Question about Sharp AL-1457 Black and White Copier
What does a flashing code L1 mean - Sharp AL-1457 Black and White Copier
  • 1,110 Answers
L1 or L1-00 indicates Scanner movement failure. The scanner is the part under the glass that lights up and moves back and forth. So if you lift up the feeder so you can see the glass, turn the machine off for a few seconds then back on. Watch the movement of the scanner. It should move right and inch or two then back to the left. If all goes well the copier should come to ready. Lay a piece of paper on the glass and press the print button to watch the scanner movement. If it binds up or does not scan correctly there are 2 possibilities.
1) your scanner lock is engaged and is preventing the scanner from moving. Check the clear plastic dial located under the far left upper side of the copier, near where the paper exits the machine. Make sure it is in the unlocked position.
2) Your scanner rail is dirty and dry. This rail can be seen under the glass towards the back of the copier. The scanner rides on this rail. It is very common for these to get dirty and for the grease to dry up causing the scanner to freeze up on the rail. The glass must be removed and the rail cleaned and lubricated.
Just power off then on the copier to reset.
Good Luck and Thank You for using Fixya.
Posted on Sep 27, 2010
Why does remote UMC-117 flash error code 11 and then L1?
Multiple error codes can mean bad PC board.
C11 is combustion, vent or gas issues
L1, heat exchanger needs delime.
Catch unit up on required maintenance each year.
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html#error
Gene
Water Heater Timers Save Money
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Jun 17, 2014 | Rheem Tankless Water Heater Main Remote...
Ps2 gta cheat codes san
Here is a list of cheat codes for Grand Theft Auto: San Andreas on the PlayStation 2.
$250,000, Full Health And Armor
Cheat code: R1, R2, L1 , X, Left , Down, Right, Up, Left, Down, Right, Up
Aggressive Drivers
Cheat code: Right, R2, Up, Up, R2, Circle, Square, R2, L1, Right, Down, L1
Aggressive Traffic
Cheat code: R2, Circle, R1, L2, Left R1, L1, R2, L2
All Cars Have Nitros
Cheat code: Left, Triangle, R1, L1, Up, Square, Triangle, Down, Circle, L2, L1, L1
All Pedestrians Are Elvis
Cheat code: L1, Circle, Triangle, L1, L1, Square, L2, Up, Down, Left
All Taxis Get Nitro + Jump Up When You Press L3
Cheat code: Up, X, Triangle, X, Triangle, X, Square, R2, Right
Junk Car Traffic
Cheat code: L2, Right, L1, Up, X, L1, L2, R2, R1, L1, L1, L1
All Traffic Lights Stay Green
Cheat code: Right, R1, Up, L2, L2, Left, R1, L1, R1, R1
All Vehicles Invisible Except Motorcycles
Cheat code: Triangle, L1, Triangle, R2, Square, L1, L1
Always Midnight (Time stays at 00:00)
Cheat code: Square, L1, R1, Right, X, Up, L1, Left, Left
Andrenaline Mode
Cheat code: X, X, Square, R1, L1, X, Down, Left, X
Blow Up Vehicle
Cheat code: L1, L2, L2, Up, Down, Down, Up, R1, R2, R2
Attracts Prostitutes With *** Toys
Cheat code: Square, Right, Square, Square, L2, X, Triangle, X, Triangle
Black Traffic
Cheat code: Circle, L2, Up, R1, Left, X, R1, L1, Left, Circle
Nearest Pedestrian Called to Get In Car
Cheat code: X, Square, Down, X, Square, Up, R1, R1
Cars Float Away When Hit
Cheat code: Square, R2, Down, Down, Left, Down, Left, Left, L2, X
Cars Fly
Cheat code: Square, Down, L2, Up, L1, Circle, Up, X, Left
Cars On Water
Cheat code: Right, R2, Circle, R1, L2, Square, R1, R2
Chaos Mode
Cheat code: L2, Right, L1, Triangle, Right, Right, R1, L1, Right, L1, L1, L1
Clowny Themed Area
Cheat code: Triangle, Triangle, L1, Square, Square, Circle, Square, Down, Circle
Commit Suicide
Cheat code: Right, L2, Down, R1, Left, Left, R1, L1, L2, L1
Destroy Cars
Cheat code: R2, L2, R1, L1, L2, R2, Square, Triangle, Circle, Triangle, L2, L1
Bikini Themed Area
Cheat code: Up, Up, Down, Down, Square, Circle, L1, R1, Triangle, Down.
Faster Clock
Cheat code: Circle, Circle, L1, Square, L1, Square, Square, Square, L1, Triangle, Circle, Triangle
Faster Gameplay
Cheat code: Triangle, Up, Right, Down, L2, L1, Square
Flying Boats
Cheat code: R2, Circle, Up, L1, Right, R1, Right, Up, Square, Triangle
Foggy Weather
Cheat code: R2, X, L1, L1, L2, L2, L2, X
Full Weapon Aiming While Driving
Cheat code: Up, Up, Square, L2, Right, X, R1, Down, R2, Circle
Gang Members Spawn Much Faster
Cheat code: Left, Right, Right, Right, Left, X, Down, Up, Square, Right
Six Star Wanted Level
Cheat code: Circle, Right, Circle, Right, Left, Square, X Down
Hitman In All Weapons
Cheat code: Down, Square, X, Left, R1, R2, Left, Down, Down, L1, L1, L1
Improve Suspension
Cheat code: Square, Square, R2, Left, Up, Square, R2, X, X, X
Increase Car Speed
Cheat code: Up, L1, R1, Up, Right, Up, X, L2, X, L1
Infinite Ammo
Cheat code: L1, R1, Square, R1, Left, R2, R1, Left, Square, Down, L1, L1
Infinite Health
Cheat code: Down, X, Right, Left, Right, R1, Right, Down, Up, Triangle
Infinite Lung Capacity
Cheat code: Down, Left, L1, Down, Down, R2, Down, L2, Down
Insane Handling
Cheat code: Triangle, R1, R1, Left, R1, L1, R2, L1
Spawn Jetpack
Cheat code: Left, Right, L1, L2, R1, R2, Up, Down, Left, Right
Jump 10x Higher
Cheat code: Up, Up, Triangle, Triangle, Up, Up, Left, Right, Square, R2, R2
High Jumps on Bike
Cheat code: Triangle, Square, Circle, Circle, Square, Circle, Circle, L1, L2, L2, R1, R2.
Lock in Wanted Level to Current Star Rating
Cheat code: Circle, Right, Circle, Right, Left, Square, Triangle, Up
Lower Wanted Level
Cheat code: R1, R1, Circle, R2, Up, Down, Up, Down, Up, Down
Max All Vehicle Stats (Driving, Flying Bike, Cycling)
Cheat code: Square, L2, X, R1, L2, L2, Left, R1, Right, L1, L1, L1
Maximum Fat
Cheat code: Triangle, Up ,Up, Left, Right, Square, Circle, Down
Maximum Muscle
Cheat code: Triangle,Up,Up,Left,Right,Square,Circle,Left
Maximum Respect
Cheat code: L1, R1, Triangle, Down, R2, X, L1, Up, L2, L2, L1, L1
Maximum *** Appeal
Cheat code: Circle, Triangle, Triangle, Up, Circle, R1, L2, Up, Triangle, L1, L1, L1
Morning Sky
Cheat code: R2, X, L1, L1, L2, L2, L2, Square
Never Become Hungry
Cheat code: Square, L2, R1, Triangle, Up, Square, L2, Up, X
Night Sky
Cheat code: R2, X, L1, L1, L2, L2, L2, Triangle
Only Gang Members and Gun Fights in Streets
Cheat code: L2, Up, R1, R1, Left, R1, R1, R2, Right, Down
No Traffic or Pedestrians
Cheat code: X, Down, Up, R2, Down, Triangle, L1, Triangle, Left
Noon Sky
Cheat code: R2, X, L1, L1, L2, L2, L2, Down
Sunset Sky
Cheat code: Left, Left, L2, R1, Right, Square, Square, L1, L2, X
Overcast Weather
Pedestrian Attack
Cheat code: Down, Up, Up, Up, X, R2, R1, L2, L2
Note: This code cannot be turned off.
Pedestrian Riot
Cheat code: Down, Left, Up, Left, X, R2, R1, L2, L1
Pedestrians Have Weapons
Cheat code: R2, R1, X, Triangle, X, Triangle, Up, Down
Peds Attack with Guns
Cheat code: X, L1, Up, Square, Down, X, L2, Triangle, Down, R1, L1, L1
Ninja Pedestrians
Cheat code: X, X, Down, R2, L2, Circle, R1, Circle, Square
Pink Traffic
Cheat code: Circle, L1, Down, L2, Left, X, R1, L1, Right, Circle
Prostitutes Pay You
Cheat code: Right, L2, L2, Down, L2, Up, Up, L2, R2
Raise Wanted Level
Cheat code: R1, R1, Circle, R2, Right, Left, Right, Left, Right, Left
Recruit Anyone (with 9mm)
Cheat code: Down, Square, Up, R2, R2, Up, Right, Right, Up
Recruits Anyone (with Rockets)
Cheat code: R2, R2, R2, X, L2, L1, R2, L1, Down, X
Sand Storm Weather
Cheat code: Up, Down, L1, L1, L2, L2, L1, L2, R1, R2
Skinny
Cheat code: Triangle, Up ,Up, Left, Right, Square, Circle, Right
Slower Gameplay
Cheat code: Triangle, Up, Right, Down, Square, R2, R1
Spawn Monster
Cheat code: Right, Up, R1, R1, R1, Down, Triangle, Triangle, X, Circle, L1, L1
Spawn Parachute
Cheat code: Left, Right, L1, L2, R1, R2, R2, Up, Down, Right, L1
Spawn Rhino
Cheat code: Circle, Circle, L1, Circle, Circle, Circle, L1, L2, R1, Triangle, Circle, Triangle
Spawn Stretch Limo
Cheat code: R2, Up, L2, Left, Left, R1, L1, Circle, Right
Spawn Bloodring Banger
Cheat code: Down, R1, Circle, L2, L2, X, R1, L1, Left, Left
Spawn Caddy
Cheat code: Circle, L1, Up, R1, L2, X, R1, L1, Circle, X
Spawn Dozer
Cheat code: R2, L1, L1, Right, Right, Up, Up, X, L1, Left
Spawn Faster Cars
Spawn Hotring Racer #1
Cheat code: R1, Circle, R2, Right, L1, L2, X (2), Square, R1
Spawn Hotring Racer #2
Cheat code: R2, L1, Circle, Right, L1, R1, Right, Up, Circle, R2
Spawn Hunter
Cheat code: Circle, X, L1, Circle, Circle, L1, Circle, R1, R2, L2, L1, L1
Spawn Rancher
Cheat code: Up, Right, Right, L1, Right, Up, Square, L2
Spawn Tanker
Cheat code: R1, Up, Left, Right, R2, Up, Right, Square, Right, L2, L1, L1
Spawn Hydra
Cheat code: Triangle, Triangle, Square, Circle, X, L1, L1, Down, Up
Spawns Quad Bike
Cheat code: Left, Left, Down, Down, Up, Up, Square, Circle, Triangle, R1, R2
Spawn Vortex
Cheat code: Triangle, Triangle, Square, Circle, X, L1, L2, Down, Down
Stormy Weather
Cheat code: R2, X, L1, L1, L2, L2, L2, Circle
Spawn Stunt Plane
Cheat code: Circle, Up, L1, L2, Down, R1, L1, L1, Left, Left, X, Triangle.
Super Punch
Cheat code: Up, Left, X, Triangle, R1, Circle, Circle, Circle, L2
Traffic Is Country Vehicles
Cheat code: Triangle, Left, Square, R2, Up, L2, Down, L1, X, L1, L1, L1
All Country Vehicles
Cheat code: L1 L1 R1 R1 L2 L1 R2 Down Left Up
Unlock Romero
Cheat code: Down, R2, Down, R1, L2, Left, R1, L1, Left, Right
Unlock Trashmaster
Cheat code: Circle, R1, Circle, R1, Left, Left, R1, L1, Circle, Right
Weapons Pack 1
Cheat code: R1, R2, L1, R2, Left, Down, Right, Up, Left, Down, Right, Up
Weapons Pack 2
Cheat code: R1, R2, L1, R2, Left, Down, Right, Up, Left, Down, Down, Left
Weapons Pack 3
Cheat code: R1, R2, L1, R2, Left, Down, Right, Up, Left , Down, Down, Down
Cloudy Weather
Cheat code: L2, Down, Down, Left, Square, Left, R2, Square, X, R1, L1, L1
May 21, 2013 | Ubi Soft Entertainment F1 Racing...
Please give me cheat codes for the game GTA : Vice City
Weapon/Health Vice City cheats
aspirine - Max health
canttakeitanymore - Suicide
thugstools - Thug Weapons
professionaltools - Professional weapons
nuttertools - Heavy weapons
preciousprotection - Full armor
youwon'ttakemealive - Increase wanted level
leavemealone - Decrease wanted level
May 28, 2010 | Rockstar Games Grand Theft Auto
What does ''L2'' stand for shown on Kenmore Elite Oasis st?
you can call sears parts service and they can tell you what code means
Aug 19, 2009 | Kenmore Elite Oasis ST 7806 Dryer
L1-18 code
I don't see a reference to a L1-18. A L1 code is a scanner feed problem. I only show a L1-00 code. Sorry.
Jul 01, 2009 | Sharp AR-507 Copier
What does the code L1-00 on a Sharp ARBC260 copier
L1-00 means that the scanner unit under the glass was interupted in it travle and didnt return to home position within a specified time. Often you can restart the power to clear this.
May 11, 2009 | Sharp AR-C260M All-In-One Printer
Sharps AL 1530CS flashing L service code and shuts down
You didn't mention the number or code or L code.
If its L1-00 its just only the scanner, it means the scanner is locked.
There is a crystal lock under the scanner and on the top of the exit tray. just rotate the lock, makes sure that the front of the lock is on the direction of the scanner(to the right).
Hope it helps...
Feb 23, 2009 | Sharp AL-1530CS All-In-One Laser Printer
Printer will not prite anything you press anything and nothing happens it flashes L1
L1 means copy lamp problem or mirror drive problem. Check that area.
Jan 14, 2009 | Sharp AL-1642CS Copier
Scanner bar won't move
According to another source, the L1 error means "Scanner position error". Hope you find a solution, and not an expensive one.
May 16, 2006 | Sharp AL-1540CS All-In-One Laser Printer
Sharp AL-1457 Black and White Copier Logo
54 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
