Question about Pioneer 12DISC CHANGER
Pioneer 12disc changer
I just bought a lexus es300 and has a pioneer 12changer in the trunk with a control unit up front. The power comes on and is showing that a disc is playing but no sound. I tried to change to every station to pick it up but no sound yet. Any ideas. Thanks a lot for your help.
    Sergeant:
    Champion:
  • 359 Answers
Try frequency 87.7. Check all speaker wires r connected properly as they could be disconnected. By chance there may have been an amp which has been removed, which will leave u soundless
Posted on May 24, 2008
Can't remove cd cartridge because won't power up.
With the top off the unit, you can turn the tray gears manually for slow eject function. Unplug unit before touching anything inside, check internal fuses.
Sometimes the little ball bearings that keep the cart trays separated come out causing tray jams and shorts.
Make sure your tray retracts all the way into the player flush with the face plate when loading, gently push it in while retracting for those occasional no-read situations. (Also for Denon that takes these same carts). Also note that the CDs go in the Upside Down position.
Applicable to:
Lexus Models: CDX-M9071zt CDX-M8036, CDX-M9071, CDX-M9741, CDX-M9751
also:
Philips CDC-875 Pioneer CDX-FM35 Pioneer CDX-FM45 Pioneer CDX-M30 Pioneer CDX-M40 Pioneer PD-DM802
* Pioneer PD-DM902 Pioneer PD-M403 Pioneer PD-M423 Pioneer PD-M426 Pioneer PD-M450 PD-M453 PD-M455
* Pioneer PD-M501 Pioneer PD-M502 PD-M503 Pioneer PD-M510 Pioneer PD-M530 Pioneer PD-M550 Pioneer PD-M552 Pioneer
* PD-M600 PD-M601 PD-M603 Pioneer PD-M610 Pioneer PD-M630 Pioneer PD-M650
* Pioneer PD-M701 Pioneer PD-M702 Pioneer PD-M703 Pioneer PD-M710 Pioneer PD-M730
* Pioneer PD-M801 Pioneer PD-TM1 Pioneer PD-TM2 Pioneer PD-TM3 Pioneer CCS-430
* DCM-444 and DCM 777
Many Magnavox, Denon, JVC,
BMW 740 OEM and others.
Dec 04, 2009 | Pioneer PD-M426 6-Disc CD Changer
I need an operators/owners manual - the one I have is in Japanese!
Hi Thanks for responding to my request for help. Unfortunately the problem is now academic as the CD head has decided to quit for good. I did find out however from Pioneer that these particular models were only made for the Asian market and it was unlikely that English owners manuals would be available for it.
Cheers
Jun 12, 2009 | Pioneer 12DISC CHANGER
My pioneer cd changer CDX-P1200 doesn't work?
Error 11 means the CD is in upside down, flip it over and it will work like a champ.
Jan 08, 2009 | Pioneer 12DISC CHANGER
Pioneer 12 disc cd changer in car
Try unplugging the unit and then powering it up again, this will make it reset and could release the disc's if not, you could have a lok inside the unit, see if and discs are half loaded.
other than that, send it off to a repair agent
Mark
www.blueice-electronics.co.uk
Nov 25, 2008 | Pioneer 12DISC CHANGER
Panasonic CD Changer with Pioneer reciever
Panasonic CD changers have a specific plug in that will not work with the Pioneer head unit. The Pioneer uses the IP-BUS plug. You will also not be able to convert the unit to work because the data between the two cannot be controlled and you won't have the ability to use the units together.
Sep 12, 2008 | Panasonic CX-DP801 8-Disc CD Changer
No rca jacks
these are designed to hook to a head unit from Pioneer. There are many units that will work if they have a P as part of the unit number. There are some with some cassette units, some with CD units, some with other connections.
Dec 27, 2007 | Pioneer 12DISC CHANGER
No power
You have 12 volts constant on the yellow and 12 volts Switched on the red (when the car is in Ignition/Accessory)? If so, then, yup.... service shop.
Aug 11, 2007 | Pioneer CDX-FM1277 12-Disc CD Changer
Pioneer Premier 12 disc changer static
I would check ground connections. I have had them come loose and introduce a lot of static.
May 04, 2007 | Pioneer 12DISC CHANGER
Pioneer 12DISC CHANGER Logo
77 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
