Question about Linksys Wireless-G WRT54G Router
I cannot connect my kindle3 to Linksys wifi network while my laptops can. Also my kindle3 can connect to other wifi network. Is there any adjustment that I can do with my linksys router to make it possible to conncet with kindle3
  • 62 Answers
Go to Menu. Go to Settings. Go to Wi-Fi settings. Instead of selecting one of the available networks chose Enter other Wi-Fi network. Enter the network (SSID) name. Make sure you pay close attention, it's case sensitive. Then instead of entering the password go to advanced; here you can choose the security type that your router uses. Then enter the password and connect.
That's u are connected
Posted on Sep 27, 2010
  • YOGIBEHR Jan 07, 2011
    I have the Linksys WRT54G ver 5 router. I could not connect even when I turned off the wireless security. I updated the firmware to version 1.02.8 and was able to connect using WPA Personal security and all other settings at default.
I was doing something with my dell latitude d610 laptop key board and i lost the linksys wifi connection...although i came to know through my friend to press fn+f2 key,wifi LED comes on but no wireless...
Most likely configuration problem,Im afraid youll have to get the settings adjusted yourself most netbooks will auto configure unless you manually or by error change the settings.
Good luck
Davey Snake!
Jul 20, 2011 | Dell Latitude D610 Laptop Computer -...
How to connect my Linksys router with my wi tribe modem?? my laptop pick up the wireless signal and can connect,,it says "connected" but when you open a page it says either "invalid server...
The Linksys Wireless router is fine, but your latop is not configured for DHCP (Dynamic Host Configuration Protocol). The computer is connected to the router at layer 2, whereas HTTP (Hypertext Transfer Protocol), sits
atop the TCP/IP (Transmission Control Protocol/Internet Protocol) layer, and seems to be trying to
query the ISP's (Internet Service Provider) network for a nameserver (via DNS (Dynamic Name Service) protocol) that doesn't exist on the ISP's network. Configuring the laptop for DHCP and specifying no nameserver will fix this (the ISP's network will dynamically assign a DNS).
Its also possible (though a remote possibility) that your Linksys wifi router may be configured to disallow TCP/IP virtual circuits to/from your computer's IP address - but this is a really advanced
capability of your Linksys wifi router - few know this capability even exists.
Connecting multiple wifi devices to the Linksys router should be no problem, just configure them all to interact with the router using DHCP.
Jul 04, 2011 | Linksys WRH54G Wireless Router
Can not connect ipad to router
If your Linksys wireless router is already setup with a wireless network, do the following to connect the ipad to the network:
Tap the Settings icon on the home screen of the iPad. Go to General, then Wifi. Once in the wifi section, you should see available wireless networks. Choose the network that is setup on the Linksys and connect to it. Enter the password if you have one set on the wireless network and tap join.
If your linksys is not setup with a wireless network, consult the manual for it to configure it properly.
May 06, 2011 | Linksys Wireless-G WRT54G Router
How to connect new laptop to router
Hello
In order to set up the wireless client, you will need to know the service set identifier (SSID), the Wireless Encryption Protocol (WEP) key and the channel and mode.
Boot up the laptop and plug in the WiFi card. This will not be necessary if your laptop has an integrated WiFi card.
Install any drivers needed to use the WiFi card. Insert the disc that came with the WiFi card and follow the on-screen installation process. Most discs will trigger a new hardware wizard that makes installation extremely simple.
Double-click on the "WiFi Connection" icon. It can be found in the system tray at the bottom of the laptop screen.
Click on "Properties."
Select the "Wireless Networks" tab.
Use the "Add" button at the bottom of the dialog if your WiFi network isn't in the "Available Networks" section.
Click on "Configure" when you see your network's SSID in the "Available Networks."
Enter your network's SSID and WEP key.
Click on "Start," then choose "Connect To" and "Wireless Network Connection." Your computer should now be able to access the WiFi network. If the WiFi network is connected to the Internet, it should also be able to connect to the Internet.
Hope it helps, if so do rate the solution
Good luck
Dec 24, 2010 | Linksys Wireless-G WRT54G Router
Can't install linksys wrt54g2 router with arris tm602g modem
I've tried network magic and everything thing else and I still can't get it to work.
Sep 28, 2009 | Linksys Wireless-G WRT54GS Router...
Lenovo laptop cannot seem to find the linksys wireless g. we have two WIFI at the office one is linksys VOIP (secure) and linksys wireless G (unsecure). why is it that lenovo laptop only sees the secure...
make sure that the linksys VOIP(secure) router is broadcasting it's SSID or signal, otherwise it will not reflect even if you refresh the wireless network. If the router is broadcasting SSID but the lenovo laptop is not detecting it, try to re-install the wireless software for the laptop using the software from lenovo.com, just click Support then Downloads and drivers.
May 13, 2009 | Linksys Wireless-G Broadband Router
When i select my Linksys WiFi connection on my Iphone I still has the "E" edge symbol on my Status bar even though wifi is selected.
You can tell iPhone is connected to the Internet over a cellular data network if you see ht1695_utms_onb.png,ht1695_3b.jpg or ht1695_gprs_onb.png in the status bar at the top of the screen.
Do you have problems connecting to any other wireless network with your iPhone?
Have you tried using the forget this network option on your iPhone for your wireless network followed by trying to connect to the network again, and/or using the reset network settings option on your iPhone which erases all previously saved wi-fi connections that you have successfully connected to with your iPhone?
Let me know....
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Apr 22, 2009 | Apple iPhone 3G
Boost PCMCIA Wifi Card Range
em maybe you just need to change the pc card or honestly just change the pc for fast and efficient browsing.
Jan 21, 2009 | Encore IEEE 802.11b WiFi Wireless LAN...
Cannot connect my wifi laptop to the wireless router
If you use your original Win XP disks, there's a chance you now have XP SP1 (Service Pack 1). Make sure you've made all the necessary Windows Updates as working with WiFi networks was enhanced with XP SP2. Then you can try to find your wireless network and connect to it. If you had a secured network you'll need your previous network key (similar to a password, but without a username, the wireless key is needed to exchange data with the router) If you can't remember the settings on your Linksys you can reset it to factory settings with inserting something into the reset hole to press the hidden buton and holding it for several seconds until lights on the front flash. Then you HAVE to run the initial install procedure (find your CD and Quick Start sheet) because your router will be open and unsecured.
Jan 12, 2008 | Linksys Wireless-G WRT54G Router
Linksys Wireless-G WRT54G Router Logo
305 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
