Question about Nikon Coolpix 5600 Digital Camera
Camera was in use to Jan 2010. Not used since but now does not switch on wioth new batteries and memory card. Green light by on/off switch flashes 2 times or 3 times.
  • Nikon Master
  • 19,396 Answers
Hi.
Ensure that the camera is not in PC mode. Turn wheel to camera mode when starting.
After you are sure that the problem is not setting related, try gently slapping the back of the camera while turning on the camera with lens facing toward the ground to help lens out. After some month the lens may be stuck, that is not uncommon problem and can be caused by dust or dirt.
If that does not work, call Nikon at the number listed on manual, or get a quote from third party here:Repair.
First try troubleshooting above.
Posted on Sep 27, 2010
My Polaroid iE 3035 camera switches off as soon as I switch it on. It has new batteries in it. There is a green light flashing at the back
A flashing green light can mean it has problems accessing the memory card.
Check the card is not Locked and if all con acts are clean and shiny.
Never use zinc carbon batteries, not even new ones, because they can't give enough power. The best are NiMH rechargeable batteries of a camera.
Contacts can be cleaned with a dry cloth or cotton swabs. Never use sharp toosl in or close to a camera.
Aug 04, 2014 | Cameras
Card error light flashing green
When the camera accesses the memory(card) a green LED will burn or flash. When it can't do what it wants, it will warn you.
A memory error, can be caused by lots of things. Like card full, card physically damaged, file system damaged. Too many folders, too many pictures. Wrong card (SD, SDHC or SDXC) cannot be used in every camera.
Check if you did put in the card correct (not the wrong way around) Check if all contacts on the memory card are clean, shiny and straight. Check if you did not switch the lock switch to the wrong position. Check if there are still pictures on the card, in an external memory card reader. put all the pictures you can find on the computer and than try to format the card. (in the computer, FAT 32) but after you put it in the camera. do a format in the camera too.
Success
Mar 05, 2014 | Samsung L200 Digital Camera
Canon t3i will not turn on without sd card?
This a situation the manual not even mentions. The red light on the bottom right of the camera is the memory access indicator. It should light green as I remember ok. And blink when it is writing to or reading from the memory. If it is red, it means : this is not ok.
This light is not a gadget. It should be taken serious. As long as it is burning, of flashing you are not supposed to switch of the camera or to remove the memory card. If you still open the memory compartment or switch of the camera or remove the battery, while the camera indicates I'n accessing the memory, serious damage can occur to the memory card.
You could lose all your pictures, because of it.
I would suggest, make sure your battery is charged correctly.
Format your memory card in a PC with FAT 32.
Check if al contacts in the camera are clean and shiny. (Battery and memory card contacts too)
The place the battery and the memory card in the camera and try switching it on again. If it should start, first do a format of the memory card in the camera before you starts taking pictures, of the camera has its own format and can make a folder.
You should be able to switch on the camera without a memory card inside. The camera will us the internal buffer, to let you take a picture in DEMO mode.
I hope the red light does not indicate your internal memory is corrupted. Because if nothing helps and the red light comes back, I think you should contact a Canon service centre.
Jan 14, 2014 | Canon EOS 600D Rebel T3i Digital Camera
Nikon D90 flashing green light runs down battery even in power off mode.
Possible short to the top cover circuit around and including the on/off switch - spillage, wear of switch.
Apr 06, 2012 | Nikon D90 Digital Camera with 18-105mm...
I mistakely deleted pictures from my camera (Kodax Esay Share M340) Move picture to internal memory.How can i get the pictures back
If Try one or more of the following
Ready light does not turn on and the camera does not work.
Ready light blinks green.
  • Camera is operating normally.
Ready light blinks amber.
  • Wait. Resume picture taking when the light stops blinking and turns green.
Ready light blinks red and camera turns off.
Ready light glows steady red.
Ready light is off or glows steady green.
Mar 10, 2011 | Kodak Cameras
Camera does not turn on
It might be a battery issue: Please try the following: 1. Make sure you will install a new or fully charged battery/batteries into your camera. Please use lithium batteries Ni-Mh or rechargeable Batteries (2000 M.Amp or higher). 2. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera 3. Turn on your camera without the memory card. (If it works then it?s your memory card that is faulty)
Jan 23, 2010 | Kodak EasyShare CX7525 Digital Camera
My camera worked very recently, as I took pictures on a camping trip. However, a few days later after getting back, I've found that it refuses to turn on. If I turn it to either Video or Photo, the light...
Here are the steps for the no power problem: 1. Make sure you will install a new or fully charged battery/batteries into your camera. Please use lithium batteries Ni-Mh or rechargeable Batteries (2000 M.Amp or higher). 2. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera 3. Turn on your camera without the memory card. (If it works then it?s your memory card that is faulty)
Jan 07, 2010 | Kodak EasyShare CX6200 Digital Camera
I've replaced the battery (again) but the lenses still won't come out, even though there is power, the music plays, and the green light flashes. I have the docking station and printer and really don't want...
Dec 29, 2009 | Kodak EasyShare CX7430 Digital Camera
My m340 will not turn on. the small green light flashes once then nothing
Here are the steps: 1. Make sure you will install a new or fully charged battery/batteries into your camera. 2. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera. Please make sure that you are installing a fresh/ fully charged battery c. Without the memory card, turn your camera on. 4. Please test with the a different battery If you do not have access to another battery Try these steps instead: Please take the battery out of the camera. b. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the battery. If you camera doesn?t switch on you will need to order a No power repair or a new cable. In order to organise your repair or Trade up please Contact KODAK: http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Dec 10, 2009 | Kodak EASYSHARE M340 Digital Camera
My kodak m883 green light flashes when turning on
Pls. use lithium batteries Ni-Mh or rechargeable Batteries (2000 M.Amp or higher).
Battery support : KAA2HR,CRV3, 2xAA Ni-MH and 2xAA Lithium-Ion
Here are the steps:
3. Without the memory card,turn on your camera.
Contact KODAK:
Nov 17, 2009 | Kodak EasyShare M883 Digital Camera
Nikon Coolpix 5600 Digital Camera Logo
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
