Question about Toshiba (HDD2171) 40 GB Hard Drive
My Toshiba HDD2171 has stopped working. I have connected it to my Desktop PC with a IDE connector. It fails to be recognised. What can I try to retrive my data.
  • Toshiba Master
  • 32,281 Answers
If you tried to setup the hard drive as a slave drive and it didn't work then you might try this, but I think it you will have much success.
Connect the hard drive to an USB hard drive adapter and then plug this into the USB port of a working computer. If this computer detects it as an external storage device and you can open the folders and files then you are in luck.
If not then there are companies that can recover data from faulty hard drives, BUT it will cost you an arm and a leg for their services.
Posted on Sep 27, 2010
  • ronnymar Sep 27, 2010
    No it did not work. Did not recognise it. Trying the freezer trick.
Hard disk wd500aakb no power
Please give us some more information on exactly whats happening. Are you trying to connect this to a desktop PC or put it in an external exclosure?
For a desktop PC, the basic steps to try are:
1 - Ensure both the IDE cable and molex cable are connected to the hard drive. If it still doesnt work...
2 - Test the drive with a different molex connector that is known to work. Only connect the molex connector (4 pin power connector) and not the IDE data cable.
If the drive still doesnt spin up, it would appear the drive is faulty and requires replacement.
For an external enclosure:
1 - Take the enclosure apart and take the drive out. Test it in a desktop machine by using the above steps. This will let you know if the drive or the enclosure is at fault.
Hope that helps!
Jul 03, 2012 | Western Digital Caviar Computers &...
Toshiba hdd2171 has failed (no boot, very bad sounds coming from hard drive) any ideas what I can replace it with? Appears to be 2.5 inch, IDE 40gb, can i replace it with another toshiba ide hard drive,...
Yes, you can replace it with another Toshiba hdd 80GB or 120 GB. It doesn't have to be a Toshiba HDD. It can be any HDD that has an IDE interface for the ribbon cable to plug into. I prefer Western Digital hard drives myself, but Toshiba does make very good hard drives as well. There are several name brand HDDs out there. Just make sure you go with a name that you trust, I don't suggest going with some off-the-wall brand for a HDD. I've tried some "No Name" HDDs before and they have all failed within a 1-2 year period. You don't want to take the risk of an HDD crash and losing your data again within the next year.
Apr 12, 2010 | Toshiba (HDD2171) 40 GB Hard Drive
HP Pavilion 7955 main HD failed; my data is on second drive (Maxtor ATA/EIDE) - still good. I want to install this as a second drive in Dell Optiplex 620 which has SATA main drive. The only IDE cables are...
Most IDE cables have THREE connectors:
* one to the motherboard
* one to the "primary" device (CD/DVD or disk-drive)
* one to the "secondary" device (disk-drive or CD/DVD)
If your IDE cable only has TWO connectors, buy a cable with THREE connectors, and connect your disk-drive to the third connector.
Mar 03, 2010 | Dell Optiplex GX260 Refurbished Intel...
Hard drive adaptor
Your laptop HDD uses a newer connection type called SATA. The one you are used to using is called IDE. They do make adapters to go from one to the other but they are hard to find and not very reliable (sometimes just dont work).
You can find a 2.5" (laptop size) hard drive enclosure for SATA to USB at almost any electronics store.
Double check your motherboard (on your desktop if thats what you are using to read the drive) for SATA connectors on it. Many computers have been using SATA almost as a standard since about 2004-2005, but some may not still have it.
The reason for the new type of connection is faster data transfer speeds.
To look at the differences, click the link below:
http://jekkilekki.files.wordpress.com/2009/06/sata-ide-laptop-hard-drive.jpg
Oct 16, 2009 | Toshiba Satellite P105-S6104 Notebook
Cannot boot up Inspiron 8200
Could be a tough one. Can you get into the bios ( F8  or F10 ) while booting and check if the HDD is being recognised in the first place ? If it recognises, then check for Boot sequence. I would also suggest to try the Recovery CD that came along with computer.
Feb 02, 2009 | Dell Inspiron 8200 Notebook
CDRom stops working when I connect IDE cable
put some different power connector other than you have used now, then check
Nov 20, 2008 | E-Machines eMachines Desktop PC
Toshiba Laptop A60-S166 fdisk won't recognize hard disk? ACPI Bios Version = 1.40 Bios setting Drives I/O where it says Built in HD = No Drive Built-in ODD = Secodary IDE(170/IRQ15 Won't let me get into...
Hmmm. Unusual report, "secondary optical disk". Sounds like you have a primary and secondary IDE setup. Something desktops had, but rare for laptops. Because of this, I would try setting the HD to "master". Most IDE HDDs have some extra pins beside the IDE pins, 4 or 6 pins in a separate compartment, same side as IDE jack. These are for choosing "master", "slave", and (default) auto detect. To find out which pins must be connected, look for a diagram on the lable or side of HDD. If none there, look up the specs on your HDD at the manufacturer's website. If all fails, It does not hurt to use "trial and error" on these pins. Either BIOS will be happy, -or ignore the setting. Try again until you find the right one. You need a small jumper to try this. If you are VERY careful not to wrap more than two pins, you can do this with a single wire from a copper stranded wire. Use hemostats and clip the excess off clean. Use a magnifying glass to verify it only touches (connects) two pins.
Personally, I would try THIS first, but it will cost you a bit of money... Buy an external IDE HDD case, with USB connector, insert your HD, plug it into a desktop PC, mount it, and use FDISK there. Always better to format a 2.5 inch drive via ext methods. Avoids funky BIOS corruptions, wacky 8mb Toshiba "recovery partitions" and MBR viruses. Also avoids the LBA limits many older laptops have, if YOU format the drive externally. This can also be the only problem. Not jumpers, but format methods. If the laptop is older than 3 or 4 years, I would suggest restricting ALL partitions to FAT32. Maybe C, D and E. Afterwards, the external USB case is a GREAT device to have, for exporting/storing large files from your laptop.
Let me know how it goes
Feb 08, 2008 | Computers & Internet
New Maxtor 3200
Hi, This is a common problem with external storage. Based on your post/description: 1. Your laptop does not recognize the external hard drive via its USB connection - try on a different computer - if it is still a no go, then it's not a PC problem; 2. Try replacing the cable - again if a no go, so it's not an interface/cable problem; 3. That leaves you only with the PS3200 itself as the possible at fault. An external hardrive would consist of 2 main parts, the electronic board and the hard disk itself. The board seldom (if ever) fails. Its function is to provide conversion/interface from the SATA/IDE connectors of the HD to the out USB/Firewire. The HD more often than not fails. Most external storage uses a standard HD inside the enclosure. Your possible options: a. Claim warranty/replacement; b. Replace the HD only; c. Physically remove the HD and connect it directly inside a desktop either as IDE or SATA and run manufacturer's diagnostic and/or third party recovery software; d. Seek services of professional data recovery firms (if data/files are mission critical); Hope this be of some help/idea. Post back should you need further information. Good luck and kind regards.
Sep 02, 2007 | Maxtor Personal Storage 3200 (U01E200) 200...
Error on laptop during startup
The IDE0 refers to the HDD ide cable connector. It may be faulty or the connection from the motherboard. When booting up pres F2 or Del to see if your HDD is being recognised, if not the cable will ned replacing.
Feb 10, 2007 | Toshiba Satellite A40-S161 Notebook
Toshiba (HDD2171) 40 GB Hard Drive Logo
157 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
