Question about LG CHOCOLATE PLATINUM KE800 Cellular Phone
Phone will not start. Battery fully charged. Battery removed then replaced. With the slider open, when I press and hold the on button the screen flashes the KE800 logo and the hidden touchpad keys flash every couple of seconds at the same time. When I release the on button only the hidden keys continue to flash, for a few minutes, then nothing. Previous to this the phone had begun losing basic settings such as menu style after charging a completely flat battery.
    Genius:
  • 1,478 Answers
I think the problem is virus, you will need to flash the phone with a special software that will help reset the phone. Take the phone to any local phone repairer within your vicinity to help use the special software to flash your phone, once the phone is flashed, the problem should be fix.
Take care.
Posted on Sep 27, 2010
My galaxy r don't open again after the battery drained. When I charged it there's sign that it is charging but I cant open once I hold the power button
I don't have that particular phone, but my phone has a small LED in the front that turns to red when it's in the charger with a fully drained battery, yellow when it's above 20% charge, and green when it's fully charged.
If the phone is fully charged, but it won't turn on when you press the power button, there's probably a problem with either your charger or the battery itself. I suggest replacing the battery, or when it's built into the phone itself visit the store where you bought it. They might know what to do.
Nov 26, 2014 | Computers & Internet
Apple id lock on iphone 4s
I assume you mean a key coded lock on the phone. If so, you're going to need to reset all the data on your phone. You're going to need a computer and a sync cable for your phone. On your computer, install iTunes, regardless of OS. Then:
1. Disconnect the USB cable from the iPhone, iPad, or iPod touch, but leave the other end of the cable connected to your computer's USB port.
2. Turn off the device: Press and hold the Sleep/Wake button for a few seconds until the red slider appears, then slide the slider. Wait for the device to turn off.
* If you cannot turn off the device using the slider, press and hold the
Sleep/Wake and Home buttons at the same time. When the device turns off, release the Sleep/Wake and Home buttons.
3. While pressing and holding the Home button, reconnect the USB cable to the device. The device should turn on. Note: If you see the battery charge warning, let the device charge for at least ten minutes to ensure that the battery has some charge, and then start with step 2 again.
4. Continue holding the Home button until you see the "Connect to iTunes" screen. When this screen appears you can release the Home button.
5. If necessary, open iTunes. You should see the "recovery mode" alert.
6. Use iTunes to restore the device.
Mar 02, 2014 | Apple iPhone 4S
My Samsung Corby Pro GT-B5310 is not starting
Hello:
1.Check the device's battery level for at least two bars of strength.
2.If the battery level is low, charge the battery.
3.If the issue is not resolved, remove the back cover.
4.Remove the battery.
5.Wait 10 seconds.
6.Press and hold the W key.
7.While pressing down the W key, re-insert the battery.
•The device restarts and after approximately 15 seconds, the 'Recovery' screen appears
•Release the power button but *continue holding the home button*, for another 30 seconds.
Step
Thanks
Jan 30, 2013 | Samsung GT-B5310 Corby Pro GSM Slider...
Stuck on start up screen, will not go to home screen
5.Wait 10 seconds.
Step
Thanks
Nov 03, 2012 | Virgin Mobile - Lg Optimus Elite Mobile...
Got a black screen ....how do I get back to the previous page?
Hi.
Here are some solutions for your problem provided by apple.
Resolution
If a single application is not responding or freezes when it opens, you can force it to close:
  1. Press and hold the Sleep/Wake button until the red slider appears. When the red slider appears, release the Sleep/Wake button.
  2. Instead of dragging the red slider, press and hold the Home button for six seconds.
  3. If the device does not return to the Home screen, see the steps below to restart.
If the iPad is unresponsive or certain controls aren't working as expected, try restarting the device:
  1. To turn iPad off, press and hold the Sleep/Wake button until the red slider appears.
  2. Slide your finger across the slider to turn off iPad.
  3. To turn iPad on, press and hold the Sleep/Wake button until the Apple logo appears.
If the iPad remains unresponsive or does not turn on (or power on), try resetting the device:
  • Press and hold the Sleep/Wake button and the Home button at the same time for at least ten seconds.
If there is no video on iPad, verify that it has enough charge to turn on:
  1. Connect iPad to the 10W USB Power Adapter with the Dock Connector to USB Cable.
  2. Let iPad charge for at least 20 minutes, then see if it starts up normally.
  3. If there is no image on the iPad screen, press the Home button to attempt to wake the device.
  4. If the iPad screen displays a red battery icon, let the iPad to continue to charge until it turns on.
Aug 28, 2011 | Apple Ipad I-pad
I don't know how to get rid of the speaker symbol in the center of the Itouch screen.
Turn the iPod Touch off and then back on again. Here's how: Press and hold the Sleep/Wake button on top of iPhone for a few seconds until a red slider appears, and then slide the slider. Then press and hold the Sleep/Wake button until the Apple logo appears.
If this doesn't help, try to reset the iPod touch while it is connected to power. To reset, press and hold the Sleep/Wake button and the Home button at the same time for at least ten seconds, until either the Apple logo or battery symbol appears. If the battery symbol appears, continue to charge the device until it is fully charged.
Apr 18, 2011 | Audio Players & Recorders
Ipod is disabled
  1. Disconnect the USB cable from the iPhone or iPod touch, but leave the other end of the cable connected to your computer's USB port.
  2. Turn off the device: Press and hold the Sleep/Wake button for a few seconds until the red slider appears, then slide the slider. Wait for the the iPhone or iPod touch to turn off.
    • If you cannot turn off the device using the slider, press and hold the Sleep/Wake and Home buttons at the same time. When the device turns off, release the Sleep/Wake and Home buttons.
  3. While pressing and holding the Home button, reconnect the USB cable to iPhone. When you reconnect the USB cable to iPhone, the device should power on.
    Note: If you see the screen pictured below, let the device charge for at least ten minutes to ensure the battery has some charge and then start with step 2 again.ht1808_01.jpg
  4. Continue holding the Home button until you see the "Connect to iTunes" screen. When this screen appears you can release the Home button:
  5. If necessary, open iTunes. You should see the following "recovery mode" alert:
Mar 28, 2010 | Apple iPod touch
Iphone 3GS- only get the apple loading screen.
If iPhone won't turn on, or the display freezes or doesn't respond
  1. Press and hold the Home button for at least six seconds, until the application you were using quits.
  2. If that doesn't work, turn iPhone off and turn it on again. Press and hold the Sleep/Wake button on top of iPhone for a few seconds until a red slider appears, and then slide the slider. Then press and hold the Sleep/Wake button until the Apple logo appears.
  3. If that doesn't work, reset iPhone. Press and hold the Sleep/Wake button and the Home button at the same time for at least ten seconds, until the Apple logo appears
More resets:
Try This:
1. Remove Sim Card
2. Hold in 'Home' button and 'On/Off' button together until Apple logo appears
3. Replace Sim Card
4. Hold in 'Home' button and 'On/Off' button together until normal phone screen appears.
Also, Try this:
1.) Shut down the iPhone 3G.
2.) Start up iTunes
3.) Hold down HOME button on the iPhone 3G
4.) While keeping the HOME button depressed, plug in the Sync cable
5.) A message will pop up to ask if you want to reset.
6.) Just click YES and the reset process should start.
Nov 29, 2009 | Apple iPhone 3G
Iphone hangs during standby mode.
More resets:
Try This:
1. Remove Sim Card
3. Replace Sim Card
Also, Try this:
2.) Start up iTunes
Sep 26, 2009 | Apple iPhone Smartphone
Cect p168C will not power on
  1. Turn iPhone off and turn it on again. Press and hold the Sleep/Wake button on top of iPhone for a few seconds until a red slider appears, and then slide the slider. Then press and hold the Sleep/Wake button until the Apple logo appears.
  2. If that doesn't work, connect it to the iPhone charger and let it charge for at least 10 minutes. Note: iPhone 3G does not support FireWire and will not charge from any FireWire-based power source.
  3. If that doesn't work, toggle the ringer switch to see if the unit vibrates. If it does, it could be that iPhone is getting power, but is not displaying any image. (see "Display has no backlight or dark screen" below for further troubleshooting.)
  4. While connected to the iPhone charger, try to reset the iPhone. Press and hold the Sleep/Wake button and the Home button at the same time for at least ten seconds, until either the Apple logo or battery symbol appears. If the battery symbol appears, continue to charge iPhone until it is fully charged.
Oct 16, 2008 | Apple iPhone Smartphone
LG CHOCOLATE PLATINUM KE800 Cellular Phone Logo
37 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
