Question about KitchenAid Ice Cream Makers
Hello, I have a Kitchen aid ice cream maker Model 5KICAOWH for approximately 1 year. Since about 3 months, the bowl is leaking blue liquid from within the small depressed area where the dash resides at the bottom. What could have caused this? Is there anything that can be done to fix it? Otherwise we have enjoyed our homemade ice-cream very much and are disappointed with these developments. I hope that you can help and I am looking forward to your advice. Thanks, Barbara Link
2 Suggested Answers
  • 19396 Answers
SOURCE: Hello. Approximately one year
That means that the sealing was allowing liquid getting inside the attachment gears, and now it is leaking lubricant from the ice cream attachment. I don't think that the unit can be repaired, the ice cream attachment is all in one block, and I have not seen any part being distributed.
This small appliances have 12 months factory warranty, call Kitchenaid after registering the appliance, you may still be able to validate the warranty. If warranty is gone, complain that the problem was due to factory defect and try to get a part exchange with reduced price on new replacement, or , since warranty expire recently, see if you can buy an extended service plan.
See: Customer Care
Posted on Sep 27, 2010
Problem with my chocolate side. Will not remain as firm ice cream. Becomes liquid ice milk. I turn chocolate side off. After I turn back on it may still be liquid but not firm ice cream.what can I do?
Homemade Ice Cream Mistakes-and How to Avoid Them ...
Bon App?titJul 30, 2014 - Ice cream machines are easily found and affordable, so procuring the ...Once ice cream is properly chilled, it should be firm but not a solid, ...
5 Mistakes to Avoid When Making Ice Cream - Cooking ...
Apartment Therapy's The KitchnJul 20, 2015 - Not letting the ice cream maker bowl get cold enough. ... churning away in the machine, this process doesn't end with the firm, super scoopable ...
Will a new ice cream maker make my ice cream set firmer ...
Feb 12, 2014 - I've been making ice cream at home for a few years now and tend to have pretty mixed results with how firm my ice cream gets. Even with all ...
Jan 10, 2016 | Ice Cream Makers
What is a recipe for this ice cream maker
What make and model is "this" ice cream maker?
Mar 09, 2013 | Ice Cream Makers
Blue liquid leaking from ice cream attachment
I have been debating as to whether to buy one of these ice cream units but it appears it would be a big waste of money. I wonder how to track if Kitchenaid has made improvements to fix the flaw in the unit.
May 03, 2012 | KitchenAid Kitchen Aid KICAOWH Ice Cream...
I need to down load a manual for ge ice cream maker model 106765
  • 1
    Place the mixer bowl in the freezer. The amount of time required depends on the temperature of your freezer, but you should expect to leave it in the freezer for about one day prior to use. To check if the bowl is frozen, shake it gently. If you don't hear any liquid sloshing around inside, it's ready to use.
  • 2
    Place the mixer bowl onto the motor base when you're ready to make ice cream. Insert the mixing paddle into the bowl and place the cover over the bowl.
  • 3
    Turn on the ice cream maker and pour the ice cream mixture into the hole at the center of the appliance until it reaches the fill line. Do not exceed the fill line, as the ice cream will increase in volume as it freezes. Use the low setting if you want a firm ice cream and the High setting if you want a softer consistency. Do not add nuts, candy or chocolate chips at this stage as they can become hung up in the mixing paddle and stop the machine.
  • 4
    Cover the center hole with the cap and allow the ice cream maker to run for 30 to 45 minutes.
  • 5
    Add mix-in ingredients such as nuts and candies two minutes before shutting down the machine.
  • 6
    Turn off and unplug the machine prior to removing the ice cream from the bowl. GE recommends using plastic or rubber utensils to avoid scratching the inside of the mixer bowl.
  • Read more: GE Ice Cream Maker Instructions '
    Sep 09, 2011 | Gel Canister 106765 1.5 Quart Ice Cream...
    Villaware model 5100 ice cream maker bowl corroding.
    I would say contact the manufacturer. Most retail stores will not sell parts like this (and if they do, it's probably a store that will be something like a kitchen specialty store--aka, a little more pricey), so the best way to go is to contact them directly so that they can get it for you (and, a lot of times, they can get it for you at a cheaper price, or, if you're under warranty, sometimes for FREE!!).
    Their contact number should be either stamped somewhere on the machine (usually on the bottom--might be stamped directly into the plastic, so make sure you have it in really good light when trying to read) or in the product manual (usually near the back of the book).
    Good luck! :)
    Aug 21, 2009 | VillaWare 5100 1 Quart Ice Cream Maker
    Cuisinart Ice Cream Freezer Bowls Not Freezing Anymore
    I would take the freezer bowls out of the freezer, run them both under the sink to thaw both bowls out, dry both bowls thoroughly, and then set them both on the counter so that the liquid settles toward the bottom of the freezer bowls. After 1 hour, place the bowls FLAT back into the freezer - don't forget to wrap them in a plastic grocery bag or some other sort of plastic bag. Try to make ice cream again after 24 hours or more of freezing. Let me know if this works, so I can pass the good news along to others.
    Aug 03, 2009 | Cuisinart ICE-20 Automatic Frozen Yogurt...
    Not setting / freezing - bowl in freezer 24 hours *
    The ice cream mix has to be xconstantly stir in a nrine solution, That's why they have motorized ice cream makers that rotate the can surrounded by ice and salt.(brine) while a paddle inside stirs it. Good luck and enjoy.
    Jun 01, 2009 | Disney Ice Cream Maker
    Ice cream maker instructions
    I have the booklet for this machine.
    1) you can use any IC recipe as long as it does not exceed 1 quart. This is for vanilla:
    1/2 c sugar
    1 1/4 c half&half
    1 1/2 c heavy whipping cream
    2 eggs 2 tsp vanilla
    with mixer beat eggs and sugar until thincl and cream colored. Addthe cream and vanilla mix well.
    the machine:
    you want to put the freezer cylinder in a plastic bag (to prevent freezer burn) and then put it in the back of your freezer until completely frozen 6 to 22 hours. You should not be able to hear liquid slosh when you shake it. For making stuff quick they recommend keeping it in the freezer in the bag.
    step one: Put maker on flat surface.
    two: Put the mixer bowl on the base.
    three: Place frozen cylinder into to the mixer bowl (the big one) do this when you are ready to start the IC because the cylinder begins defrosting right away.
    four: set the paddle on top of the cylinder, placing the peg on the freezer cylinder inside the peg hole on the paddle
    five: Place the cover over the mixer bowl, locking the grooves on the motor base. Plug in, turn on, the bowl and cylinder will begin to turn.
    six: Pour the recipe into the feeder hole of the cover then put the lid on.
    You will need 20 to 40 minutes or until mixture is frozen. Don't stop the machine until done. If you want hard ice cream spoon the soft serve into an airtight bowl and put it in the freezer till it is like you want it.
    Hope this helps, Elizabeth
    May 17, 2009 | Ultrex Double Canister 2 Quart Ice Cream...
    Ice Cream not freezing
    Yes, they stop working sometimes. Same thing happened to me.
    The Cuisinart ICE-20 bowl is precisely the same, and works with the Krups 337. You can buy the Cuisinart bowl separately. It costs nearly as much as the whole machine, but what can you do.
    Jun 26, 2008 | Krups 358-70 La Glaciere 1.5 Quart Ice...
    Ice Cream Makers Logo
    305 people viewed this question
    Top KitchenAid Ice Cream Makers Experts
    Andrew Taylor
    Andrew Taylor
    Are you a KitchenAid Ice Cream Maker Expert? Answer questions, earn points and help others
