driver Load When I install Win XP Pro...
please check the IP Address i.e,
go to
Control Panel
Network Connections
Local Area Connection (Right Click On it)
Properties
Internet Protocol(TCP/IP) Properties
See whether the
IP Address,Subnet Mask,Gateway,DNS Server Address
is entered properly or not
if it is entered properly go to Command Prompt type the following
Ping ip address and ping gateway address and DNS address
if both are getting reply then connectivity is there no reply means
either the cable not plugged or else cable not poper i.e, RJ 45 Cable (Network cable)
if still not solved try to get the solution from the vendor or else friends or any computer technician nearby to u r home because until some one has to come over there and understand the problem then only we can solve the problem .
Sorry i thought it was a driver problem so therefore i gave the link for drivers
Aug 19, 2008 | Dell Latitude D510 Notebook
Router connecting to Linksys USB adapter
to confirm if your Network adapter's assigned IP, subnet, Gateway & DNS
  • Start > Run > cmd
  • at cmd prompt type: ipconfig /all
  • look at the parameters given to your Network Device that is connected to the router (IP, Subnet, Gateway & DNS Servers.
  • Verify those addresses if they are reachable by pingging. Check your IP, Gateway, then check for the DNS Addresses. Type cmd prompt: ping ip_address << do not omit the periods between the numbers.
  • See if there are replies from those addresses. if you get Request timed out, tell us here which part you get one. if you can receive a reply from those addresses (gateway & DNS Servers) definitely you are already connected to the internet. Just check your Browser's connection setting.
Jul 06, 2008 | Linksys Computers & Internet
Nokia E63 Cell Phone Logo
83 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
