Question about Dryers
How do I change this belt? Have so far removed back panel and removed the drum. seems a little extreme just to change a belt. Please help. Jamie
    Problem Solver:
  • 10 Answers
You have not said the make or model no.
Posted on Sep 27, 2010
How do i change a belt on a indesit washer machine its a wd 12
Usually there is a back panel that can be removed to give access to the motor and pulley wheel for the drum. If not then remove the top panel and look down the back and you will see the big drum wheel. you will also be able to see the spindle for the motor at the bottom. Reach down to the motor and hook the belt around the spindle and place as much of it as possible on the pulley then turn the wheel to pull the rest of the belt on. It can be a little tricky but the only other way is to completely remove the back half of the machine. If you get stuck try www.espares.co.uk and check the advice centre, it gives a video on how to change a belt, most machines are similar. Hope this helps.
Mar 02, 2011 | Indesit WA 115 Front Load Washer
Hi i am trying to fix my belt on a beko condenser dryer as the old one has snapped can you help me please.
remove all the screws from the back panel and remove the heater cover (shaped inner panel fastened to the back panel).remove the cir-clip from the drum shaft and you will be able to pull the back panel away far enough to drop the belt down between the drum and back panel.refit in reverse.take the cover plate off the back/bottom right corner and using a tube or screwdriver,stretch the belt over the motor pulley.refit cover plate.job done
belt diagrams:
http://www.applianceaid.com/images/belt-config.JPG
Jan 08, 2011 | Dryers
Change drier belt on model number 41794702300 Kenmore stackable
1. UNPLUG UNIT. 2. On the front of the unit, remove two screws from the bottom panel. Remove it and you will see two screws holding the top panel and door in place. 3. Remove the screws and gently pull up and out on the door panel, INSURE NOT TO PULL ON THE WIRES LEADING TO THE DOOR SWITCH. 4. Remove wires from door switch. MAKE SURE TO NOTE WHICH WIRES CONNECT TO WHICH TAB. 5. Set door aside and you will have complete access to drum. Remove old belt, if necessary, noting now it is around the drum and weaved through or around the tension bar below the drum. 6. Once removed, or if there is no belt, or a broken belt, put the new belt around the drum so that the slack hangs below the drum. NOTE: You will probably see a black mark around the drum where the belt has laid, about in the middle of the drum. Lay the belt on that path. 6A. Lay on your back with both hands available, raise drum slightly to get access to the belt. Take slack in belt, raise tension bar slightly out of the way, bring belt UNDER the pulley on tension bar and put it around the pulley/spindle on the motor. (This may take another hand) Slowly lower tension bar back down to make contact with belt, applying tension to belt. 7. Get the door panel and reconnect the door switch. 8. Start to put door panel in place, while slightly raising drum to fit into position, careful to the raise to high or **** drum out of position off the back rollers or cause belt to slip off. Push door panel into place and put screws in. 9. Once you've got the door secure, test the belt by reaching inside and manually turning the drum clockwise until it seems to turn easily with not bumps. This is allowing the belt to settle into place and insuring it is not going to pop off; if it does, repeat the operation. If it turns easily, move on to... 10. Replace lower panel. 11. Plug in unit and test to insure drum moves freely. If not, you may need to readjust the way the door panel fits in place with the drum, or the belt on the tension bar. 12. If you need further help, please let me know.
Good luck. It's simpler than it sounds. G
Aug 02, 2010 | Kenmore 77062 Gas Dryer
Dryer wont tumble the belt has come off and also the spring system, ho can this be fixed?
Follow the bellow steps in order to replace the belt:
  1. Safety first! Unplug the machine from the wall-socket and make sure the machine has been idle long enough so that the heater elements, etc. have cooled.
  2. 180px-p3090017.jpg magnify-clip.pngTop cover removalRemove the top cover of the machine by undoing the 2 bolts at the back of the top panel.
  3. 180px-p3090016.jpg magnify-clip.pngTop cover removedYou should now be able to see if the belt is broken or not. It should be wrapped around the back of the drum. In this picture, you can see it has snapped and is loose on the drum.
  4. 180px-p3090047.jpg magnify-clip.pngRemove plastic coverRemove the plastic cover at the bottom rear of the machine and take off the black belt going from the red pulley to the white pulley (this turns the fan).
  5. 180px-p3090019.jpg magnify-clip.pngAir-flow coverAt the back of the machine, undo the 5 or 6 bolts securing the air-flow cover...
  6. 180px-p3090020.jpg magnify-clip.pngAir-flow cover removed...revealing the drum securing e-ring and washers.
  7. Remove these and keep them in a safe place for now. 180px-p3090023.jpg magnify-clip.pnge-ring & washers
  8. 180px-p3090034.jpg magnify-clip.pngdrum and back panelThe drum is no longer holding in the back panel of the machine.
  9. 180px-p3090037.jpg magnify-clip.pngBack PanelUsing a 7mm socket wrench, remove the screws holding in the back panel of the machine. Take care to support the panel (and the drum) as the screws are removed. A second pair of hands is useful here!
  10. 180px-p3090025.jpg magnify-clip.pngBack panel removalTaking care to support the drum, move the back panel away from the machine slightly. Do not move more than a few inches yet!
Jul 14, 2009 | Dryers
How do i change my tumble dryer belt on a beko thanks
Just changed the belt on a Beko DRCS68W and its a real pig! Remove the top panel and loosen all screws on complete back panel having removed circlip holding the drum spline on to the back panel. You will also need to disconnect wires/leads on top right inside panel to give you more space. Once you have done this you should be able to ease away the back panel far enough to get the new belt around the drum and over the drum spline in the middle. Then the tricky bit - getting the belt tensioned on to the motor drive spline. I did this before securing the drum and back panel, which gives a bit more flexibility. I also used about 15ins of 15mm copper pipe to ease the belt down over the motor spline. Hard part was getting the back panel back lined up with the screw holes as the belt tension distorts the casing. Finally hit on the idea of lying the machine on its side so the weight of the drum is pulling away from the motor and helping to line up the screw holes. Two and a half hours later job done! I guess if I ever did another it would be a whole lot easier but still not the type of job I relish!
Mar 06, 2009 | Dryers
Can't Put Belt On
You have to remove the front of the dryer to
access the drum. First unplug the dryer.There are screws at the bottom of the front to remove the lower section. Once you remove that you can get to the screws for the door section. The front of the drum rides on the inside of the front panel so when you remove the panel the drum will drop down. Try to keep the drum in place with something to hold it up. Remove the old belt and place the new belt around the drum. Slid the belt back to where the belt used to ride and then loop the belt around the motor and the tension wheel. Make sure the tension wheel is tightening the belt. Hold up the drum and put the front panel back on. You may need a helper to hold things while you do this. Rotate the drum by hand and make sure it moves smoothly. Plug it back in and give it a try. I hope this helps. Any questions feel free to ask. Please rate me so I know if I'm Helping. Thanks.
Dec 30, 2008 | Frigidaire FEQ1442ES Electric Dryer
Dryer belt replacement
Take the top panel off by slideing a putty knife about 2 inches in at the front and releasing the tabs. remove screws from top of front panel after top removed. also remove 2 screws from inside of front panel on both sides about 4 inches down screwing back into front panel. pull front off and slip belt through opening. Feed belt around drum and put tension on the idler spring release onto belt. reassemble unit.
Aug 09, 2008 | Frigidaire AEQ7000ES Dryer
My Hotpoint Aquarius WF210 washing machine drum is not rotating
I think the belt has come off or has been damaged.
To open the machine slide out the machine. On the back panel lower 1/3 you will see a plastic panel remove the screws and the panel will come away. Inside you will see the belt. I suspect you will need to reattach the belt of remove it and buy a replacement.
Sin é
Jan 13, 2008 | Hotpoint Aquarius WF210 Front Load Washer
Asko T700 loose belt, access from front?
I think you must replace the belt and the tensionarm. It MUST be done from the backside of the machine... Remove the backpanel, and the drum, change the tensionarm, and put the drum into the machine again. Put on the new belt, and mount it together again. Be careful for sharp edges! Hope this helps :-)
Jan 12, 2008 | Asko T700 Electric Commercial Dryer
Creda
remove the rear panel screws, remove side panels, pull drum backwards, slide belt down front of drum and under, refit rear panel screws refitting drum at the same time, place belt around motor spindle and reasemble, job done.
Dec 24, 2007 | Washing Machines
Dryers Logo
Top Dryers Experts
