Ive got a Alpha combi boiler and it just wont fire up and the prussure needle is below the green mark so ive put that flexey pipe on the two pipes under the boiler to bring the pressure needle back up to were its supposed to be but the needle wont rise so ive got no heating or hot water
  • 56 Answers
There is 2 taps on the filling loop
Posted on Jan 20, 2011
Why does it take two bowls of water before water gets hot on combi boiler
The water isn't maintained hot (unless the central heating is on) in a combi boiler. you will, therefore have to turn the water on, which activates the burner. The burner will then have to heat up the heat-exchanger which then supplies the hot water through cold pipes. Once the pipes are warm, you will receive hot water.
Jan 29, 2015 | Water Water Heaters
After moving my gas meter from inside the home to outside and having a semi concealed meter connected we cant get the combi boiler to work properly we can get hot water and have the gas fire on but
your boiler needs a minimum gas pressure of 16 mb to light successfully. if your gas pipe has been extended it has to be able to flow enough gas. it may need upgrading to 28mm for even as little as a metre from the gas meter. if your central heating works ok when the fire is off then this is your problem
Oct 12, 2014 | Water Heaters
Water pressure low on BAXi Combi 80e boiler
open bottom tap first then open top tap when water is to the leval you want turn off top tap then bottom tap.
Feb 03, 2013 | Heating & Cooling
I want to use my baxi bermuda gas fire just as a fire as having a combi boiler installed is it possible
yes a combi boiler has to be piped so they would cut off the pipes to your baxi and you can ues it as a gas fire only
Nov 06, 2012 | Heating & Cooling
My baxi combi 105he, the red light is flashes on the 30 degrees light which is telling me that the flame failure or the blocked condensation pipe is the problem. i have tried to defrosted the pipe and this...
you can disconnect the white plastic condensate pipe from boiler and just let the condensate water from the boiler it drip into a bucket when the boiler is on untill the pipe defrosts then just reconnect it and make sure the condensate pipe is lagged outside
Dec 09, 2010 | Heating & Cooling
Which is the cold water input to the worester 240 combi boiler . because of the position its difficult to check . Im fitting a hydroflow limescale reducer .from left to right there are 5 pipes is the cold...
HI turn the boiler on to heating and see which pipe gets hot that will be your heating flow the return will be cold at first , then put on hot water only, pipe to hot taps will get hot , water inlet will get cold , you should be able to work it out from that the middle could well be the gas ?
Jan 30, 2010 | Heating & Cooling
Alpha 240e boiler wont fire up for hot water, will for heating
most likely the diverter valve.. when hot tap turned on the movement of the water through the valve operates a diaphragm which pushes a pin/button//switch to tell the boiler to fire up
Aug 21, 2009 | Water Heaters
Alpha H CB33 boiler A and B lights flashing won't start what do i do?
if the pressure gauge is showing below the green mark you need to top up the pressure by connecting the small flexi pipe underneath the boiler then turn the 2 blue taps located either end (slowly though) this will re pressurise the system and it should fire up straight away, hope this helps. KEEP AN EYE ON THE GAUGE THOUGH dont let it go to far above the green bar.
Oct 25, 2008 | Heating & Cooling
Heating & Cooling Logo
332 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
