Question about Tissot T-Touch T33159851 Wrist Watch
I have t-touch tissot. Meteo and Altimeter don't work; sometimes it works for a while. but mostly doesn't react to touching the glass.
4 Suggested Answers
SOURCE: "Tissot Touch" Touch screen failure
it all stems from the watch not actually being waterproof it's more water resistant than waterproof. The little indentations on the back that look like they are for a tool to unscrew it are actually holes i guess for the altimeter and meteo so it can sense pressure. Behind the back just behind the holes is a nylon gauze material and underneath this is a sensor slightly recessed and covered with some kind of waterproof substance. As far as i can see the problems lie here any water sweat or other foreign object than gets into this gauze will eventually will clog this gauze material which at first will affect the altimeter then the meteo. When the gauze has been clogged up severely i gets very dirty indeed which means when it gets wet it takes an age to dry out so if you wear it in the shower like i used to it will never dry out this causes the watch to malfunction quite severely. You can actually fix this problem yourself just get a very small flat screwdriver and lever the back off don't worry it's only a push fit and comes of easily you will see straight away a dirty damp smelly clogged up round piece of nylon gauze clean this up with a bit of WARM not boiling soapy water being careful not to disturb the pressure sensor and it's waterproof goo inside then dry it all and put it together
Hope this helps
Dom
England
Posted on Feb 26, 2008
  • 3 Answers
SOURCE: touch screen is not working
==== http://www.voguecatch.com ==== ====accept credit card and paypal
Cheap Nike air Jordan shoes33$,Air Force 1 33$, Nike dunks SB shoe,Nike Shox shoe. Wholesale Cheap Nike shoes with discount jersey, High quality T-shirts,ED hardy t-shirts,ED Hardy hoodies,ED hardy shoes,ED hardy Jeans,Evisu shoes,GUCCI shoes,LV Handbag,Chanel Handbag......welcome to ==== http://www.voguecatch.com ====
Nike shox(R4,NZ,OZ,TL1,TL2,TL3) $35
Handbags(Coach lv fendi d&g) $35
Tshirts (Polo ,ed hardy,lacoste) $13
Jean(True Religion,ed hardy,coogi) $30
Sunglasses(Oakey,coach,gucci,Armaini) $15
New era cap $16
Bikini (Ed hardy,polo) $18
Posted on Oct 26, 2010
small6363
  • 18394 Answers
SOURCE: reset a tissot t touch
here is manual
http://support.tissot.ch/usersmanual/138-en.pdf
Posted on Aug 17, 2012
Thermo shows 91.7c, Meteo shows just hpa and altimeter just m other 3 functions working fine.
same question here, but it happens to me after a dead battery replacement, although the temp on my watch indicate 78.0 c, another sympthons are the same
Oct 18, 2009 | Tissot T-Touch T33159851 Wrist Watch
T touch Meteo out by 20 Milibars
Certain functions need to be calibrated. The altimeter and the Meteo are tied together. When a customer gets the watch, they should calibrate to either the Meteo or Altimeter. The easiest way to find out the altitude of the nearest airport (you can usually get this on line) and then go to the airport and adjust the
watch. This will also calibrate the Meteo.
To calibrate the Altimeter:
1. Activate Crystal
2. Press Altimeter
3. Press and hold top + button until the watch beeps and display flashes.
4. Use + and – buttons to adjust altitude
5. Press center of dial to lock in.
Oct 14, 2008 | Tissot T-Touch T33159851 Wrist Watch
Tissot T-Touch Baro way too high
Try to recalibrate the Baro/Altimeter as below:
Certain functions need to be calibrated. The altimeter and the Meteo are tied together. When a customer gets the watch, they should calibrate to either the Meteo or Altimeter. The easiest way to find out the altitude of the nearest airport (you can usually get this on line) and then go to the airport and adjust the watch. This will also calibrate the Meteo.
1. Activate Crystal
2. Press Altimeter
Aug 05, 2008 | Tissot T-Touch T33159851 Wrist Watch
Tissot t-touch t0015204406100
Go to the offical Tissot site www.tissot.ch and download the pdf file "user manual" and there you'll have everything u need to know about operating this great watch...
Jan 12, 2008 | Tissot T-Touch T33759851
Tissot T-Touch : Faulty reading on Thermo, no reading on Altimeter and meteo not working either
If it's under warranty by all means pursue a fix. You might have to send it to a warranty center instead of working with your local dealer.
"Water proof" and "water resistant" are very different. About 20 years ago all watch companies stopped promising waterproof and started using the term water resistant. It gives them wiggle room in the guarantee, unfortunately. I believe T-Touch is supposed to be water resistant to only a few meters.
Nov 21, 2007 | Tissot T-Touch T33159851 Wrist Watch
Meteo
1. How do you know the meteo is wrong? Are you comparing against a known good measurement device?
2. The altimeter requires adjustment every few days or whenever there's a weather change. Select the altimeter, hold the upper or lower button until you have the correct altimeter reading for where you are and it will hold for a few days.
For example, I know my home is at 100m elevation (I checked on a topo map) so I reset it to 100m when I leave the house in the morning. It varies (in my case) by over 100m in either direction, depending on the weather.
Nov 03, 2007 | Tissot T-Touch T33159851 Wrist Watch
The 'meteo' function doesn't work when I press the watch face.
This seems to ba a common problem. On mine both the Meteo and Altimeter stoped working. Apparently these watches have a fault with the water proofing and should not be worn in water!
Oct 23, 2007 | Tissot T-Touch T33759851
Tissot T-Touch T33159851 Wrist Watch Logo
370 people viewed this question
Top Tissot Watches Experts
Ansel Alberto
Ansel Alberto
Shehu Pro
Shehu Pro
Are you a Tissot Watch Expert? Answer questions, earn points and help others
