1. Press Function key
2. Press Data Registration key
3. Press Set key
4. Use (up or down) arrows to select REPORT SETTINGS
5. Press Set key
6. Use arrows to select TX REPORT
7. Press Set key
8. Use arrows to select OUTPUT YES
9. Press Set key
10. At PRINT WITH IMAGE, use arrows to select YES or NO (YES will print the first page of the fax with the report)
11. Press Set key
12. Press Stop/Reset key to exit menu
SOURCE: confirmation Page
Check the link -- if this is the correct device page 44 of the first english manual has the code for changing the confirmation page setting.
http://www2.panasonic.com/consumer-electronics/support/Phones-Fax/Fax-Printers/Plain-Paper-Fax/Copier/model.KX-FG2451
SOURCE: Fax does not print a confirmation page.
Use Function 8 not 6 and use set to lock it in. Lawrence
SOURCE: FAX MACHINE NOT PRINTING CONFIRMATION PAGE
How do you get a confirmtion page after faxing on a Canon 3235i imagerunneer
