I have one VIN-845GLD mother board witch is equivalent to Pretech Taiwan PT-845GLD-MN board. I want to connect the front panel like pwr reset and hdd led and power led. i don't know the connections pls help!!!!!!!!!!!!!!!!! its and urgency!
ericram
  • 101 Answers
SOURCE: Front panel connections
You can download the complete user manual in English from the manufacturer's website at this link:)
http://support.asus.com/download/download_item_4.aspx?product=1&model=P4B533&SLanguage=en-us&os=17
The front panel connector pinout is on page 2-33, or page 59 in the PDF file. You should have mor ethan enough information to make all the connections you need.
Posted on Jan 02, 2009
sodeep
  • 3267 Answers
SOURCE: can't connect power switch reset switch hdd led to
If your power is correct, then the reset leads comes to the 2 pins imm. after the power connection...................sodeep
Posted on May 16, 2009
nonontech
  • 4737 Answers
SOURCE: i am having a problem
Take a look at the picture below:
If I am right, the Front Panel connector should look similar as shown above (it's an assumption since you didn't mention the Motherboard's name and version). Look at the front panel connector on the motherboard carefully, you'll see similar name/indicator as you are seeing on the above picture like Pled, Hdled etc... I hope the front panel connector has 9 pins, and remember, one should be left without any connection.
Simply you have to connect the two female Pwr-Led to the Pled+ and Pled-, and Power to Pwr and Gnd, the same sequence with hard disk led and Reset switch as Hdled+ and Hdled- and Gnd and Reset respectively.
If the front panel connectors on your motherboard has less than 9 pins, then I am sorry, I have no idea about it and I am afraid if it exists or not.
If you still have the problem, let me know.
Good luck.
Thanks for using FixYa.
Posted on Aug 01, 2010
virtualhost
  • 2185 Answers
SOURCE: looking for installation manual for
Here is where you can see the manual for your reference.
http://www.fixya.com/support/p281308-soyo_sy_kt333_dragon_ultra_motherboard/manual-35537#
Upon clicking the link, wait for it to completely load. If you want to download it, just click "Download this Manual" link so click on that. You will be asked to fill up the captcha for verification.
Please let me know if you are able to download it. Thank you for using FixYa.
Posted on Oct 13, 2010
  • 82 Answers
SOURCE: pinout for front panel connector
the molex connector
Posted on Dec 20, 2010
Dell motherboard diagram of wiring and front pannel connectors
most front panel connectors with a 4 x 5 pin configuration are intel compliant, and are all the same.
The "nine" pin is missing, and is the "KEY" to orientation, no matter which way the pins are situated on the board.
1 3 5 7 X
2 4 6 8 10
1= HDD LED+, usually green
3= HDD-, usually white or black
2= PWR LED+, usually red
4= PWR LED-, white or black
These are polarity specific, and must be connected to the proper + and - terminals to work properly
5= RESET
7= RESET
9 is missing, can be used to determine location of other pins
6= PWR
8= PWR
Thes are momentary contact pins, can't get them backwards
Pins 6 and 10 are jumped together in the Dimension 2400.
Apr 18, 2014 | Dell Dimension 2400 PC Desktop
I have a hp pavilion a1777c desktop. i had to take it apart to replace hdd and dvd rom and some other parts. i have been trying to get detailed info on where the front power panel wires connect onto the...
There is usually a set of pins on the corner that are labeled get a magnify glass and light up the board take the glass and look down on one of the corners it is usually on the right corner of the bottom of the board at the bottom of the desktop case. You will usually see a series of abbreviations. LED, HDD, PWR, RES or RE the pins are marked. Now on the wires to the power button you will see the same wire abbreviations. Just hook up the HDD wire to the HDD pin the PWR to the PWR button wire and so on. RESET wire is RE or RES etc. Those really are the only three you will need. Not sure of the exact abbreviations. But they are lettered enough for you to match them. The best thing to do is try to download the board specs and get a look at the pins one side is neg and the other is positive it would be to your best interest to find the mother board specs for you mother board since you went all over the internet and could not find the board specs. just match the LED and the others they are marked PWR is the main and HDD is just showing when the HDD is working. The reset is for the button to reset the computer. It is basic and not that complicated really. Thanks for using FixYa! John
Mar 02, 2011 | Computers & Internet
I try to connect my ECS Motherboard one again but
you may have misplaced the power switch connections which come from front pane to the mother board
there are many of them like pwr switch, reset switch
hdd led etc
check *********** board it will be indicated where to connect the pwr switch pwr led etc
May 07, 2010 | EliteGroup ECS GeForce6100SM-M (1.0)...
I lost all conection from mother board (USB2 and
there is a label on the mothereboard on what connector you will put..youll see hdd,pwr something like that
Dec 13, 2009 | Foxconn 865G7MF-SH Motherboard
Front panel Mic not working when connected to Mother Board
Yeah,sounds like the case wasn't designed for that board. Just carefully double check the pins in the manual for the board. If you don't have the manual,check the asus site.
Jul 10, 2009 | ASUS Computers & Internet
Lost book on mother board and i accidently pulled the case wires from the mother board. need to reattach in order for the mother board to have power and thus the computer to power up.. need to see...
Hi there.
Get a strong flashlight and a magnifying glass (if you have one). On the motherboard look for the front panel, it should be marked PWR and coloured green, also the plug that connects to it should be marked PWR_SW. On some boards there are no colours but the markings are the same, so a good close look.
Have a look at these pictures for an idea >>>>>>
Please post back with the results and any more advice if needed.
Good luck and thanks for choosing FixYa!!
Jun 11, 2009 | EliteGroup ECS L4VXA2 (CDL4VXA2)...
Jan 02, 2009 | ASUS P4B533 Motherboard
PWR > PWR (aka PWR SW), HDD LED > HDD LED, RST > RST (aka RST SW and Reset)
May 31, 2008 | Iwill XP333-R Motherboard
MY MONTOR HAS POWER AND IS NOT WORKING.
Hi, dont loose faith. If you look on your mother board along the edge closest to the front of the case you will see a series of pins, usualy about 10 pins. Printed on the board will be the names of the plugs that match. The wires from the front of the case have corresponding names. The power and reset switch will work no matter witch way around you put them. The HDD led and the pwr led will only work one way so if these lights dont work, just reverce the plugs. If desperate you can bridge two pins together at a time until you get the on/off switch. Note you cant hurt anything unless you use a hammer. Regards mistyman
Sep 03, 2007 | FIC FR33E Motherboard
Computers & Internet Logo
257 people viewed this question
David Payne
David Payne
