Question about Western Digital My Book Essential Edition (WDG1U5000N) 500 GB Hard Drive
HOW TO FIX WD CLICKING - Western Digital My Book Essential Edition (WDG1U5000N) 500 GB Hard Drive
  • 32,281 Answers
A clicking hard drive is known as "the click of death", this is a faulty hard drive and cannot be fixed. This hard drive needs to be replaced with a new one.
Posted on Sep 27, 2010
Mitsubishi WD-65737 will not turn on
The tv is trash. It will cost more then its worth to fix it..Trust me. Get a new Flat screen and stay away from projections..My Mitsubishi 60" is laying in the shop on its back. They are trash.
Nov 07, 2013 | Mitsubishi WD-65737 65"" rear projection...
Tip
KithenAid Gas Cooktop Igniter Clicking after cleaning.
I had this problem and the solution is quite simple. Remove the control knobs and shoot a good squirt of WD-40 directly down the center of the exposed control shaft. The WD-40 will penetrate the switch located at the base of the shaft and displace the water from inside the switch, which is causing the intermittant operation or clicking of the ignition. I actually disassembled my cook top to learn this fix, but don't take yours apart it's waaay too much trouble.
on Jan 11, 2011 | Cooktops
Hi there, I just bought my WD My passport 500gb usb 2.0 last november, it was fine until yesterday when I mistakenly pulled out the cable while it was installing the WD smartware on the laptop, since then...
1 If the warranty is valid> get another drive and install it according to the instruction set. the hassle is better than trying to fix what is broken or defective without the tools to do so.
Feb 12, 2011 | Western Digital My Passport Essential...
Clicking and not showing up
There are different software available. Try Spinrite if you can. If it works, it'll help fix your hard disk.
May 18, 2010 | Western Digital Passport WDXML800UE...
Wd 52525 red lamp light on but new lamp isn't
HI. the actual issue will be a failed ballast device. replacing this damaged power regulator will fix this issue. you can order your new ballast by clicking the link below.
Ballast(Click here to order)
Sep 02, 2009 | Mitsubishi WD-52525 52" Rear Projection...
My WD 1 tb says application not found
sounds like you have to do a viruss scan and check from there,
or your computer may have had updates installed recently that have changed its functionality,
to fix this you could restore your computer to an earlier time
Sep 02, 2009 | Western Digital Elements powered by WD 320...
I have a mitsubishi WD-57731 57 In. DLP. When I power it up I get no or video it makes a whirring light clicking electrical sound in the back. The timer indicator flashes green for like 20 secs or so when...
The whirring is the fan. The clicking is the spark gap on the ballast releasing the unspent voltage trying to fire on your lamp.
Check your lamp; it may be unseated (unlikely) or just blown/bad (likely).
Jun 15, 2009 | Mitsubishi WD-57731 57" Projection HDTV
WD need to be fixed.
well..the clicking noise is not a good sign.. Can you unplug it from computer completely. power it down..wait around 5 min, and then plug it in without computer?
May 28, 2008 | Western Digital My Book Essential Edition...
Cannot retrieve data from my 500G WD
For your 2 queries:
1. The clicking sound is indicative of a hardware failure or the start of one. Considering having it fixed would simply be buying a bit of time and prolonging the inevitable.  The drive even when repaired tends to be suspect and would defeat its very purpose;
2. You can perform the reformat yourself. If the WD would show as a removable drive in your Windows Explorer, right clicking on the assigned drive letter would give you the option to Format it.
Alternately, it might be to your advantage to simply replace the WD. In some instances, it is also possible to just replace the actual HD inside the enclosure.
Hope this be of some help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Oct 28, 2007 | Western Digital My Book Essential Edition...
Western Digital My Book Essential Edition (WDG1U5000N) 500 GB Hard Drive Logo
156 people viewed this question
Top Western Digital Computers & Internet Experts
Marcin
Mike
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
