Question about Ricoh Aficio 450 Copier
Hi there, how is it going? I want my ricoh printer to make it wireless but the problem is there's no slot for wireless port? it is possible to buy a hardware for that??
  • 126 Answers
Sorry mate. there is no wireless option in your machine. its very old model Ricoh machine. I am a Ricoh technician. Even the newer models are not wireless.
Posted on Oct 01, 2010
  • 1,110 Answers
There is no wireless print option available for the aficio 450. Nobody will be making one either as the machine is just getting too old now. Ethernet/Parallel are the only options for printing to this machine.
Thank You for using Fixya.
Posted on Sep 27, 2010
Cannot connect to wireless network
does it have wireless capability? most ricoh/savin/lanier/gestetner machines must have an option installed.
if you have it networked via lan port and have a wireless access point on the same network you should be able to ping the unit and access the gui. if so it is already "wireless" in a sense
Feb 05, 2016 | Ricoh Aficio SP C830DN - Printer - color -...
Set up my rich aficio2015 to run of my computer
either buy a wireless card from ricoh or run a Ethernet cable from router to copier
Jan 26, 2015 | Ricoh - AFICIO 2015 Printer
I have a Ricoh 1013F and I want to make it part of my network so that the other two laptops in the building can print wireless. How can I do this?
You can use a wireless printerserver.
I use the D-Link DPR-2000 multi-port wireless printerserver, this works perfect. It also supports WPA security and wireless scanning, simultanously from 3 printers
There are also cheaper devices, like a Belkin printerserver, that however doesn't support scanning/faxing and is a bit difficult on networks with WPA encryption.
Jul 07, 2011 | Ricoh Aficio 1013F Copier
Hi there My computer crashed and have it up an running again. I am a complete newbie and dont now how to get my Ricoh Aficio AP 400N printer to work again. I went to the ricoh site and downloaded (I...
Please download RPSC driver for needed OS version and then try find do you install the printer on correct printer port (USB or TCP/IP port)
pifonski
Feb 20, 2011 | Ricoh Aficio AP410 Laser Printer
HI I am trying to connect my printer via a router
You need to plug your comuter into one of the LAN Port and the Copier into another LAN port your Modem into toyr WAN port. Then you will need the IP of the router it should com along with the router Info and either be 192.168.000.1 or 192.168.0.1. add an ip spec range Isusualle use 192.168.000.120 this goes into your copier under network protacals in user tools. under the same area setup sub net mask 255.255.255.0 if you have already installed you Ricoh AP3800 Driver place the ip 192.168.000.120 again the 3rd set of numbers either .000 or .001 depending on your router. SO under start menu go to either printer and faxes or control panel right click on printer icon for ricoh AP3800 go to properties select the ports tab, Click add Port select Standared TCP ip Clickm the new port. Click next Add your IP adress for the Copier here. Click next Next window will have Generic network card so press NEXT and then Finished Close printer ports window and then click apply. This should get you printing
May 16, 2009 | Ricoh Aficio AP3800C Laser Printer
I have option to buy ricoh 1013F copier i need it to be wireless
If you already have wireless setup easiest way is to purchase a wireless bridge, gives you wireless connection with hard wired port to connect to the copier. Configure the bridge to same wireless settings as your network and plug cat5 cable from machine to bridge setup print driver and you are golden,
Hope this helps,
TankMurdock
Apr 23, 2009 | Ricoh Aficio 1013F Copier
Network problem with Aficio 1515f
Sounds like you have a wireless router, but are (for some reason) plugging your laptop into it, and if it's not wireless, you should return it and get a wireless one for about the same money, that will let you use your laptop from anywhere, and the setup is often easier, as it can usually all be done via the Installation CD. You can also still plug the Aficio 1515 into the router and print wirelessly to it from your laptop, once you have it configured.
Next, the Aficio 1515 printer feature included a standard usb port, so I find this a little strange.
You can download the manuals here:
http://www.ricoh-usa.com/downloads/manuals/bw/aficio1515/
The 'network settings' guide will be most helpful. The two things you primarily need to be concerned with are the "IP address", and "subnet mask". Do not use "Auto", but rather set them manually, and then configure the printer driver
If you don't have a basic understanding of IP addresses, and network printing, then you'll really need some help to complete the setup
Mar 02, 2009 | Ricoh Aficio 1515F Plain Paper Laser Fax
Ricoh 1022 as network printer?
You can add a wireless print server to it.  Has to be a Parallel based one.  Printing can be done that way but no network scanning can be done if you have that feature enabled.
Sep 17, 2008 | Ricoh Aficio 2022 All-In-One Laser Printer
How do i connect my printer with a usb to a Ethernet (RJ45) cable
Hi Tony,
I assumed you'd like to share the printer on network. I recommend to buy a printer server device that will connect USB port of printer and that device has RJ45 port that can be connected to router or switch hub to share the purpose. Hope this gives you an idea.
Best regards,
Rosener
Jan 31, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
Ricoh Aficio 450 Copier Logo
78 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
SOURAV KAPOOR
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
