Hi i'm looking for user instructions for an old style switchmaster 950 heating and water timer system. Thanks
  • 4 Answers
Posted on Aug 15, 2012
  • 3,740 Answers
Try contacting them here:
Invensys Climate Controls Europe
Telephone: +44 (0) 845 130 5522
Facsimile: +44 (0) 845 130 0622
Technical Helpline: +44 (0) 845 130 7722
Website: www.climate-eu.invensys.com
Email: customerservices@invensys.com
Just a note... I did not find a SM 950 but did manage to locate a SM 980
The website above links straight to This link: http://www.draytoncontrols.co.uk/content.aspx?id=2649
Under documentation they have programming instructions for the SM1 and SM2 that mention the SM980 under SM1 mechanical time switch here:
http://www.draytoncontrols.co.uk/supportingdocuments.aspx?id=1504#
This may not be what your looking for. If not just don't rate the post please.
Kelly
Posted on Sep 27, 2010
Can anyone tell me where I can purchase this part
Hi Ian, i have these switches, usually for the old style 900/950 kangos. My email is prax55@hotmail.com, if you would like to see pictures then please put kango switch in ebay search bar and it should come up first or near the top. Hopefully it's the one you want. Look forward making contact with you. Kind regards
Apr 22, 2016 | Hammering
How do I set the timer on my sm300 switchmaster
http://waterheatertimer.org/How-to-set-timers.html
Analog timer/ set trippers and manually rotate dial to experiment with timer operation
Gene
Oct 17, 2014 | Hardware & Accessories
Just moved into a new house with old heating system. not sure what some of the switches do? or how to set up heating & hot water timer etc?
Need to know a few things first. What kind of heating to you have? Fuel used to heat? Instructions on setting things up are available online from the manufacturer.
Oct 15, 2014 | Hardware & Accessories
Please where can I get an instruction manual for a Switchmaster 400 central heating timer?
SERVICEMANUALS @ COST www.mauritron.com Manuals at free download: homeappliance.manualsonline.com/manuals/.../lg_air_conditioner_product_list.html
Dec 24, 2010 | Heating & Cooling
User guide needed for old Honeywell programmable heating control
It depends on your system some will only work with hot water on and heating do you have two zone valves?
Jul 18, 2017 | Honeywell TH4210D1005 Heater
Need a manual for drayton tempus 3 heating control
I've ended up with a Drayton Tempus 3 when I bought my house, and I think this is how it works. It allows you to set 2 Timers (I'll call them timer 1 and timer 2) so that you can control Hot Water or Heating On/Off times twice a day. The unit has 6 buttons - 2 for Adjustment, 2 for Hot Water and 2 for Heating. The 2 Adjustment buttons allow you adjust the Clock Time, or allow you to adjust Timer 1 and/or Timer 2. NOTE: Timer 1 is the time refered to on the Heating / Hot Water Select buttons if you press "Once". If you select "Twice" on these the both Timer 1 and Timer 2 are taken into account. For example if you want Hot Water to come on Once between 8pm -10pm, but you want Heating to come on Twice between 6am - 7am, and 8pm -10pm, you have to do the following: Set Timer 1 to 8pm - 10pm, and set Timer 2 to 6am -7pm. Then select Once for Hot Water, and select Twice for Heating. Hope this helps.
Mar 23, 2009 | Water Heaters
Frigidaire dishwasher not completing cycle.
hi,
The cycle doesn't complete
If the cycle doesn't complete, check these:
Water-heating cycle
Timer
Water-heating cycle
Many dishwashers heat the wash and/or rinse water to a higher temperature, as the cycle calls for it. In these cycles, the dishwasher pauses after it has filled with water, waiting for the water to reach the pre-set temperature. What happens next, depends, as follows:
On some units, the pause is timed and the unit continues after the allotted time.
On others, the cycle can't continue until the water reaches the higher temperature. If you have this type of dishwasher and the water isn't being heated (say, because of a problem with the heating element or thermostat), after the unit stops at the heating cycle, it never continues. When you repair the heating-system problem, the "cycle problem" is fixed too.
Timer
Timers don't often fail. But if every other part of the dishwasher seems to be working properly and the timer knob seems to be stuck in one place--doing one function continuously--the timer may be at fault. Dishwasher timers can't be repaired. If yours is defective, replace it.
I see an error code
If your dishwasher has a digital readout and you see an error code, it may indicate a problem with the unit. If this happens, look up the error code in your owner's manual to find out what the problem is.
Good Luck
Thanks for using FixYa
Jan 03, 2009 | Dishwashers
Please I need a timer for a Potterton timer EP2003
Dear dm:
Sory to know about your father.
I think the best to do in this situation , if you can afford it, is to look for a certified electrician to take care of that timer . May be you will have to buy a new, "user friendly timer" to control your water system.
Hope this helps.
emiliosan
Dec 27, 2008 | Hardware & Accessories
Heating & Cooling Logo
522 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
